So I’m slowly (VERY slowly) updating an engine on the bench (build thread to follow!) and have run into a problem fitting a new countershaft oil seal. It won’t bl00dy fit!
Old seal needed drilling, couple of screws inserted and pulling. I’m talking vein-popping, red-faced and swearing type pulling!
[image: B2A2DF7D-3888-40A5-97B4-50382DB4237E.thumb.jpeg.1e95fee6ca1053f8663b62cf44d259cd.jpeg]
[image: 16C9D8F6-5A3D-4FEB-A9DA-C388C219BE40.thumb.jpeg.039f54dea97b644a0851d5b92d28adcf.jpeg]
[image: F21A7EE3-8C89-46EB-9717-B4E228540C84.thumb.jpeg.929b29030c747cd6c352d96ebee7ca90.jpeg]
[image: CCEFCE74-9A37-4654-8141-355A876A0348.thumb.jpeg.13ff87af8a5aa7da35b9bf3e355ba670.jpeg]
Old seal next to new one.
In fact it was a very strong seal and I really regret trying to replace it. Should have left the b@stard thing alone!
Anyway, I bought a new seal and it didn’t quite fit. The pushrod and shift shaft seals went in beautifully. So what’s this guy’s problem?
Anyway, the engine needs a countershaft seal so after much head scratching I decided to try fitting it. Lubed her up real good, found a jug with the right size opening and heaved like a man possessed.
[image: E7F6FA7F-FB65-4E60-BCDA-C5DF47BC8C40.thumb.jpeg.3cd80e93df6d068fe0e4593325d3aa0d.jpeg]
Because it seems so big I couldn’t get it to go in square. One end always ended up slipping out and unsettling things. But it needed to go in so I persevered and pushed harder than a teenage boy with half a chance!
Anyway, the result was awful as you’d expect. Much of the seal sheared off from trying to squeeze into the hole.
[image: 02CB8A5A-03BB-491A-BD8E-70101B8464C3.thumb.jpeg.bb657df769acad68a7bc5f6feb1fb474.jpeg]
Comparison of old seal with the piece sheared off from the new one. That’s a lot of seal to lose on insertion!
When I pulled the new seal out you can see how much of it has been sheared off when compared to a new one.
[image: D5DD9504-F2E4-4435-B928-EA530C285695.thumb.jpeg.666c0cc5e1152eb3dab59ea65a78c494.jpeg]
Drill 3mm hole and insert 4mm screws to pull on.
[image: 45BEDE8F-8197-445E-A926-0D128877B118.thumb.jpeg.f6730cec75f53a774b5ca0e19a3a87de.jpeg]
[image: 009A48C2-54DE-4FBA-B9B0-2571E0D03351.thumb.jpeg.0266f3289399e5e6ef6a4b7dd3d307c5.jpeg]
See how much of the lip is sheared off? You can see the metal part of the seal exposed. There’s almost no rubber there at all.
Here’s a comparison of how much material is missing. See the torn seal next to the newest seal (3rd one now!).
[image: 457E1122-2A38-4B80-92BB-5D110E138247.thumb.jpeg.ff855fa839edb225726a9a43aea18a54.jpeg]
[image: B6FA15F7-3E4C-4A6D-96FF-E8608C0F356D.thumb.jpeg.39da35ce32dbeb0b402b42acc2f9ea05.jpeg]
No such damage on the old seal. So how is this aperture so damn tight? Is the seal supposed to be so squeezed? How was the original seal fitted?
Old seal has same size numbers marked on surface so it CAN be made to fit. Just need to work out how!!!
Anyone got ideas on how I can get this one in there? I’ve got visions of a piston ring clamp...
