Bleeder valve size for PCV
3 posts Started 21 Jan 2021 Last recovered post 21 Jan 2021 Wayback Machine snapshot 5 Mar 2021
Hey guys, I’m in the middle of a brake fluid flush and taking the opportunity to install speed bleeders this time. I’m looking at the diameter of the threaded portion of the PCV bleeder valve (still installed) it appears to be bigger than the speed bleeder I have to replace it. Because of this I thought to ask before removing it. I tried searching for the answer to no avail.
Does the 5th gen PCV take the same size bleeder as the rest of the system?
Thanks in advance!
If you completely remove that bleeder, you'll see it is a unique design, nicely sealed with an o-ring, no reason to replace it.  I don't know of a SpeedBleeder that would fit.
5 minutes ago, raYzerman
Thank you very much for that reply! I will leave it be and proceed.
End of thread · 3 posts recovered Wayback Machine snapshot 5 Mar 2021
