Stator Tests
127 posts Started 24 Jan 2007 Last recovered post 3 Mar 2021 Wayback Machine snapshot 18 Sep 2021
I have been having lots of problems tring to figure out what is wrong with my charging system. Thought it was the RR, wasn't. Thought it was the battery, wasn't. Thought it was the wiring, wasn't. Thought it was the stator, wasn't ..................... But wait, maybe it is.
Lets get all the facts on the table.
Battery Voltage = 12.3v
Charging voltage at Idle = 13.2v
Charging voltage at 5k rpm = 12.1v and lower as time goes on.
Resistance between battery ground and frame ground = 0.1 ohm
Resistance between all 3 legs of the stator = 0.3 - 0.4 ohm
Continuity between all 3 legs and ground = none
AC voltage from stator (with rr Unpluged) at idle = 19.6v
AC voltage from stator (with rr unpluged) at 5k rpm = 65v
AC voltage from stator (with rr pluged in) at idle = 11.2v
AC voltage from stator (with rr pluged in) at 5k rpm = 4.2v
DC voltage at the battery side of the +/- rr Connector = Identical to battery voltage (Bike off = 12.3v / Bike running = 13.2v @ idle, 12.1v @ 5k rpm)
DC voltage at the RR side of the +/- RR connector (connector unpluged, measured directly across the red and green wire) at idle = 0.9v - 1.1v
DC voltage at the RR side of the +/- RR connector (connector unpluged, measured directly across the red and green wire) at 5k rpm = 0v - 0.1v
Static tests of the stator, it checks out fine. However, under a load it seems to show its failure. Also, something that I have noticed is that as the bike warms up, the problem gets worse. Is this normal, and is it the stator, or possiably the flywheel.
is that correct , i was thiking it should be more like 1kohm between the wires, but I could be wrong
if you charge the battery will it charge to 13 volt , and sitting idle for couple hours still hold above 12.7, if it wont that's a weak battery
Battery is brand new, My battery tender holds directly at 12v. I had just taken it off the tender, so that explains the low voltage.
As for the resistance between the legs, honda says that it should be between 0.1 - 1.0 ohm.
chris2992Battery is brand new, My battery tender holds directly at 12v. I had just taken it off the tender, so that explains the low voltage.
ANY charging system for 12v, charges at least 13.6v and your charged battery should read at least 12.6v. so i am wondering as to the condition of your meter. as for heat affecting readings, MOST DIFFINATELY. the R/R spends most of its life cooking off extra amperage. heat is what kills the R/R. the stator can be over heated also. a cold stator can test fine but when heated wires may be shorting within that loop causing low output on that leg and not show any reading to ground. you certainly did your homework and complete checks. not cheap but i would change both R/R and stator. best..........
When i had my epiphany about the wiring last weekend, i didn't mention something because most people don't have one.
There is a device called a megger, this an ohm meter that outputs high voltage and alot more current than a simple multimeter. The multimeter is fine for 90% of checking, the megger will help to find bad continuity where a multimeter will not.
I would venture to say it is still a wiring issue, unless you have soldered all connections and totally cleaned your grounds.
chris2992I have been having lots of problems tring to figure out what is wrong with my charging system. Thought it was the RR, wasn't. Thought it was the battery, wasn't. Thought it was the wiring, wasn't. Thought it was the stator, wasn't ..................... But wait, maybe it is.
I started the other thread on 5th gen charging problems a couple of days ago so I'm interested in your results. At first, from your description I would have thought that you had a second bad rr given that your voltage from the stator seems good until it's attached to a load but I found this snippet of information on a BMW site. It originally came from the Electrex site but doesn't seem to be there any longer and coincidentally, refers to VFRs! Anyway, after reading it, I think you should replace your stator and unfortunately, possibly your your rr as well as it appears that a failing stator will take out the regulator. Here's the quote.
<<VRF Regulator Rectifier Basics
Inside there is a six diode full wave rectifier, and every phase input can be switched to ground through a thyristor. The thyristors are switched by a regulator circuit that measures the DC output voltage. We call this a shunting regulator. It is a very simple system, and doesn't work very efficiently. But it does the job while not dissipating too much heat. That is why most OEM manufacturers still use this setup.
First of all the regulator relies on it's heatsink. That in itself is not bad , as long as there is good thermal contact between the diodes and thyristors inside the unit to the housing, and as long as there is a good airflow.
Quite often when a regulator/rectifier fails, a new one will fail after a fairly short time. It is a recurring problem (not on all bikes, but has been seen quite often). The stator has 18 poles, 6 per phase. Each pole has (I don't know exactly) about 20 turns of copper wire on it. Between the phase outputs of a delta wound system you will have 120 turns. Because of the hot spot in the engine, the copper winding's insulation starts to fail after some time. Most likely that will be somewhere from one layer of windings to the next layer on a pole. This usually happens only under load and when the unit is hot. Imagine a few of these shorts in between the phase outputs. You will have not 120 turns but say 50 or 60. The complete charging system will still be able to reach 14.4 V DC, it is rated for about 400W.
When you have a transformer with only a few thick windings, you will get a low voltage but higher current output. The same happens in the VFR Delta stator. Those 60 turns will give a much lower Vac but a much higher Iac. And diodes in regulator/rectifiers don't like high currents. If they are rated for 35 Amps, as most diodes are in this application, they can handle that whenever they get sufficient cooling.
When they run hot, the max current they can handle drops down quite a bit, which makes dissipate even more heat, and finally one of the diodes fails! Electrex stators are wound in star. The total power output is about the same as the original (lower Iac times higher Vac makes about the same... I know this is simplified, there is more to it....). But there are always two phases in between the phase connections. (=240 turns) The Vac is higher, and the Iac is lower. Even if there would be a short in between some layers of turns (I haven't seen that happen) you still wouldn't have the current output of the original stator, which is what destroys regulator diodes.
So far this is still unproven, but seems correct. It is difficult to prove, as you need to check the original stator for shorted windings whenever the systems is under load, and very hot. And it doesn't need to do it all the time even! Bikes that have had a few failing RR's stopped frying them after replacing the stator.
One last thing:
Problem #3:The output of the Voltage Regulator/Rectifier (VRR) is fed through the wiring loom and some sort of junction box to the battery. Make sure you have perfect connections here. I found a number of problems with voltage drops over these lines. Check the fault finding chart on http://www.electrexusa.com. It will guide you through the process. The best thing to do, if you see any voltage drops in between the VRR and battery (we are talking high current here, so any bad connection will give a significant voltage drop) is to feed the output of the VRR straight to the battery terminals using a (good quality) inline fuse.>>
Hope this is helpful to everyone.
Just had mine in to the dealer for a couple of issues. One was I pointed out that 30A main fuse/holder looked burnt. When he checked my elect. system he said my RR was bad. Replaced under extended warr'ty. He then check voltages off/idle/ 5000 RPM etc. and they were stilll a little low. He ended up replacing both main cables/harnesses to the battery neg & pos.. This brought up to spec. the voltages.
Good luck.
Mark
Thanks Cooter. I have heard bad things on eletrex products, so I won't be using them. But You saw where I had spoken of Ricks Motorsport Electronics, I am going to call their CS office today and speek with them about my problem and see what they have to say. I'll probably just have them re-wind my stator and possiably run some diagnostic tests on my rr.
chris2992Thanks Cooter. I have heard bad things on eletrex products, so I won't be using them. But You saw where I had spoken of Ricks Motorsport Electronics, I am going to call their CS office today and speek with them about my problem and see what they have to say. I'll probably just have them re-wind my stator and possiably run some diagnostic tests on my rr.
I too, haven't heard great things about Electrex and wasn't suggesting their products. After reading your post and having my own issues, I really started digging around to try to learn how exactly the various components of the charging sytem worked. There is a fair amount of information out there (I was searching motorcycle voltage regulator design). The article I quoted was the first explanation that made sense as to why a stator would test OK in one circumstance and not another or in my case why the stator shows low output but continues to function in the system (it is failing slowly). I ran across another tech article from an old bike magazine that said that this type of charging systen design is so flawed (the 2 piece design of a stator mounted off the end of the crank relying on oil for cooling and a seperate rr) that it really can't be expected to last much more than 20,000 mi. It is still in wide use on sportbikes because of it's cheap to produce, light weight and compact. Here's the link www.reptilesmagazine.com/mcn/technical/MCNdec05charging.pdf
Don't ask me why it's in a Reptilesmagazine link, the page says it's from Motorcycle Consumer News, ah the mysteries of the internet! Please post your outcome with a Rick's rewind.
