Exhaust Gaskets
5 posts Started 1 Aug 2022 Last recovered post 1 Aug 2022 Wayback Machine snapshot 1 Feb 2023
Hello everyone,
     Its been a while since I pulled the old VFR apart to start my project, I am fitting the exhaust back up, but I had removed and disposed of the 2 graphite exhaust gaskets that go in the join between the rear header pips and the rest of the collector, behind the RH footpeg.
I need to buy some more, anyone got a link, or got the dimensions so I can source them please?
Hi Coxylaad.
Is this what you're referring to Item - 13?
Partzilla.com shows them as in stock.
Part No.18392-MK4-000.
[image: IMG_1502.PNG]
yes number 13. do you know dimensions of them?
Bit of a Google showed me this.
Would I be correct in guessing the dimensions given are in the order of ID, OD, Height. Which would mean a wall thickness of 3mm?
[image: 20220801_190044.jpg]
End of thread · 5 posts recovered Wayback Machine snapshot 1 Feb 2023
