[image: gallery_11167_3051_26002.jpg]
Harness side of RR Connector Block
I don't know what is going on with Ken's old harness but I decided to checked out the RR input to the harness on my '02 (with a mulitimeter).
I checked the continuity and resistance of my harness from the RR back to the battery. I also wanted to know where the White/Black wire went - did Honda crimp it onto the red wire 8 inches away?
When you pull the RR plug to the harness apart, the picture you see above is the part that feed into the harness. Reference that and what you read below and you'll get it (I hope). This is what I found...
(Note: to be accurate the red wires are actually red with white stripe)
Battery Disconnected:
Green to Green = Continuity (0.2 ohms)
Red to Red = Continuity (0.2 ohms)
Reds to Pos Battery Lead = Continuity (0.3 ohms)
Greens to Neg Batt Lead = Continuity (0.2 ohms)
White/Black to Red = No Continuity <--- Kills the "Ken's harness" on my '02 theory
White/Black to Green = Continuity (1.0 ohm) <--- WTF?
White/Black to Pos Batt Lead = No Continuity
White/Black to Neg Batt Lead = Continuity (0.8 ohms)
Battery Connected - Key OFF:
Green to Green = Continuity (0.3 ohms)
Red to Red = Continuity (0.3 ohms)
White/Black to Green = Continuity (0.9 ohms)
White/Black to Pos Batt Lead = Continuity (-153.2 or infinity if leads are switched) <-- Like a diode?
Battery Connected - Key ON (bike not running):
Green to Green = Continuity (39.6 ohms) <--- WTF? Grounding issue with power on?
Reds to Pos Battery Lead = Continuity (4.3 ohms)
Greens to Neg Batt Lead = Continuity (one shows 18.3 ohms the other 59.3 ohms) <---this is Odd but answers the above 39.6 ohms resistance
White/Black to Red = Continuity (-53.0 at 200K and if I reverse the electrodes and I get infinity)
White/Black to Green = No Continuity
White/Black to Neg Batt Lead = Continuity (-153.2 or infinity if leads are switched) <---Diode?
Conclusions:
1. I have good lines to the battery (there is continuity and little resistance at least with the key off anyway);
2. I have a good ground (again, at least until I turn the key on)
3. There is no way my Regulator/Rectifier Black/White monitor wire is DIRECTLY connected to the Red wire 8 inches away (aka Ken's setup). Mine is going through something - probably the ignition and start switch as per the wiring diagram.
4. I even checked the diode as per the service manual (page 19-18) and it checks out OK. AND if you ever want to get into your forward fuses under the left (ABS stuff) and right (lights etc) meter panels you DO NOT have to remove the upper cowl as the service manual says. Thankfully ScottyDo has some pics on how to take the left or right meter panel off - as well a very cool blue light mod. It's the little things like removing these panels for the first time that drives me nuts.
Surprises:
1. That the White/Black to Green ground (and Negative Battery terminal) showed continuity and very little resistance with the key off - I need to look closer at the wiring diagram.
2. That resistance goes up on grounds with key ON - There is something going on here I think. I don't know why a ground would be fine with no power applied but show resistance with power on. Any thoughts?
I have also been looking at the RR upgrade wiring job some people are doing. Chris had mentioned that you would want to reduce the fuse size if you bring all the wires back to the battery. I agree. All you have to do is imagine a short on one of the three wires. All other wires will begin to "feed it" until the amperage begins to blow fuses. I'm no electrical engineer but to me, if you have three 30 amp fuses each on their own wire, you might as well have one 90 amp fuse on one wire.
I also think that there has to be a "cleaner" way to set this up so that there are not so many fuses piled up back at the battery.
[image: gallery_11167_3051_28948.jpg]
Stock RR and Suggested Rewired RR
PS - I never put in Chiris' extra ground mods - but at the moment I think they are a good idea.
chris2992Here is the wiring diagram of what I did. You won't have the Kriss Amp-U-Tron in line, but you can mearly cut the main feed to the battery and splice in an extra wire to boost charge to the battery.[image: gallery_4338_1246_52340.jpg]
Wiring Upgrade New + Wires in Red, New - Wires in Green. All wires used are 12ga high strand.
Keep in mind that when you have the extra wire coming directly from the RR to the battery, and you add a second 30a fuse, you then have on the bike side of the battery, 60a of potential. To prevent this you may want to change the 30a fuses for 15a or 20a fuses so as not to have such a huge potential in case of a dead short.
Edited June 7, 2007 by talus