I am more concerned with the voltage dropping from idle to 5k rpm! That would indicate a bad RR! If you really concerend about the Stator take the thing out of the engine case and inspect it, I had one fail - deep fried it! My engine overheated once cause the fan wasnt working, that contributed to the stator failure. Mine was pretty bad!
http://www.vfrdiscussion.com/forum/index.php?showtopic=3016
Mr.RC45 shows the same voltages at the same rpms... I've gone through extensive trouble shoot procedures and even changed the R/R twice and stator once... no joy... I'm not so hot when it comes to electrics so I'm watching the thread... right now I can't go 3 days without a external charge... it will just quit running...
Edited January 24, 2007 by BusyLittleShop
The RR is the new upgraded honda part, and it is around 3 months old, and only 1k miles. So I doubt it to be the issue. Battery is brand new, so I'm doubtful that it is the problem. I can't Understand how it might be the RR, when the stator tests out voltage wise unloaded fine, but under a load, very week. But on the same note, I have never seen a stator fail quite like that. Who knows, I am going to send my stator and RR to ricks for diagnostic testing, hopefully they will be able to make things right.
BLS, when you replaced your parts, did you use OEM, or aftermarket? Also did you check the flywheel, I have seen notes on the flywheel actually going bad, unlikely but possiably.
chris2992BLS, when you replaced your parts, did you use OEM, or aftermarket? Also did you check the flywheel, I have seen notes on the flywheel actually going bad, unlikely but possiably.
With so few examples world wide there are no aftermarket parts for the RC45... all the parts are OEM... I've swapped flywheels with another RC45 in my shop... still no joy...
Well, stay tuned then, I'll post my results from Ricks as soon as I have some. Probably be about a week.
chris2992Well, stay tuned then, I'll post my results from Ricks as soon as I have some. Probably be about a week.
just curious if you checked your three way diode? (looks like a fuse on front of fuse block but has three prongs) i do not kow what the result would be with a bad leg or if it was toast. its purpose is to change your ac generation to dc but if part of it was bad?????????
I've ordered a new stator and RR (OEM from Honda) and am going to wire it all directly to the battery using Weather Pack disconects and No. 10 sxl wire with a dedicated 40 amp fuse holder, I'll dialectric grease all connections and use thermal paste in mounting the regulator. If I end up with the same voltages then I'm going to call it done and carry the old rr under my seat as a back up. I'll report the results when I'm done.
I sure appreciate you boy's situation. I've got the shirt and box of NFG Honda electrics as well . I've had 2 stators fail and a "few " RR's . The typical mods (fans, conductive paste , and improved wiring )improve things but it leaves a definite mental scar. My stators were fine static but failed under load. I had a damn RR that I could NEVER get to fail within 40 miles from home - just get the other side of Rockspring though .... More then once nearly leaving the pavement staring at a stupid meter. Even today if I glance down at my ODO and I don't see a tenth click off in a couple of seconds the paranoia skyrockets ( as we know the odo is the first instrument to no go as the V decays.) I recently did a roadtrip without a spare RR - felt like a hit man w/o his piece. I've come close to selling this great bike a couple of times over this - I was brought up on Yamahas.
I am giving no usable input here - I'm sorry for that. But on a positive the last time I went through the "Triad of Ballbreak" disfunction was on my way to the Gap. The Tenn Trooper helped me get to the right place, and Mark (last name ?? ) owner of Cooksville Honda and his crew went out of their way to get me rolling ASAP and at a VERY fair price. I wasn't worried - worst case scenario would have been me smashing the bike to a pulp and throwing the VISA down on a spiffy RC51 - I was going to the gap by damn !
I just hope Soichiro H ( the exalted one ) kicked that no good number ten son in law in the electric division around the shop a few times before going to that big dyno in the sky.
non illigetimi carborundum, mates
DuckeaterMy stators were fine static but failed under load.
Did they fail with results similar to mine? Or what fassion did they fail?
khyronWhen i had my epiphany about the wiring last weekend, i didn't mention something because most people don't have one.
I check my connections occasionally also, like you said you can loose 1/2 volt very easy with bad connection. I ran a charge test yesterday as a normal maintenance probe. Battery at 13.2volt, running at 1500 rpm 14.77volt
That looks good
Had same problem; everything checked out but charging pattern was the same as yours. Finally pulled the side cover and found stator was cooked, very dark brown on some windings. Changed stator and all has been happy. I use a late model R1 rr as the honda ones are ridiculous expensive. Good luck...
Pulled my stator tonight. UMMMMMM, I think it is fried, looks like it was half way in a deep fryer.
Fried Stator This is what a bad stator looks like!
I'll be sending it off to Rick's on Monday. Report coming.
Mine looked like that, too (as has everything other one I've seen here). Yet my brand new replacement from Honda actually lost me a few tenths of a volt, so don't be surprised if it checks out.
chris2992
R was good static, E was in spec running, the I under load was the prob. Ignore the hot oil discoloration - anectdotal.
I worked as an Electronic Tech for the Coast Guard and you are right about the megger. But the megger would be a poor application for the VFR. It is used to test high voltage/current wiring systems and would most likely damage components of the VFR with the amount of output it shunts per run. For what the VFR is designed for a good multimeter (such as Fluke) is all you really need. Of course, if you found a low power version of the megger (IE under 30 amps/20 volts) you could always go that route but it would still be over kill. That's just my opinion though. To each their own. :thumbsup:
yea yours looks as bad as mine did, mine would rear its ugly head when it heated up! melted or exposed wingings just expand or become so resistant at temp that they no longer function when they get hot! However once cooled operate well enough to fool a test!
Mr.RC45's stator was this discolored at 45,000 mile mark... replacing it with a new one didn't produced any more volts... it's possible that my old dark brown stator is still good...
[image: gallery_3131_51_4013.jpg]
Well to be sure the color is not the problem, mine had a ground short in one of the phases, definitly melted a wire to the stator body!
Just to throw a curve ball into the mix here. I have a 6th generation. Last June, I live my house, drove for about 15 minutes an stopped at a store. Get out, turned the key on, put my gloves, and tighten my helmet. Push the start button: 2 revolutions then click click click. At that point, I have no intention of buying a new battery, so I do everything I can to keep on running until the season ends (October). At that time, I was convinced my battery wasn't holding its charge. I would come home, start it a few times, and by the 3rd try, it would be dead. No testings, just "hands on trial and error".
So, remember, I don't want to replace the battery, so I do everything I can to keep the charging system working as little as possible to keep the battery fully charged at all time: No more high beam during the day (I like having h-beam on to be more visible), never let the key on for an extended period of time. keep my hand and foot off the brake to avoid having the brake light come on. Put the charger on the battery once in a while. I did that religiously.
Not only did the battery last the whole season, it is still good today. At Xmas, a friend of mine wanted to here my bike running. I hadn't charged, nor started the bike for 3 months. It is near freezing temperature in my carport. I Push the start button, the bike fired up after a few revolution, then died, I restarted it, and it ran beautifully.
After reading was Cooter posted, and my own exerience, I think the charging system on most motorcycles is marginal at best. Adding accessories (heated grips and vest, GPS etc), keeping the high beam on, running the bike at low revs might just be too much.
When this happen to me, I was also thinking my charging system was failing. I had similar problems with 92 Fireblade, which I was running on highbeam at all time. Now, I believe that the charging system is weak to begin with, and there is nothing that can change that. I need to work around it.
bump bbbump bUUUUMMMMP!!!!!!!!!
There is no problem with running the high beam for long periods provided you don't over draw the amperage from the Stator. As soon as you quit charging the battery and and pulling voltage directly from the stator and RR is when you have a problem. The only way you will know if you are doing this is to install a Volt and Ampmeter. I have one, and when my stator was working fine; High's, Heated grips on High, cellphone and Ipod charging, I still had 9 amps charging the battery. Your bike has something wrong, but untill you get out the trusty multimeter you won't know whats going on.
sunlineHad same problem; everything checked out but charging pattern was the same as yours. Finally pulled the side cover and found stator was cooked, very dark brown on some windings. Changed stator and all has been happy. I use a late model R1 rr as the honda ones are ridiculous expensive. Good luck...
I got an r/r from an 05 r1 off ebay about a year ago for $35 bucks wired it up and has been flawless so far. Haven't heard much from the Yamaha guys having trouble have you?
Edited February 9, 2007 by original007
BusyLittleShop
I went riding today and now I have the same voltage readings.
