Yep. Battery voltage at the bl/w wire to each coil power to the ICM and earth continuity from ICM earth (solid green) to battery.
There is output from the pulse generators at the close connector and continuity of output from the pulse coils generator signals to the 16 pin ICM connector.
I'm stumped/flummoxed/bamboozled and bewildered. Sadly I don't have access to an oscilloscope so I can't check the quality of the output from the pulse generators but as it's function is to let the ICM know when to drop the connection to the coil energising the secondary winding -> on to the spark-plug there should be something even if the secondary clutch is 120degrees out ( yes, ultimate straw clutching time )
There is nothing at the fuel cut-out relay (the pump runs on a bypass wire) but there is continuity from the No4 coil to the relay.
Unfortunately I don't have access to a known good ICM but it is increasingly looking like the fly in the ointment.
A long shot I guess, but is there any chance your plugs are fouled.
- Have you tried different plugs and have you confirmed the plugs are the correct type?
- Are the high tension leads in good shape?
- Are the two primary connections for each coil making a clean and tight connection?
- Have you tried unplugging the Fuel Cut Relay just to see if this has any effect on spark? Just wondering if there is some fault with this device that may be killing/loading spark output.
- And you have definitely confirmed that the Ground signal from the Neutral Switch is seen at the ICM - Yes? (Essential for Ignition enable.)
On a side note. I can't see how the original R/R failure and melted wiring would effect the ICM. UNLESS the R/R had overvolted.
Grasping at straws!
End of thread · 6 posts recoveredWayback Machine snapshot 22 Mar 2023
