Hi
i own a VFR800X 2013.
it’s had a few owners, and has covered 12,000 miles, 2,000 miles in my hands.
modifications done:
1: pair valves disabled and blocked, air box bunged.
2: flapper valve disabled / disconnected
3: arrow end can ( all done by first owner )
4: O2 eliminator fitted, exhaust plugged. ( by me )
5: Previously fitted K&N air filter (clean) and new spark plugs ( by me )
6: Hyperpro shock and fork springs ( by me )
7: Handlebar conversion to Renthal bars ( I just hated the plastic shrouds )
previous owner also balanced starter valves, no idea how well, but other work seems competently done. Bike sounds fine, nice even beat when warm and the fuelling seems fine. Smooth even power delivery, no hesitancy or snatchiness.
I was getting 6.1 miles per litre commuting in London ( heavy traffic )
The exhaust also smelt very rich at start up. Lots of white steamy clouds in winter temperatures.
I recently fitted the O2 eliminator as the O2 sensor looked very sooty in the hope it would address the rich mixture.
I then got 8.1 miles per litre. Happy days.
It has since started heading back towards the previous figure. Now at 6.8 miles per litre. The weather has improved, so some of this might be happy throttle related.
I’ve run seafoam in the tank twice also, in case it cleans up the injectors.
My questions are
1: What is a normal fuel consumption figure for this engine when city commuting?
2: If its uncharacteristically low, what might be causing it? I don’t drive like a madman.
3: Where is the fuel pressure regulator on this bike? It’s not on the fuel rail, like on previous models.
4: could it be the MAP sensor or thermostat?
5: could it be a dripping injector issue and they need ultrasonic cleaning?
6: am I chasing ghosts and these engines are just very thirsty 😉
thank you for any help or information