I have 13.2 at idle, then voltage drop as RPM increases. It does seem to go back up to 12.7 when I reach 7000 RPM, but it is not steady.
I need to fix this as I find it dangerous paying too much attention to the voltage meter and not the ride.
I have replaced all three components last summer when I started having the clock reset to 12:00. :unsure:
This is all very interesting. I went through a RR failure last summer on my 98 vfr. It had the newer version already, but failed anyway.
There were a number of things I learned then;
1. Just because a battery tests bad doesn't mean it is.
2. Overheated appearing stator wires may well be the result of too high current coming from a partially shorted stator winding.
3. Good voltage doesn't mean good charge.
1 relates to the Yuasa battery that tested very poorly after charging and then testing the float voltage. I bought a Battery Minder that desulphates and the battery has not yet needed replacement. It started the bike today after sitting for 3 weeks in freezing temps. The float reading is very good at 12.6 volts.
2 is straight forward but often overlooked. A bad connection merely ups the resistance and in turn lowers the carrying capacity. If it's cooked at the connector, check for bad connections or bad crimps, if its more general it's probably too much currnet from a partially shorted stator.
3 is more of a phantom. As has been pointed out voltages vary. They vary a lot on 5th Gen VFRs. You might test in the shop at some acceptable level but that doesn't mean you get it all day. I suspect a similiar rule applies to newr VFRs. A voltmeter permanently mounted is best. Lastly, grounds, grounds, grounds. OK, all connections are suspect.
Now I'm left wondering if anybody uses the Electrosport Products.
These seem like good products but are never mentioned here. I use the Rick's RR, so far so good. Might try these if I have need in the future.
They are said to use a modified RR system that regulates all 3 phases of output and not just two as the OEMs do.
Why do I suggest that? I read it here - GSResources
Ther is actually a decent description of rewinding your own stator in the articles.
I have heard bad things about electrosport products, AFAIK they are the same company as electrex.
Got a call from ricks this morning, my stator is done and on its way back. So far so good, I sent it to them on tuesday, and it is already on its way back in less than one week. Pretty quick turn around.
Redfish
BusyLittleShop
I have replaced all three components last summer when I started having the clock reset to 12:00. :wheel:
you have weak readings try cleaning all your contacts from stator and from rec red wire to battery and black ground wire,
Hi -
I saw this post and I would like to know what you think about my situation......
I purchased a interceptor VFR750 and have had nothing but problems.
First I thought it was the starter... Not...
Then I got a new battery... Seemed fine.
A couple of weeks later had to purchase another battery.
But come to find out that it drains the battery and then just stops completely!
Even when I am in third gear.. it will just stop working.
So I check my battery... dead as can be
These guys at a bike shop tell me it is the regulator and/or the stater!
The regulator is BRAND NEW!!!!
Why are they telling me I have to pay over $375 for new parts not including labor!
I may be a woman but I am not like most.... I do have brains and I do know mechanical stuff.
Still learning at this point about my bike!
Please help me .....
When I tested the wiring, the voltage is low that comes out from the stator.
Please reply..
Thank you Terrin
terrinVFR750InterceptorHi -
Please reply..
Thank you Terrin
Rather than reinvent the wheel, I'll here repost some good information from the UK VFR site about how your charging system works. Basically, your "stator" makes alternating current (AC), a/k/a electricity, it is sent to the "regulator/rectifier" (R/R) where the AC current is changed to direct current (DC) AND the voltage is "regulated" to something in the range of 14 volts. The R/R ties into your wiring harness and sends DC volts/amps into the battery, which may accept the charge if in good condition, or reject it, if the battery is failing or gone. If the R/R tries to stuff DC volts into a dying/dead battery, the power backs up and overheats the R/R, ruining it. If a new battery is forced to work with a dying R/R, the battery will overexert and die trying to run the bike, then you replace the R/R but if you don't replace the battery at the same time, the bad battery will kill the new R/R, and you start all over again. The stator can also go bad and/or have a bad connection to the R/R, but that is less likely. In any event, read the information below and let me know of questions. I'm sure others will come along with their input, as well.
What is the Voltage Regulator/Rectifier and what does it do?
The R/R is a little gizmo, a bit larger than a cigarette packet, that converts the AC output from the Alternator into a DC input for the battery - hence the Rectifier part of it's name. It also controls the DC input to the battery in a controlled voltage range - hence the regulator part of it's name.
History
The failure rate for this component on the '98 FiW and '99 FiX models is somewhere in the region of 70%. Generally, the failure of the R/R on the VFR gives an under-volt condition, i.e. it doesn't charge the battery. Mind you, there has been the odd, but much rarer, failure to the over-volt condition which boils the battery and can blow bulbs.
The failures are mainly down to the inability of the R/R to shed heat, which then fries the electronics in them. If you touch one after a ride, you'll find it quite hot to the touch anyway.
It is possible to fit a computer cooling fan to try and prevent the problem, but I think it merely delays the inevitable. An upgraded R/R is available for the '98 FiW and '99 FiX models with improved cooling capacity and has, so far, proved much more reliable than the original. The upgraded replacement is a direct replacement.
Luckily, Honda realised there was a problem and replaced the R/R on the '00 FiY and later models for one that's a whole lot more reliable. The later one comes with an additional voltage sensing wire, which means it's not a direct replacement for the earlier model, but it's not insurmountable to fit one if you want.
Symptoms
The usual symptoms of the R/R going AWOL in the under-volt condition are:-
1. The clock resets to 1:00 AM and the tripmeter resets to 0 miles when you start the engine.
2. The engine fails to start, this can happen even if was running a few minutes previously. Often when you've stopped for fuel.
3. The rev counter and speedo needle start to do "strange" things.
4. The bike may start to stutter and cut out.
The symptoms of the R/R failing to the over-volt condition can include:-
1. Blowing bulbs.
2. Boiled battery.
Things to check
Starting with the simple things:-
1. Check the battery connections are clean and tight. It's not been unknown for the connections to come loose.
2. Check the electrical connections to the R/R are clean. Sometimes they get corrosion in them, which ups the resistance and causes it to overheat. The overheating, in extreme cases, can melt the plastic.
If those haven't sorted things out, you really need to buy a multimeter. These cost less than £10 and will prove a bonus from here on in. If you're not confident in using one - read the instructions and practise getting DC voltage readings from it. Start practising with a little dry cell (1.5 volts) battery if needs be - we all have to start somewhere.
Warning:- Never, ever connect the multimeter to both battery terminals unless it's selected to the DC volts range. The resistance across the meter when selected to read volts is very, very high so it can measure the difference across the terminals without damage. The meter resistance when selected to amps is very, very low and would effectively short out the battery, possibly melting the leads and blowing the meter up.
Now we're moving into the nitty-gritty.
How old is the battery?
Anything over 3 or 4 years old and it may be past it's best. As they deteriorate, batteries can lose their effective capacity, i.e. they behave as a smaller battery, so, it may be worth doing a selection of load tests on it.
Battery Load Tests
As with many electrical problems, make sure the battery is fully charged. If the charging system is playing up, you've only got a finite amount of power available from it.
a. Off-load test - connect a voltmeter (selected to volts DC) to the battery and off load a fully charged battery should sit at about 12.7 or more volts. Even a failing battery can pass this test at times.
b. Low-load test - a low load test is done with the engine stationary and just turning the bikes lights on and taking a voltage reading at the battery. The battery should have at least 11.5 volts with the lights on.
c. High-load test - this is done when cranking the engine over on the starter motor. You should have more than 10.5 volts while the starting motor is cranking the engine.
If the voltages are appreciably lower than those values, the battery is probably on it's way out.
Replacement Batteries.
If you need to replace the battery, then get a recognised and quality make. For example, the Yuasa YTX12-BS is available from Halfords at around £50. Before you fit it to the bike, ensure it's been fully charged.
What model of R/R is fitted to your bike?
If you lift the seat and have a look just outboard of the LH subframe rail, just behind the cutout in the rear fairing you'll see a grey box a bit larger than a cigarette pack. If it's made by Shendingen (who make them for Honda) you'll see a number on the top of it starting with SH. If it's SH579A-11, then you've one of the original and gloriously unreliable R/Rs fitted. If so, then there's a good chance it's put up the white flag.
If the number on it is SH689DA, then you've got the upgraded item. As mentioned earlier, it is much more reliable than the original, but there is still the possibility of a random failure. Anything else is a non-standard or pattern-part R/R.
