1986 VFR700 Fuel Tank Issues
6 posts Started 6 May 2024 Last recovered post 1 Dec 2024 Wayback Machine snapshot 18 Mar 2025
Hi guys,  I recently started another project bike that I pulled out from behind a barn in Maine a few weeks ago.  The bike had been lying on its side for more than 10 years.  The tank is toast.  had at least a half a tank of gas in it when it was stored and that dissolved into brown junk.  The tank has holes in it all around and would take a major advanced welder to be able to fix it.  Just wondering if anyone out there has a tank for a 86-88 they want to sell or if anyone knows if there is an aftermarket tank available?  I think I saw a post about a retired guy in CA who makes them from scratch?
thanks for the assistance
Hey guys, secondly what would you think of a CBR600F2 tank on the VFR700?  dimensions are really close.  Just wondering your opinions?
The rear of the tank that has to fit inside of the rails of the subframe will likely be an issue on a CBR tank.
There are even some very anomalous VFR tanks that are slightly wider in that area and had a slightly different subframe to accommodate.  Joe at v4 Dreams first documented it and I also had a tank with a parts bike that was like it.  It was very strange and would not fit on any of my bikes.  Unfortunately the subframe got tossed before I took possession of the bike.
There are tanks out there.  Will it be really pretty AND really cheap?  No.  But you have A LOT of work to do before you are even close to needing a real tank to ride down the road.  You can finish everything and run it on a hanging aux tank while you look.
This is a classic cart-before-the-horse scenario.
I have done a ton of work on it so far.  Taking the engine apart this week, 3 out of 4 spark plugs came out fairly easy.  1 is in there really bad, gonna need some heat the luck to get it out.
have a complete set of bodywork now, just need a complete brake light.  I will be posting some of my extra parts on FB marketplace soon.
End of thread · 6 posts recovered Wayback Machine snapshot 18 Mar 2025
