VFR Discussion Group -> Power commander
6 posts Started 11 Jan 2005 Last recovered post 11 Jan 2005 Wayback Machine snapshot 3 May 2005
Any of you with the PCIII USB played aroung with the new accelerator pump utility yet?  i was curious to see if it is worth the download.
I tried it with my vtec. I sure was able to make it pop and backfire! Didn't really get any noticeable improvement with their suggested settings though. Back to normal the PC went.
I've got it set up on mine right now...but I can't see where it makes that much of a difference.  Then again...I may not have it set correctly either.
I'll have to play around with it some more when sping comes, & see what I can come up with.
Peace
It's usefullness may depend on your map.
I run the "stock" map from dynojet with a few low RPM tweaks, and I run the acclerator pump with the dynojets recommended "street" settings, and I like it, I think it helps with on/off smoothness. �I think the accelerator pump does hurt your fuel economy but that may just be a result of it inspiring you to get on the gas more.
You can definitely REALLY screw up your bikes response if you use the accelerator pump with the wrong settings! �I did experiment when I first turned it on. � :roll:
Dynojet's recommended starting point for a streetbike:
90% sensitivity
15% fuel increase
20 engine revolutions
Recommended for a racebike:
75% sensitivity
20% fuel increase
15 engine revolutions
My guess is that if your map is too rich you won't be able to feel anything with the accelerator pump, or it will mess things up.
Quote
benSV Posted on Tue, 11 Jan. 2005 06:43:00
It's usefullness may depend on your map...
I had a before and after run on my bike and the downloadable map was wayyyy rich according to the dyno run (average 12.8  to 1 fuel/air) so there is validity to BenSV's input if you are running dynojets free Map.
jim
I would be suspicious if a dyno run even correctly measured the A/F mixture on a new VFR.
When I had mine dynoed (just a basic dyno, not a full tuning session), they determined they could not correctly measure the mixture on this bike without further work, so they didn't record it.   The standard probe won't fit down the VTEC muffler and the cat and 2008 emissions package causes some changes in the readings.
AFAIK if I go have the bike tuned they'll have to take one of the O2 sensors out and place a special probe in the O2 sensor port, as the normal probe they had didn't look like it would work correctly.
End of thread · 6 posts recovered Wayback Machine snapshot 3 May 2005