For what it's worth the '00 FiY and '01 Fi1 models had R/Rs with SH579C-12 on them which are much more reliable.
No matter which model is fitted, it'd be worth doing a charging system output voltage check.
Output Voltage Test
As alluded to already, the R/R fails when hot, but it can seem to recover when it's cooled down again. The ideal time to do this test immediately after a ride round, if possible without stopping the engine and remove the seat using the spare key.
1. With the voltmeter (set to the volts DC range) connected to the battery, at 4000 - 5000 rpm with the lights off you should have anywhere between 13.5 and 15.5 volts.
2. Turning the lights on could cause the voltage to drop by up to 0.5 volts.
Anything seriously outside those ranges could indicate the R/R is giving up the ghost.
Although Haynes specify the charging voltage should be 14.2 volts for the FiW/FiX models. It's nice if you can get it, but don't worry if you can't. For example, the upgraded SH689DA model regulates at 13.8 volts - chase the 14.2 volts and you'll be throwing a lot of serviceable R/Rs away.
Another oddment, is some people say the lights should get brighter when you rev the engine. That isn't necessarily the case. The SH689DA model can provide more voltage at idle (or slightly above it depending on what idle speed you've got set) than at higher revs, for example, the one on my VFR provides 14.2 volts at idle, but 13.7 volts at 5000 rpm.
Please be aware that multimeters can have slight errors between them. What one is reading could be very slightly different on another.
If the Voltage Regulator/Rectifier is unserviceable
Many thanks to Journeyman for this little bit of useful information.
Because the alternator is mounted inside the engine the heat from the engine could affect the insulation on the alternator stator windings. The insulation may even break down between the windings. This typically happens under load and when the engine is hot. You will still get a good output voltage from the R/R, but as the VFR uses a delta wound stator, the alternator will give a much lower AC voltage and much higher AC current.
I will warn you though, having received further information from Brain's, the following procedure may not conclusively prove the alternator stator serviceable or unserviceable. As Brain's reminds me, a multimeter doing resistance checks only uses a few volts, whereas the alternator at high speed may well be inducing in excess of 200 volts at high engine speeds - a much bigger test of the insulation of the windings. Therefore there is the real possibility that a multimeter will say everything is OK, but in use it may well not be.
To check the insulation of the alternator stator coils you'll need to do the following:-
1. Disconnect the R/R connection to the alternator - the one with the 3 yellow wires.
2. Select the resistance (Ohms or Ω) range on your multimeter and touch the two probe ends together. The readout on the multimeter will give you the effective zero reading - so if there is a value shown and your multimeter cannot be zeroed - as many cheaper ones can't be, you'll have to deduct this number from any further measurement.
3. On the three yellow wires coming from the alternator (not the ones from the R/R by accident) measure the resistance between each of the wires in turn, i.e. have one probe on the connection to one yellow wire, then touch the other probe to the connections for the other two yellow wires. So if one probe is one wire 1, place the other probe on wire 2 then 3. Then move the probe from wire 1 and put it on wire 2, then place the other probe on wire 3. That way all combinations are covered.
4. The resistance readings in step 3 should be anywhere between 0.1 Ohm and 1 Ohm - remember to deduct the resistance reading you got in step 2 from the values you saw in step 3.
5. Now test the resistance between each of the yellow wires and earth. There should be no continuity, i.e. infinitely high resistance, between any of the yellow wires and earth.
If the values in step 4 or step 5 are outside the tolerances, then there's a pretty good chance the alternator stator coils are knackered.
Replacement Voltage Regulator/Rectifiers
Use the upgraded OEM one. Electrex make one, but it's reliablity record isn't anything to shout about.
To get an upgraded OEM one at a good price, try David Silver Spares who do them for £55 (plus VAT and P&P), which compares very favourably with about £200 from a Honda dealer for exactly the same item, just look in "OE Regulator Rectifiers" on their site.
If you get the one from "Genuine Spares" area of the DSS site (£79 plus VAT and P&P), the extra money merely goes into buying a nice Honda box to throw in the bin when you've got the R/R out of it.
The cheaper one is identical, just supplied in a poly-bag. Also included is a set of longer bolts (the upgraded R/R is thicker than the original as can be seen in this link) and an additional aluminium heatsink.
Reuse the original domed nuts as these stop the bolt ends rubbing away at the nearby wiring loom. It can also pay dividends to put some heat transfer paste (available from outlets such as Maplins) between the R/R and the heatsink and between the heatsink and the rear subframe. That'll help transfer extra heat from the R/R into the subframe.
I'd tend to advise, if the battery is over 3 years old or of unknown history, replacing that at the same time as the R/R. A failing battery can over-work the R/R hastening it's failure.
The charging system voltage is OK, the battery load test voltages are good, the alternator resistance values are fine, but the battery still flattens quite quickly.
Now we're looking at the battery leakage rate. This is the current (Amps) the bike draws even though everything is turned off.
Ideally the leakage should be less than 1.2mA, but with an alarm fitted and armed it might marginally higher than that. It might be worth consulting the alarm instructions and seeing what current it draws.
You'll need to set your multimeter to the highest DC Amps range. this is to stop the meter overloading when it's connected. On some models of multimeter you'll need to change which connection the red lead goes to.
When set to read amps, under no circumstances connect the multimeter between the battery terminals, otherwise you could short out the battery, melt the leads and wreck the meter.
1. Disconnect the battery negative (earth) lead.
2. Set to multimeter to the highest DC Amps range.
3. Connect the multimeter between the battery negative terminal and the disconnected negaive (earth) lead.
4. Going down one DC Amps range at a time, reduce the range until the reading is sensible. Always start high to protect the meter from overloading.
5. The ideal leak rate should be below 1.2mA, but as mentioned above it may be very slightly higher because of any alarms/immobilisers, but not substantially so.
If the leakage is substantially higher than 1.2mA, try pulling and refitting fuses one at a time and seeing which fuse make the biggest difference to the leakage value when removed. This'll give you a clue as to which circuits are drawing too much current.
Real Time Charging System Monitoring
If you're concerned about the state of your charging system and want to monitor it without the faff of getting a multimeter out every time, there's nothing to stop you fitting a small voltmeter. I have a Lascar EMV1200 fitted to the Big Red Bus - my VFR.
Hope this little lot is of some use.
http://www.vfrdiscussion.com/forum/index.p...ectrical+system
See this thread, follow the instructions, create new topic and post results.
A bad stator could fry a battery and/or RR.
A bad RR Could fry a stator and/or Battery.
A bad battery could fry a stator and/or RR.
Before you start changing things, it is better to figure out exactly what the problem is. As you can see from this thread, it isn't always as easy as it seams.
i just started pulling out all the wires and checking the connections/connectors etc.
I found (it looks like a relay of some kind) yellow wire and a small harness with two wires.
The yellow wire has been sliced into a black wire. With the wires totally exposed but just wrapped with old tape.
I plan on going through the entire wire system and checking it all before I do anything else.
I figure that is the best place to start. At least I think it is.
Thank you for your reply.
Terrin
terrinVFR750Interceptori just started pulling out all the wires and checking the connections/connectors etc.
Terrin
in this case, soldering the connections will pay off in the long run, crimping connections just doesn't cut it.
Got my stator back today, and all I can say is wow. The rewind looks perfect. I shoot some pictures tonight and post them up. Will probably be Sunday before I can get it installed and tested.
But a big Thumbs up for Ricks Motorsport Electric, turn around on a rewind was only 8 business days from when I shipped it to them until I had it back in my hands.
Okay, I am an absolute idiot when it comes to Bike Engines. Here is the situation. Right before the summer ended, I was having problems with my bike getting really hot and dying while I was stopped at red lights. I would have to push it to the side and let it sit for a long while and then try to drop the clutch to start it. Well, come to find out, my battery was shot so I replaced it. No problems for the rest of the season. Just last month, I fired it up and let it run for a while. Turned it off and installed my graphics on it. When I finished, I noticed I had left the key in the on position and the bike would not start. Luckily, I live on a hill and just did the whole drop the clutch thing again to start it. I garaged it again and went out to fire it up a few days ago, but it would not turn over. It clicked a few times, but would not turn over. Any suggestions??? I do not have a battery tender and my garage is not heated. Do I just need a new battery??
Charge your battery. It is dead. Something is likely wrong elsewhere though, a battery won't cause the bike to over heat.
I see you are from Belleville, there are a few other members close, we will have to get together for a ride at some time.
chris2992Charge your battery. It is dead. Something is likely wrong elsewhere though, a battery won't cause the bike to over heat.
