Repairing thread on the clutch slave cylinder
34 posts Started 27 Mar 2021 Last recovered post 7 May 2021 Wayback Machine snapshot 25 Jun 2021
After changing out my front sprocket, without much force I managed to break one of the threads of the clutch slave cylinder/ front sprocket cover. Now I can't get the cover on and I essentially have no clutch.
I bought a Helicoil kit to repair the thread but the tap is not long enough to fit all the way down the hole. The shank is also too big and gets stuck when trying to drill further than the thread length.
I tried looking online for longer taps but I found nothing helpful. The hole is about 2.25in deep.
The bolt is M6x1.0
[image: image.thumb.png.8d2a682e222213456f28bfd061c82b80.png]
[image: image.thumb.png.b2ee01915dfb453280f4c3a4c494e356.png]
[image: image.thumb.png.f77fe6f6711c90a7e2115fdf300d4a0b.png]
^^^ the shank is too wide and it won't go in further than the thread length without destroying the hole
I've often wondered about this.
Is there any particular reason that bolt has to be so long with threads so deep in that hole?
What if we tap hole close to surface of hole and use shorter bolt?
I've seen tonnes of helicoil repairs come apart. Might be OK for permanent repair that's never disassembled, but upon removal several times, lots of them come apart. I prefer more durable solid inserts. Such as EZ-lok or Time-serts.
https://www.belmetric.com/m6x10-c-217_218_228/ts1610-m6x10-timesert-kit-p-1499.html
2 hours ago, DannoXYZ
[image: image.thumb.png.40d88635b266e9898aec51a4b2a22b5a.png]
[image: image.thumb.png.6dce2139340203a3ddf68ac4b82ec5e5.png]
if you look at the first image you can barely see a gasket poking out. The threading is past that gasket so the bolt is holding the slave cylinder in place and another cover in between the transmission and drive sprocket.
So, I don't think threading just the surface would be a good idea.
3 hours ago, styran
The bolt is M6x1.0
Can you use a grinder to slim down the shaft to fit the opening?  You'd be tapping aluminum,  so it seems unlikely the tap would break.
When I remove that cover I make a cardboard template to ensure each bolt goes on the correct place and always use an inch-pound torque wrench to tighten the bolts.
6 minutes ago, Cogswell
Is there a specific torque spec for these bolts? I broke the thread by applying barely any torque at all.
Yes - IIRC 9 ft-lbs, 108 in-lbs on a small TQ wrench.   Same for the clutch cover.  All the steel bolts that thread in to the engine case deserve special attention due the consequence of stripping them out.
Not sure how much those cost here. I just grabbed the link to show what machine tap is...
10 hours ago, DannoXYZ
Yes, it's just a cover, essentially, and there are other fasteners holding it in place (there are even dowels).  The only problem I can see is that there isn't much meat at that point in which to tap a larger diameter thread.  But the long tap option is probably what I'd try first.
JZH
1 hour ago, JZH
JZH
I'd see how things function without that one bolt, prior to throwing $$$ at it.
[image: image.png.b6b3248dbd949825c9e51f274e2544a7.png]
https://www.bike-parts-honda.com/honda-motorcycle/800-MOTO/VFR/2007/VFR800A6/Engine/WATER-PUMP/13MCW601/E__0900/1/38097
Why not epoxy the hole with the bolt in? The bolt should be lubed first and the epoxy won’t stick.
When epoxy cures then bolt gets backed out and voila - new threads. Lots of YouTube tutorials.
If it was mine I’d build the hole up with alumiweld rods and drill/tap. You can also do this with the bolt in place as above (alumiwekd won’t stick to steel so the threads will be perfect). These are low temp solder-like rods that can be melted with a torch. Repaired a few things with them in the past.
Best,
Stray
I think he needs a tap specific to Heli-coils, which may be a different pitch than a normal tap. The hole might be too deep for a time-sert which I do agree are by far the best.
You can do what I did on my kid's Honda 80 dirt bike, considering the depth of the threads - Take the fairings off, and lay the bike on it's side. Mix up some titanium epoxy, or JB Weld, and put it in an infant medicine syringe with a small tube on the end. Fill the hole with the epoxy - ONLY PART WAY. When it sets up, drill and tap it.  You will actually need a RELEIVED tap as some aer just long, but may not fit in the hole. Also when you drill it, make sure you put tape on your drill bit so you don't go too deep. I would not go more than 4mm past the lenth of the screw FROM THE OUTSIDE OF THE CLUTCH COVER - otherwise you might get into an oil galley or water jacket. You can also test the depth of the hole without the clutch cover if you use a pointed pick that is thin and long enough to measure the depth.
