11 hours ago, lucwilride
Hello @Grum, I just checked the stored FI Fault codes. It is throwing code 22 = Faulty no. 3/4 Oxygen Sensor, no codes other than that one. Any thoughts on whether or not that could lead to the issue I am having?
I'll pull the fairings tonight so I can check the sensor, wiring and connector. Could someone explain how I can check the wiring between the sensor and ECM for shorts? It appears that I would check continuity of the black/orange wire between the ECM and connector? The other wire (that is not for the heating element) seems to be light grey in the wiring diagram and this connects to a green/orange wire that goes to most of the other sensors. Do I need to check that wire as well for shorts/continuity?
It looks like the heating element has it's own fault code (which has not been thrown) but I will check the resistance between the two white wires on the sensor itself anyway. This is a ~$300+ part for me so if there is anything I should verify prior to just buying a new one and replacing it I would appreciate any tips. Thank you!
Can I ride the bike with this faulty sensor or is it best to park it until that is fixed?
I wouldn't worry too much about the Code 22 for the O2 sensor at this stage, other than to perhaps check its 4P Black connector for good, clean connections. The Service Manual Symptoms for this Fault States - "Engine Operates Normally".
It would be highly unlikley the O2 sensor fault would cause your nasty issue as the O2 sensor just provides feedback info to the ECM (closed Loop Mode) for A/F ratio fine trimming.
Did you clear the code as suggested? You want to do this and re run your bike, who knows when that O2 Sensor DTC could have been logged to memory, if your bike gives you a hard time, its after that when you want to see and recall if any intermittent fault has been stored to memory. AND when riding when the fault occurs check the status of the Fi Light as quick as you can IF you can! A sudden flash of the Fi Light could also mean a momentary loss of EFI Power - The Black/White wire coming from the Engine Stop Relay and ultimately from Main Fuse B 30amp previously mentioned.
With the memory cleared any highly intermittent error detected by the ECM (there one second, gone the next) will be stored and may help in isolating a problem causer.
An intermittent sensor issue, such as the TPS, a Fuel Injector, Ignition Pulse or Cam Pulse Generator etc is more likely to cause sudden changes to the bikes operation, not an O2 Sensor, especially as you've stated that "It does this in rain or sun, hot or cold, any gear, any speed".
And, as mentioned, an Active current fault detected by the ECM will have your Fi Light ON while riding, then displays the flashing code once stationary with SidesStand Down. If the fault suddenly comes good the Active code dissappears and no flashing code will be seen, However it will be logged and stored in the historical memory for later recall.
There most definetly is No problems riding the bike just because of a historical memory DTC of 22 for the O2 Sensor. If it was currently Active your Fi Light would be telling you so, you don't have that situation.
Just curious - When you changed the Spark Plugs. What brand and part number were they?
Be interested in hearing how you get on after siphoning as much as you can from the tank and refill with fresh preferably non Ethanol blended fuel.
There are stories of Fuel Stations (high humidity regions of Texas is one area) that do not purge their storage tanks, this allows the continued build up of water in the tanks because of Ethanols hygroscopic nature, this can ultimately end up in the fuel tanks of customers, something to think about!
