Chris800, 8/30/2020 at 4:54 PM
I called the seller today and asked him for the VIN - JH2RC46AX5M700055
Running it on couple checkers online (I didn't find any in the search here) it comes up as produced in Manufacturing Plant: HAMAMATSU SHIZUOKA JAPAN I'm not sure where the most of them are made, but I'd guess it's around the world?
I've compared it to a VIN from the recall pined post. First one is this bike's VIN.
https://www.vindecoder.pl/JH2RC46AX5M700055
https://www.vindecoder.pl/JH2RC461X4M601209
https://www.cyclepedia.com/manuals/CPP-VIN/index.php?VIN=JH2RC46AX5M700055&submit=DECODE+VIN
https://www.cyclepedia.com/manuals/CPP-VIN/index.php?VIN=JH2RC461X4M601209&submit=DECODE+VIN
Does anyone know a better vin decoder or should I better call Honda?
I don't know of any online VIN checkers that give anything other than the most basic information--which does not include the market designation. But, then again, I'm old school and have paper Honda Parts Catalogues for all of my bikes, so how would I know!
I found a .pdf of a ROW 2002 VFR800 Honda Parts Catalogue in my files, however, which confirms what I would have guessed based on my experience with VINs of somewhat older Hondas. In your VIN, "JH2" indicates that the manufacturer is Honda, "RC46" tells us this is a VFR800, "A" I will get to in a moment, "X" is the VIN check digit (which you can ignore), "5" refers to the model year 2005, "M" refers to Honda's Hamamatsu factory, the "7" in the serial number section tells me that model is from the eighth year of RC46 production (1998 to 2005), and the "00055" says that this was the 55th [something] to roll off the line when it was manufactured (probably actually in 2004, but that's irrelevant).
Now, back to the "A" I mentioned above. That is the fifth digit in the Vehicle Descriptor Section, and this is the most critical digit in the entire VIN if you want to identify the market for which it was originally designed. "A" is usually the letter Honda used at that time to indicate a model intended to be sold in Europe or the UK, but the exact meaning of the letter or number in that position in the VIN changes from year to year, so you really have to look at the Parts Catalogue for the specific model to know what an "A" means in a given year. Because an "A" usually means a European bike, I would have said it was not a Japanese model because of that, but then I found this:
Looks like there were J-spec 6th gens (these are photos of the Japanese version of the bike's Honda Parts Catalog from Yahoo! Japan Auctions):
[image: spacer.png]
[image: spacer.png]
[image: spacer.png]
But, look at the last photo. That page from the J-spec Parts Catalogue shows that all of the Japanese models had Frame Numbers and Engine Numbers, not 17-digit VINs, so a genuine 2005 J-spec VFR should have "RC46-14xxxxx" stamped on the frame. So, that bike is not a Japanese model. (Note also the identification picture: they also had standard Honda wings on the tank.)
So, what market was it originally intended to sell in? Most likely, somewhere in Europe, based on the "A" in the VDS. But you'd need to ask Honda or check the VDS code in the 2005 ROW Honda Parts Catalogue to know for sure.
JZH