Sounds good....Once I get this problem taken care of. How hard is it to replace the R/R if it ends up being bad?
Easy, If you wind up needing some help, PM me and maybe we can get together so's I could lend you a hand.
chris2992Easy, If you wind up needing some help, PM me and maybe we can get together so's I could lend you a hand.
Sounds good, Thanks. I am going to check out the R/R this weekend. Anything to look for as far as it being bad??
Edited February 16, 2007 by Shak
ShakSounds good, Thanks. I am going to check out the R/R this weekend. Anything to look for as far as it being bad??
chris2992 http://www.vfrdiscussion.com/forum/index.p...ectrical+system
Follow that guide line.
[image: gallery_4338_1246_240360.jpg]
Stator Re-wound by Ricks Motorsport Electric. A+++++ Quality
[image: gallery_4338_1246_131933.jpg]
There is the rewind job. Looks great!! Stay tuned for a result post.
SO - how much of the "Brown" in the original post - was oil?
chris2992 [image: gallery_4338_1246_240360.jpg]
Looks like a damn fine job! :thumbsup:
None, It may have been burn't on oil, but after I cleaned it off in the sink (won't be doing that again, got yelled at) it still looked the same.
I am having the same exact trouble with my VFR750F ! What the hell is going on with these bikes? I have no idea what else to do but take it all apart and totally rewire the entire bike... Electic is not my cup of tea. Oh well... Good Luck to ya..
I said I would report back after I installed the new parts. Just to remind everyone, I was not having problems with the bike staying charged, just lower than spec charging voltage that would drop even lower, into the low 13's, as the rpms rose and was only showing 38 volts output max from the alternator. I also had the original RR. I had no signs of over heated wiring or connectors. I decided that I would go ahead and replace the stator and regulator proactively. My stator looked very similar to Chris' very toastie on the same side as his pictures show but it still tested OK except for low voltage output. After replacing the stator and RR, I am now getting charging voltages in the high 13' to low 14's with little to no drop on rising RPM and output from the stator of 50 volts and up, rising with rpm. I did do a little maintenance on connections but nothing that I would consider an A HA. I now firmly believe that much of the problem with these bikes starts with a failing stator. As the stator begins to fail under heat and load, it appears that the voltage drops and the current rises which then starts playing havoc with the rest of the charging system. I have posted references to this in my previous posts on this topic as well as a post on the general fraility of this type of alternator (stator) design. For those of you having multiple rr failures, I would consider replacing the stator. For the record, my bike is a 98 model with 24,000 miles and no history of electrical problems and hopefully, none in the near future.
CooterI said I would report back after I installed the new parts. Just to remind everyone, I was not having problems with the bike staying charged, just lower than spec charging voltage that would drop even lower, into the low 13's, as the rpms rose and was only showing 38 volts output max from the alternator. I also had the original RR. I had no signs of over heated wiring or connectors. I decided that I would go ahead and replace the stator and regulator proactively. My stator looked very similar to Chris' very toastie on the same side as his pictures show but it still tested OK except for low voltage output. After replacing the stator and RR, I am now getting charging voltages in the high 13' to low 14's with little to no drop on rising RPM and output from the stator of 50 volts and up, rising with rpm. I did do a little maintenance on connections but nothing that I would consider an A HA. I now firmly believe that much of the problem with these bikes starts with a failing stator. As the stator begins to fail under heat and load, it appears that the voltage drops and the current rises which then starts playing havoc with the rest of the charging system. I have posted references to this in my previous posts on this topic as well as a post on the general fraility of this type of alternator (stator) design. For those of you having multiple rr failures, I would consider replacing the stator. For the record, my bike is a 98 model with 24,000 miles and no history of electrical problems and hopefully, none in the near future.
I used to have a Honda Pacific Coast (V-Twin), which model was produced from 1989-1998, and those guys were always replacing their stators, which were probably similar, if not the same as, the ones we have in these bikes.
For the record, I replaced my failing original r/r with Honda upgraded one and got 13.98 at 5k (had been at mid-13s before, and clock was starting to clear, etc., indicating problem when I bought it), would pop over 14 off idle, drop on rising rpm, etc. Stator checked OK statically and output 59 vac. Thinking to get the volts at 5k over 14, I then replaced the stator and volts to the battery actually DROPPED to 13.94, warm at 5k. Bike has 14k on it. Still pops over 14 v off idle to 2k or so, then drops off to the 13.94 (warm) (13.89 cold).
Everything works, so taking a wait and see attitude here now.
Well, bad news. The stator wasn't all of my problems. After installing the new stator, all of my numbers got better by about 3/4volts, however as HS stated above, the droping voltage vs. increasing RPM's seems to be a bad RR. My theory on this is that when I began having problems last summer, probably started with the stator being bad, the bad stator then fried the RR which I replaced with a new oem. However since I still had a Bad stator it cooked the new RR as well. At this point, I can only speculate, but I sure hope that the new RR fixes the issues. I picked up a Yamaha R1 regulator from a 05, huge fins and looks to be a much more robust unit. I searched the squidly forums, and lots of folks with R1's from around 03 and earlier had RR problems, but the 04's and up the problem was corrected. My new RR should be here on Monday or Tuesday, so I'll report back then.
When replaced the alternator on my truck, the guy who rebuilts them told me something similar: a bad battery is really hard on an alternator. Since our system are slightly different, it still make sense that one would damage the other.
chris2992Well, bad news. The stator wasn't all of my problems. After installing the new stator, all of my numbers got better by about 3/4volts, however as HS stated above, the droping voltage vs. increasing RPM's seems to be a bad RR. My theory on this is that when I began having problems last summer, probably started with the stator being bad, the bad stator then fried the RR which I replaced with a new oem. However since I still had a Bad stator it cooked the new RR as well. At this point, I can only speculate, but I sure hope that the new RR fixes the issues. I picked up a Yamaha R1 regulator from a 05, huge fins and looks to be a much more robust unit. I searched the squidly forums, and lots of folks with R1's from around 03 and earlier had RR problems, but the 04's and up the problem was corrected. My new RR should be here on Monday or Tuesday, so I'll report back then.
Bummer...
Some Yamaha's use a generator instead of an alternator... ask Rick about using their RR...
The RC45 RR is robust and sports big fins...
GOOD NEWS AT LAST
I got the R1 RR in today and got it hooked up. Instantly had 14.0V at idle and 14.5v at 5k RPM. I also preformed alot of the procedures in the Beef UP Dem Wires thread. I haven't had an oppertunity to completely finalize the wiring, but when I do, I'll post up some pictures. I have to give a big thanks to Origional007 for providing the pictures and information on the R1 RR.
chris2992 GOOD NEWS AT LAST
Did you test OEM wires w/Yamaha R/R before upgrading wires to determine which (or if both) made the difference?
Unfortunately no, I did the wiring job while in wait mode for the RR to get here. However I'm sure that the RR was bad.
Just finished my R1 rec reg mod... major job as usual on this bike... had to machine 1/2 inch off the fins
and then cut a custom aluminum hanger... now I show a constant 13.7 to 14.2 volts... thanks Chris for the
idea and all the help... I shall recommend this mod to other RC45 owners...
[image: gallery_3131_51_26532.jpg]
[image: gallery_3131_51_42896.jpg]
Ok, stupid question time....how do I check the "AC voltage from stator. With a warm motor at 4000 rpm, I checked the stator side of the plug with the three yellow wires. Each one measured about 6V.
Yes, Electrex screwed me over. Advertised a 6th gen stator part number, but didn't realize there was a difference between 5th and 6th gen stators. Shipped me a 5th gen, which was smaller and didn't work of coarse. I sent them photos of the difference in sizes and they ignored me. Never got my money back.
I must admit though, they did ship me the wrong one pretty quick from overseas.
superfuzzOk, stupid question time....how do I check the "AC voltage from stator. With a warm motor at 4000 rpm, I checked the stator side of the plug with the three yellow wires. Each one measured about 6V.
There are 3 "legs" of the stator, the 3 yellow wires. Lets lable them 1, 2 & 3. Take your multi meter and set it to AC voltage with a range of 0 to somewhere around 200v (same range you would use to check a 120v receptical in your home). Now take the voltage across 1 and 2, 1 and 3, lastly 2 and 3. All 3 values should be very close to one another and at idle read about 20v and at 5krpm read about 60v. Make sure to do this with the RR disconnected.