Great ideas.  Having that bolt doing its job is important - the clutch puts a lot of pressure on that cover.  Leaving one bolt out will work for a time - over time the a-symmetric force on the cover will result in it flexing ever so slightly each time the clutch is cycled.  Long term the cover can fatigue and possibly crack or break.  If it fails sufficiently, the clutch will be in-op.   If it were mine, that would happen when I'm some multiple day's ride from home . . . my $.02.  YMMV.
Good point.  But how much is a spare clutch cover?  ⁉️
JZH
The clutch cover is extremely brittle - super thin aluminum "pot metal" casting. When I cut mine for the Budget Streetfighter, I was gripping it with vise grips, and it broke. I ended up just chunking pieces of with said vise grips, then ground it to the final shape. Any off-axis flexing and it snaps!
Helicoil taps are the same pitch as the thread being repaired BUT are bigger in diameter.
You first drill the failed thread out and then cut a new thread with the special tap.
To Helicoil that thread you need to remove the selector assembly cover, the one behind the sprocket, so as you are down to the base crankcase where the actual thread is.
Then you repair it and reassemble it all.
No use at all trying to repair it further up the hole and using a nut tap is only the same thread diameter as the standard M6x1 thread.
Do it once and do it right.
13 hours ago, HighSideNZ
I think the issue he is having is that the "special tap" will not fit down in the hole being repaired. Additionally, I'm not sure the "special tap" is a standard pitch, as it might be proprietary to Helicoil, and therefore he may not be able to get a longer relived version of the "special tap".
The pitch has to be the same pitch as the damaged threads, but the diameter is different.  According to Helicoil, the taps are called "STI" (Screw Thread Insert) taps and they are not just larger standard taps.  That makes sense, as larger standard threads usually have different (larger) pitches, so the new tap would have to be a "fine" thread version with exactly the right diameter to accommodate the Helicoil wire.  There could be a coincidental match, though...
JZH
RC1237V, 4/3/2021 at 2:22 AM
Hence why I said the shifter case should be removed so as you can get to the base thread and repair it correctly.
If you could get a longer version of the Helicoil tape you would end up threating the outer shifter case as well as the damaged thread in the crank case.
Not ideal or wanted as you could end up with the helicoil partially in both parts.
Phil
Well about three weeks ago I took an angle grinder like what @Cogswell said and I managed to thread the whole hole. Once I got three helicoils in I put in the bolt and tightened and the bolt got stuck. What ended up happening is the bolt split in two with the thread portion of it stuck one inch down the hole. It is lodged in between the crankcase and the gearshift linkage cover. I definitely should have taken the cover off before sticking helicoils down that deep hole. So now I'm really in trouble and I can't even get the cover off cause the bolt is keeping it in place. I had to remove the water pump so I can access the hole easier but I'm unsure of how I should proceed. I might get a nail the size of the hole and hammer it a couple times to make a center indentation and drill the remains of the bolt down to the top of the crank case so I can get the cover off at least. It is so deep & small and it is impossible to see if you are drilling on center.
I'll post pictures tomorrow.
HighSideNZ, 4/1/2021 at 4:32 PM
I really wish I saw your reply before doing what I did cause now I'm really fucked & I don't know how to get this thing out
You cannot "stack" helicoils as they will never line up perfectly. You will need to drill the bolt out with a cobalt left hand drill bit, and remember to run your drill in reverse. Yes, some sort of center punch will help, and if it is too skinny, then wrap it with masking tape tightly and evenly around it so it fits snug in the bore.
https://www.ebay.com/itm/283884915096?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=283884915096&targetid=1068323850910&device=c&mktype=pla&googleloc=9032190&poi=&campaignid=11614425263&mkgroupid=114834261282&rlsatarget=pla-1068323850910&abcId=9300456&merchantid=8047204&gclid=EAIaIQobChMIpeOVkIj_7wIVwRt9Ch2mJA5tEAQYHCABEgKp5PD_BwE
I might be able to help you get that out and get it fixed. Where are you in the Bay Area? I sent you a PM....
