I have a '98 VFR which has been sitting for a few years (job, kids, overseas assignment....).
Have done careful bootstrap (new battery, drained all fuel out, oil/filter change, little bit of oil in cylinders, manual turnover... all good so far).
Put in a gallon of fresh gas. Starter is turning it over easily but it's not firing. I'm assuming no fuel, but I'm guessing.
Seems like connectors to the fuel pump are getting voltage when I turn it on (2 sec of 12v, then drops off which I've read is the right behavior? IDK).
I'm not hearing any sound however when I switch it on, which from memory... I remember I'd get a short whine of the pump priming the gas when I first turned it on.
Does the pump just gum up and totally stop working if it has sat for years? Is the next step to replace the pump and filter? Anything else I can do/test before throwing money at it?
Anyone with more smarts to me know what a next step is? 🙂 I hate to just start replacing stuff but that's kind of where I'm at.
Yes, you should hear the Fuel Pump prime for aporox 2secs every time you turn ignition to on.
Unplug the electrical connector to the pump, take note of which terminal has the Green wire.
Make a couple of test leads and connect these to your battery. With the ignition switch to off, carefully touch the other ends to your fuel pump terminals, negative to where the Green wire went.
If the Fuel Pump doesn't run then you'll need a new one.
If you hear the Pump running. Then you need to confirm the Green wire for the pump connector is properly Grounded and the Brown wire you have solid 12v for 2secs at switch on. Make sure the pump terminals and connector are clean and make good contact with the pump connections, even a spray of WD40 into the connector might help.
There certainly appears to be a lot of crud around the fuel filter in your photo!
Don’t write pump of just yet. Remove and with a pick tool give rotor a push.... see if pump spins after that. Another thing to check is wiring downstream from the connector. I had a terminal broken off once on a different bike....
Agree Magneto, but could you ever trust a pump after needing a push start!
The pump is 23 years old, assuming its the original, and the crud around the fuel filter isn't good, who knows what the pump has ingested over the years along with years of non activity, potential condensation and bad fuel.
There are excellent Japanese built non OEM pumps out there that are not too expensive.
If it were mine, I'd ditch the pump and filter, give the tank a good clean out, then fit a new pump and filter.
Pumps get stuck because of crud, once unstuck and flushed should be as reliable as any 23 years old pump. Replacement is a nice option, but why stop at the pump whole bike is a museum piece 😉
Prices for Japanese armature are plain crazy. Trim motor just took a dump on my outboard the other week, 600 bucks from Suzuki. Damn Showa. We are being taken advantage off....
I pulled the pump, and it looked rotten, so I just ordered a new kit from Quantum Fuel. Aftermarket pump and filter was $130. OEM was looking to be over $400....
Downside was the wiring didn't match so I needed to splice in the new wiring.
Anyway, below are old pump and new pump photos.
I am having trouble with the pump/tank seal. I've tried less torque, more torque, swapped for the old seal (it was in great condition), and just tried some Permatex PermaShield fuel resistant gasket dressing on the gasket... it still has a small leak so I'm letting it dry more before trying to tip the tank over again. (I let it set for ~45min before trying it... too short?)
Anybody have experience getting this seal to, well, seal? [image: :)] When I turn the tank over to remount it, it starts dripping fuel.
Thank you!
BTW, advice for whoever finds this looking for fuel pump solutions: you should also order 12mm crush washers for the banjo bolt. You aren't' supposed to reuse crush washers. This cost me an extra day once I realized.