Thank you for mentioning that the stator voltage test should be performed with the RR disconnected. I was getting worried about my results with the plugs connected. With the plugs disconnected I get 20v at idle and 60v at 5k. Thanks for the clarification.
It does seem that the stator wires look a good bit smaller on the stator side of the connector than on the RR side (Y2K VFR). While doing voltage tests, the wires on the stator side seemed to get pretty hot (when connected). Is this normal? I did the testing with the bike barely warmed up.
Mr. Visible
On my '02, those Stator wires are 16 gauge and run into (or used to), a connector block that goes out with 14 gauge wires to the RR.
And my wires get hot also.
I still haven't figured out what fried the "3P" block yet but I'm working on it. :thumbsup:
Totally melted white connector block.
Well - I'm pretty sure the the Stator killed the "3P" connector. I replaced my Regulator / Rectifier and the stator wires are so hot they melt the shrink tube on the connectors!
Finding a replacement kit has been a bit of a challenge though.
For those with 2002 bikes 31100-MCW-315 is the current up to date "AC Generator Kit" and includes the stator and flywheel. It replaces the kit quoted on the service bulletin.
BTW for you Canadians the price range on that part number from Victoria to Calgary was $355 to $420.
For you Americans - Service Honda www.servicehonda.com has the kit for $160.59 - and that is smok'in good deal!! I would have ordered from them if they had any. Come to think of it I should order a bunch just to sell them to Canadians!
Unfortunately, everyone seems to be out of stock and it sounds like it could be a few weeks to get them in.
Edited June 15, 2007 by talus
Here are some snaps of my stator change.
I didn't have the correct Honda tool for pulling the flywheel (07933-3950000) so I rented a puller. Service Honda lists the tool as a "PULLER DYNAMO" and sells it for $16.46 USD. It is nothing more than a bolt that screws into the flywheel and then pushes against the end tapered shaft that the rotor sits on. I'm sure any machine shop could make one up for you if you knew the thread. My rental puller cost me $10 so it's probably worth the extra $6.50 to have the correct tool for the job - you can alway rent it out to your VFR buddies for a case of beer and you'll end up ahead!! :thumbsup:
Here is a close-up. If you do use this method you need a puller that can fit through the center of the flywheel and push against the end of the tapered shaft. The end on this puller was about 5/8" and fit through nicely without going inside the tapered shaft or damaging the threads on the flywheel (my flywheel will be replaced with the kit anyway but no sense doing a bunch of damage). Those holes in the flywheel are also quite small so you'll want very small arms on the puller.
Here's a shot of the empty case. I was just starting to lean into the wrench on the puller and the flywheel literally "popped off". It took a fair bit of pressure so I'm not sure you would have an easy time trying to "pry" it off otherwise. Does anyone know what the brass bar inside the case that runs from 11 O'clock to 2 O'clock is for?
Now here is my stator. The three yellow stator wires come out of the top of the case at the 1 O'clock position so the dark brown section was definitely NOT soaking in oil. In fact - very little oil came out when I pulled off the alternator cover - not more than one cup max.
Here is the good looking side. The area where the stator was white colored looked not bad.
[image: gallery_11167_3100_80309.jpg]
Here is what it looked like on the dark brown side. Very burnt and toasty. It had a funky burnt smell as well. Makes me want to change the oil and filter. This is the first stator I have ever pulled apart but it sure looks bad to me. I'll take it down to the local shop and see what the mechanics have to say about it and let you know what they say.
[image: gallery_11167_3100_28426.jpg]
Anyway new parts should be here in the next day or so and I'll post some pics of the install. Maybe I should make up a "How-to"... would that be useful to anyone?
hi - yes yes yes
i think i need to replace the stator and am nervous taking all these parts apart - why does the flywheel have to be replaced btw????
gr3664hi - yes yes yes
Give me a day to get the pics together. I want to show the electrical reinforcement as well.
There is a great write-up on stator replacements (Maintenance - Stator Replacement). For your 2002 (and newer) you should also read the service bulletin (Six Gen - 2002 Alternator Recall) and of course review the Service manual (Downloads)
That should keep you busy while you wait for the parts. Don't worry about this job - it's no more difficult than changing the oil - just a couple of extra bolts.
Finding an appropriate puller and the two torque wrenches will be more difficult than the job. I need one "low" torque wrench for the case bolts and one "high" torque wrench for the flywheel bolt. Bring the torque specs when you go to buy/rent it will save you and extra trip :beer:. BTW the guys at the local dealer tell me they just "guestimate" the case bolt torque - I didn't have the guts.
I think that the flywheel gets replaced due to a stator/flywheel clearance issue. --- At least I seem to remember reading that somewhere around here.
Edited July 27, 2007 by talus
talus
Finding an appropriate puller and the two torque wrenches will be more difficult than the job. I need one "low" torque wrench for the case bolts and one "high" torque wrench for the flywheel bolt. Bring the torque specs when you go to buy/rent it will save you and extra trip :huh:. BTW the guys at the local dealer tell me they just "guestimate" the case bolt torque - I didn't have the guts.
this discussion is great! i am not thrilled that i have to dig into my fairly new vfr to do this but you guys make it so much easier and almost enjoyable - as to estimating torque, i changed the oil on my volvo the other day because the filter can had a hole in it and was leaking oil; i busted my finger when the filter finally unseated and crunched my hand - i had thought i had run over something that punctured the filter, but no, the duffus at the oil change place had so overtorqued the filter that it bent and in one of the creases had even opened up a hole!! i am a little leary of shops since then... i will follow your instructions to a 't' thanks again
Hey guys, I just got my Nused VFR and i am starting to get the bugs worked out. I have a 97 model and its in decent shape but the previous owner was a "first time owner" and i am sorting out all the missing peices and mismatched hardware. S
Of course my problem is a stator/ Reg/rec wiring problem, like everyone else it seems. I have tested the output voltage on the plug behind the faring on the right side (not the R/R). I unpluged it from the harness to do the test and at 3500 rpm i only see 0.06V. I see a lot of others posting at least 6V at idle and between 30 - 60v at revs over 4k. NEedless to say ALL 3 phases are dead and i get a reading of .03 to .06 on any of the 3 output yellow wires. Now i am still confused as to how to perform the test as i only inserted the pos lead on my multimeter into the output harness and i grounded the neg lead to either the neg battery terminal or directly to the frame. Also, the plug into my R/R was totally smoked and one wire was completely burnt trough. I have already ordered the Honda part to replace the plug and cooked wires but i want to be sure im replacing the right part. either the Stator or R/R... Honestly i am starting to think i will just buy both for some peice of mind... I already bought the brand new battery and it is being tended so it doesnt get damaged in any of my testing proceedures. I also want to add that i found the R/R was an aftermarket one so it has been replaced previously, how long ago i dont have a clue.
Thanks in advance to anyone who can help me get this thing worked out....
[image: 29910223741.jpg]
[image: 29910223617.jpg]
[image: 29910194775.jpg]
Edited October 27, 2007 by Dirtnap450
Well i just cant spend money until i am darn sure that i have the right part..(knock on wood) So i put the old stator back in and added some oil. I started her up and tested across all three phases (1-2, 1-3 & 2-3) of the stator and still i get nothing but DEADNESS!!... i would initially (for a milisecond) get a reading of 25-30v (for about a blink of any eye and that could just be the behavior of my multimeter) but it would immediatly drop to .06v. It was a similar result on all three phases and i never saw even a hint of real voltage.
I dont know what to say but i connected everything and even plugged in the burnt old connector to the R/R. Believe it or not that dam thing started working! I am getting 12.9v at idle and around 14.4v at 4k. I have ridden her around the block a couple of times to see if heat will bring back the charging problem but it kept working. I let it cool off for a couple of hours and the bike started right up and the voltmeter showed 13.5 at 2500 rpm. SO i am still going to solder in the new connector for the R/R and the test her again. *fingers crossed* Maybe it was a connection problem with the connector under the right faring? jeez the not knowing is going to keep me up all night......
Edited October 28, 2007 by Dirtnap450
So I haven't seen any firsthand reviews of the stuff from Rick's, except from Chris...? That stator has served you well? What about their R/Rs? It's lookin like I'm about to get into this on my '86, so I want to be sure I get the right stuff.
duderadideaSo I haven't seen any firsthand reviews of the stuff from Rick's, except from Chris...? That stator has served you well? What about their R/Rs? It's lookin like I'm about to get into this on my '86, so I want to be sure I get the right stuff.