RC1237V, your generosity is only exceeded by..........the magnificent bike you ride! :fing02:
I have reverse drill bits, as well as a special 6mm broken bolt drill that can thread on a stud, in a tapped hole, or the correct sized bore....
styran, 4/13/2021 at 6:45 AM
Don’t panic mate - it’s fixable.
This is what I’d do if it were mine:
1. buy a new shifter cage thing (not sure what it’s called?) off eBay. Looks like this one from a 6th gen and very cheap...
[image: ABE3C261-E78D-4723-AABE-F09E2777241D.thumb.png.c0324a68e60df722df0b89840a74e69b.png]
2. Remove clutch slave, speedo and sprocket cover. Get everything off and out the way
3. Remove all bolts so only the broken bolt is left holding your “shifter cage thing” on
4. take a Dremel or angle grinder and CAREFULLY cut around the bolt hole where the broken bolt resides. The rest of the cage should just pull off as it’s only held with dowels. DON’T CUT INTO YOUR ENGINE!
5. if you’ve done it right the only thing left should be the broken bolt and the piece of cage it’s stuck in. Now just grab it with a pair of pliers and unscrew it off.
It’s very easy this way. Plus, you’ll have access to rethread the stripped hole properly with everything out the way.
If you don’t have a Dremel/grinder you could probably snap off pieces of the “shifter cage thingy” with a pair of stout pliers. These cast aluminium pieces are very brittle.
You may also want to buy a new bearing for the shifter shaft whilst you’re in there. Also very cheap.
Have fun!
Stray
Drove up and met Styran this morning and helped him out. Very nice young man with great curiosity, and intuition for mechanical things. Great to see that, as it has become rare these days.
Turns out he had also snapped an extractor off in the bolt, trying to get it out, and those things are hardened. We were able to eventually get through that with some diamond dremel bits, and some patience. Then I was able to drill the remaining tip of the bolt and get it out with an extractor. Finally I was able to remove the old heli-coil. We cleaned, re-tapped, and cleaned the hole again. I had him order a longer heli-coil from McMaster Carr, so he will get full engagement. So far so good, and it looks like the repair should be solid.
Great effort and write up RC1237V. Styran is very fortunate to have someone with your expertise go out of their way to help him out. VFRD at its Best. :fing02:
1 hour ago, RC1237V
I'd give this post 3 likes if I could . . .  Well done!
Awesome job!!! 👍🏼
This reminds me of teenager who brought in cylinder-head to my shop with broken-bolt wedged in real tight. It also had broken extractor and TWO broken drill bits in there!
RC1237V, 5/1/2021 at 4:28 PM
[image: 20210501_095521.jpg]
[image: 20210501_095526.jpg]
[image: 20210501_095646.jpg]
I put the new coil in and it holds up great. Now I'm just praying I don't get any oil leaks.
I managed to get the engine running again and I'm getting close to getting it back on the road.
Thanks again for your help, advice, and generosity
RC1237V, 5/2/2021 at 12:28 AM
This is why I love this forum. Guys like RC1237V helping a fellow rider. Good on you mate - really proud to be on the same forum as you!
DannoXYZ, 5/2/2021 at 8:39 AM
Awesome job!!! 👍🏼
Oh my - that sounds like a mechanic’s worst nightmare. Bet you regretted opening the shop that day!
4 hours ago, styran
So please for you, Styran. Looks like you have a pretty good handle on mechanics and also the maturity to know when to ask for help. Even the world’s best get it wrong sometimes and it takes guts to ask for help. Well done getting this over the line!
Awesome that you got this fixed, it was starting to sound like a real nightmare. As HighSideNZ said, do it once and do it right. I hate HeliCoils more for the opportunity they provide for misuse, and also prefer Keensert type inserts for their longevity. I routinely have to fix Helicoiled holes, and often the problem isn't the original Helicoil install but the fact that the next person that touched it felt Loctite was necessary, and then the person after them extracted the helical with the bolt it was now bonded to.
  :beatdeadhorse:
17 hours ago, styran
You're welcome! Looks like it will be done in time for the good riding weather!
End of thread · 34 posts recovered Wayback Machine snapshot 25 Jun 2021