I have had good luck with Rick's R/R's....I have sold 10 or so of their's through my site. They have good customer service, and I have had Rick himself call me to answer a question I had. The biggest issue is to be sure you don't have other issues causing problems. Any weak link can have effect on multiple items, sometimes tracking the true problem down is tough!
Well, here's my situation. I've got similar symptoms to the ones at the very beginning of this thread;
I pulled the bike out of the barn from winter storage on Sunday, put the battery in, which had been on the tender for about 8 hours. Didn't have enough juice to start the bike, so I plugged it back in to the tender and gave it a jump, at which point it started... idled for a few minutes... shut it off, then it started up again, but the battery was going on its 5th year, so I replaced it yesterday morning anyway with a brand new Interstate.
As soon as I put the new battery in, I hit the road and blasted from Vermont to (almost) Rochester, NY. Had no problems until about 20 miles outside of Rochester, then it just shut off (at about 80mph all the way in the left lane) and wouldn't start again. I let it sit for a few minutes and then was able to bump start it and ride about 1/4 mile off the thruway. Got it back to my apartment, pulled the side covers today, and found that connector on the 3 yellow wires between the stator and the R/R totally melted, 2 of the wires actually burned through.
Soo, new stator/RR/battery, no? It's got 43k miles on it, 25k of which are mine, and to my knowledge it's still got the original R/R, and presumably the original stator.
So that's where it's at right now. Should I just go ahead and get an R/R from Rick's and have them rewind my stator? The weather was BEAUTIFUL today in Rochester, I was so bummed to not be riding to class.
Im having a charging issue too. Odd thing is is that I have 1600 miles on the bike. is that even possible that the stator or RR could fail in such a short amount of time?
I disconnected a bunch of connections, reseated them, charged the battery, and bam, runs great. It idles at 13.9 and goes to about 14.1 at anything above. Had the headlight turn off but once i started the bike it came back on. I let it idle for 20 mins and Voltage was constant and smooth. lose about .8 volts when the brights are on, which i beleive is normal.
What say you?
I'm having similar issues to what Chris was having, except my charging voltage is 12.3V. I'm replacing the reg/rec since the troubleshooting diagrams point to that. However, my stator looks JUST LIKE all the brown ones on this forum: dark brown 2/3 of the way around the circumference. And yet it checks out fine...
So my question--is there anything to be gained by checking current through each of the stator wires? I've checked voltage, and I get around 20VAC at idle, 60VAC at 5k RPM, both on a cold engine and with the coolant up to 170ºF. It seems that measuring current would only give you as much information as checking the voltage, but I wanted to throw this idea out there. Can any electrical engineers chime in?
FYI, I've seen discoloured stators before, but this one (found on another forum) is truly fried: gallery_362_402_1085949.jpg
I am having issues with electrical system in my 2000 vfr 800. Its a new interstate battery, so I dont think that that is the problem. My buddy said it was a regulator rectifier. Instead of replacing the r/r, he hard wired it in because the conection was fried. All the tests of the electrical system he performed seemed fine. I went for an hour ride, shut the bike off and then it wouldnt restart.
Anybody know what I should do?
This is very frustrating!!!
Keatballs.
Post the charging system results from the chart on the first post of this thread. That will allow for a proper diagnosis. However I'd say that your RR is smoked. Look for the R1 RR thread how to.
Can anyone verify if part number 31100-MCW-315 is still the AC generator kit for a 2002 VFR? I called service Honda and they don't list that part bring for a VFR. It's non returnable and I want to make sure it's going to work before I spend the $$ on it.
According to CMS (Netherlands), that part number has been superseded; the current part number is 31100-MCW-325. That said, I don't know what that part is. The middle section "MCW" means that whatever it is, it was originally designed for the VTEC RC46, so at least you know that much. Ron Ayers' site says the part is not in their microfiche system (but they can supply it if you want it), which is consistent with a repair/service kit. They are parts that are developed after the bike was designed, so it makes sense that they may not be in the microfiche.
Bumping this topic again. I bought my 2006 VFR in 2009, had 3180 miles on the odometer. In 2011, I had to replace the stator (diagnosed by Wheeler in North Carolina), it was totally fried, about 18000 miles ish on the odometer. I know have 36,000+ miles on the bike, and after being on the battery tender all winter, the bike is exhibiting symptoms of the stator going again. I love this bike but an important part like this should not be such a problem.
Is there a better stator out there to replace the OEM one?
I bought a KLX250sf to take some of the commuting load off the VFR, i.e. big engines don't like heat. I bike tends to run warm in traffic, even on the interstate. The temp will climb to 200-208F at 75mph in traffic, will only cool down in open air.
I have been commuting for about 3-4 weeks since the ice finally cleared the roads, daily temps haven't been more than 50-55F and morning temps 25-45F, the bike has never exceeded 180F until today, but it started hard today anyways.
Why is the stator so weak? I still have the old one for reference. Is there anything that can be done to beef up the stator? Better insulation so it won't break down and short out?
I'm frustrated and I'm supposed to be leaving for Ohio in 8 days and now I have to drop more money into a bike that I maintain religiously.
BTW, I'm sitting at work because the bike is dead, waiting for a ride to go get my trailer, grrrrrrrr.
The majority of oem motorcycle stators, are sub 50,000 mile units, most fail in the 20 to 30,000 mile range, any models that average above 50,000 mile are considered above above average life, the your 06 falls in the range. Although you had a failure in less than ten thousand miles thats very poor for the vfr and not normal, you might check all your wiring from the stator through all the charging circuit and see if you have over heating and melting plugs. But when they replaced your stator do you guarantee it was an oem unit?
In all the Oem vfr stators, are the best that can be had, yes they will fail , they all do. Ive experienced very good stator life on the vfr, the first oem 56,000 miles and the second oem is pushing 50,000 and still going, cant really ask for much more, considereing the statistical numbers in stator life, for the majority of motorcycles is much lower.
Im still waiting for someone with aftermarket stators, to come even close to oem.
I ran more stuff on my 2005 svs650 and never had an issue in 65000 miles. It's very bothersome that this is happening. I drove the truck and trailer to work, put the bike on a charger so I can get it home and look it over real good. I'm ordering a stator and beefed up r/r from Rick's electric today so I can get the bike back to reliable by next wed for my trip to Ohio. Hopefully I can get some money for the stators from a salvage yard or something. Rick said that they do not rebuild the stator for this model VFR800, bummer.
Suzuki imo, is about the weakest, so Im surprised you have 65,000 on an sv stator, I know my suzuki stator went out about 21,000 miles, and that is pretty much the average for that particular model, but I did see 1 or 2 make it towards the high 20's a rarity.
I have a friend and his vstrom stator failed at 10,000 miles.
Check all your connections for tigtness/corrosion/burning/melting before replacing any hard parts.
And stators that test good when cold sometimes get flaky when hot.
Ranger
So found Rick's online. Stator is $160, RR $150. Are they better than OEM? Any thoughts. Also, their information says "Ricks Design eliminates the use of the OE black wire. Anybody have any experience with Rick's products?
I tested my stator this morning, per instructions found elsewhere.
Battery checked at 12.8, after full charge off the bike and left hooked up to the bike overnight.
Ohms reading is -00.0 across all terminals.
I have not found anything online about that reading...  Am I doing something wrong or does this mean the stator is toast?  Bike is 2000 VFR with less than 17k miles.
Thanks for any input.
Edit...  Just realized this is a 2013 thread.  :P
10 hours ago, Rick1
You test VAC between the 3 legs. You want to see 20vac at idle and 50vac+ at 5k rpm across all 3 (A to B, B to C, A to C)
14 hours ago, thtanner
Thank you.
I actually went to the local auto store to check my battery this morning, and they advised it's time to change...  Weird, as I've had no problem starting with it.
Will start with that and retest everything.
Appreciate your help.
At 12.8v overnight it's absolutely fine!
That's what I was thinking as well...  I'll double check with my voltmeter.  Read online that I can check by starting and revving the engine, seeing where the voltage is at.
Any opinions on that method?
29 minutes ago, Rick1
Rick,
You should go through the stator tests 1 by 1, as well as the rectifier tests 1 by 1. Yes, you can watch your basic DC voltage when you rev. Stock regulator will cap out at 13.9v or so. That doesn't test the individual components so you can't be sure you're 100%. One of the legs of your stator can be out and it will still probably near 14v if your regulator is working right.
If you don't know how to use a certain function of the multimeter, look it up on the Googles or ask us.
There is no substitute from individually testing the components.
57 minutes ago, JZH
That's float voltage, but if it can't handle load, the battery is toast. Float voltage is not a great indication of battery health. The store should have put a load test on it, which it sounds like it failed.
I think you mean "surface charge"?  Anyway, I misunderstood Rick's message: if he tested the battery immediately after charging it overnight and disconnecting the charger, then the voltage reading would be unreliable.  A load tester is not absolutely necessary, but you do need to remove the surface charge before testing (by leaving the battery disconnected for several hours and turning on the headlights for a couple of minutes).  Then, a reading of 12.8v would indicate a good battery!
4 hours ago, JZH
The battery could sit for a few days, still indicate 12.8, and fail a load test. That is why voltage can not be solely used to determine battery health.
1 hour ago, thtanner
I suppose it's possible, but I haven't seen any batteries test at 12.8v as described above and fail a load test, though.  There would have to be an internal breakage or something.
So I noticed that running heated clothing puts too large a load on my battery; I'v had the tach, speedometer and headlight all falter when my clothing is at maximum draw (jacket and glove liners). I ordered the wiring harness and mounting plate from roadstercycle, as well as the appropriate used R/R from a wrecked 2016 FZ-09. Two days ago I ran some of the tests from the Honda Service manual; charged battery was 13.3V several hours after being removed from the Battery Tender; there was no continuity between the stator legs and ground; resistance between each pair of stator legs was 1.3 Ohms at 40ºF (4.4ºC)--corrected using the alpha for pure copper, that comes to about 1.4 Ohms at 20ºC. There's virtually no leakage at the battery, which is encouraging. Yesterday, battery voltage was 12.8V; after warming up the engine, I measured 12.5V @ 5000rpm at the terminals. I've not yet checked battery load, but the elevated resistance for all three legs of the stator and the poor charging at 5000rpm (AND the inability to run any accessories) make me think I'll replace the stator along with the R/R--and possibly the battery as well. Plus install a voltmeter at the same time...
Sent from my iPad using Tapatalk
1 hour ago, MsRN98
Also check your earth block, this could also play havoc with your charging system and should be upgraded ASAP..
VFROZ
Will do; thanks for the advice. I looked at online vendors for a new Honda stator; it appears that the OE 5th-generation stator has been discontinued. What is the recommended replacement?
3 minutes ago, MsRN98
I looked at online vendors; it appears that the OE 5th-generation stator has been discontinued
I find this hard to believe, try OS, from US or OZ.
Actually, forget here, you will pay through your nose.
Try Partzilla, that's were I got mine.
VFROZ Here it is:
http://www.partzilla.com/parts/detail/honda/HP-31120-MBG-003.html
Ordered--thanks for the link! I should see it Tuesday or Wednesday. In the interim, I just have to figure out how to limp the bike through, if possible; I'm away from home at the moment.
You mentioned upgrading the earth link; is there a better way than soldering all the leads together and connecting them to a new earth point? Not that I'm averse to the latter, just curious.
Soldering is the best connection you can do.
It is also the only type of connection I would do to the three stator to RR wires.
In fact, I got rid of all connectors in the charging system.
VFROZ Soldering is the best connection you can do.
That works for me. I already have the new MOSFET R/R and direct wiring loom to connect it to the battery and the stator. The R/R will be attached to an aluminum adaptor plate, then to the original R/R mounting points. I'm tempted to find some sort of thermally-conductive grease/cream to improve contact between the R/R and the mounting plate, in order to optimize heat sinking. As for the stator, I've seen it said that the OE wiring from stator to R/R is insufficient; is this the case, and should I re-wire that connection with larger-gauge wire than Honda supplies with the OE stator?
I'm already planning to solder the stator wires to those for my new stator-R/R quick disconnect. Are you saying you bypassed the quick disconnect and soldered the stator wires directly into the R/R?
No, you will have to use the RR plug as I've done to my ex R1 FH012.
The biggest problem is the Honda connectors, and undersized wiring from RR to main fuse and battery.
You should get rid of all weak points, the earth block, the main fuse, the charging circuit wiring.
Stator wiring is ok, just go directly to the RR and use the proper crimping tool made for the type of connectors you have bought, failed crimps are bad news and a major weak point. Crimp and solder is even better, just don't over heat it.
RR to battery should be upgraded and head directly there through new heavy duty main fuse, not through the harness.
Also make sure any cable you use is of good quality and thin multi strand made for 12v.
Heat transfer paste will do nothing much, as the new RR doesn't get that hot.
VFROZ No, you will have to use the RR plug as I've done to my ex R1 FH012.
Happily, I bought the RR plug with stator wiring already attached courtesy of Jack at Roadstercycle.com. I'll solder that wiring to the wiring from the new stator. As for the RR-battery connection, that, too is courtesy of Mr. Fleming; it's 10-ga wire with a 30A inline circuit breaker, routed directly to the battery. Which leaves the earth block and the main fuse, if I understand you correctly.
The circuit breaker bypasses the main fuse, so that is sorted.
You will need to solder the wires from the stator to the wires coming from the RR.
I also ran a new bigger gauge wire from the soldered earth bolock to the battery.
That should see you with many years of trouble free riding.
Adding a voltmeter will give you peace of mind.
A voltmeter is definitely on my shortlist, and the stator-RR wires will definitely be soldered. Thanks for the suggestion about the large-gauge wire from the negative battery terminal to the soldered earth block; I can make that happen, too. As for the old stator, I'll send it for a re-wind and keep it in reserve for the next time this happens--hopefully not for a long, long time. Then it's on to cleaning all the terminals with De-Oxit, finding and installing a distribution block for heated gear, radar detector or whatever else strikes my fancy, and riding as much as possible!
I have spent some time reading articles about stators and that the best route to follow is to go with a OEM. I have a 4th gen and the OEM stator is no longer available. Does anyone know if there is a Honda stator from another model that will fit a 4th gen? I am not worried about the connector as that would be eliminated in favor of a direct connection.
#114
The 3rd or 5th gen units might fit, you’d need to do a size comparison. But the simplest & usually cheapest solution is just to get the current one rewound !
You can either do that yourself or get it don professionally.
Got mine from Joshua (Tightwad here on VFRD) from www.wiremybike.com
Thanks for the responses. The current one is working fine so I am looking at getting one as a backup in case something goes horribly wrong while I am on the road. With a backup and a backup R/R, although inconvenient I am not left stranded somewhere to wait for parts.
#117
My 6th Gen unit at 41000 miles, think i will do a new stator and RR at the same time..
Any experience / anecdotes on the Ricks Motorsports staor units?
Not Rick's specifically.  I sent my G6 stator to Custom Rewind in Birmingham, AL.  Fine work - cost me $105 plus shipping.  Very happy with it.  The good thing about them is they will give you any length lead you want or any connector if you want to change R/R or its location.
20 minutes ago, Cogswell
Thanks Cogs! I will call them tomorrow! Cheers, JW
If you get the owner on the phone - can't recall his name now, Gary? - he has multiple sclerosis.  It makes him sound like he's drunk,  but he's not.  Good guy.  He has others working there.  They do good work.
14 hours ago, Cogswell
Thx for the info, i will post updates as it goes........................ talked to Vicki at the shop this am.. going to get it ready to ship off to Alabama!
1 minute ago, jimbob
Awesome.  When you caught up with me and we rode over Lolo pass, I was then running their stator work.  No reason it should not work out as well for you.  :fing02:
Cogswell, 1/20/2021 at 10:00 AM
Got the Stator back from Custom Rewind today...looks good, cost $125 with shipping,  hope to reassemble asap!
Stator Update :  the rewound unit is back in its place..  fired up and got 14.5V at the battery terminals at a fast idle..  looks like a success! The whole process was not too tough, just takes some patience.  Trailering to AZ next week... so lotsa test rides coming up soon ! 😃
I sent a stator to Custom Rewind and had them upgrade the windings as well as put a Yamaha connector on the output leads.  Got it back and installed it in a buddy's 98 with about 20k miles on it.  We previously installed an R1 R/R but this was on our list to complete.  Even with the R1 R/R, his volts never rose above 13.6v.  It appears we completed the upgrade in time.....  Custom Rewind continues to do excellent work, 14.4v at idle.
[image: IMG_9321.JPG]
#127
However, that stator in the picture above is what I would call a "normal" color.  The lower windings don't turn brown because they're generally submerged in engine oil.  When the windings char and flake, then you've got a problem!
JZH
End of thread · 127 posts recovered Wayback Machine snapshot 18 Sep 2021
