#1 Thread starter
The OEM wheel weights are the type that clip onto the center ridge of the wheel. It looks to me like using these weights repeatedly will scratch the wheel, as they are held in place by spring tension on metal tangs which dig into the wheel.
Stick-on weights avoid this problem, but they cannot be centered on the wheel. Is this a concern for getting a good balance?
The dealer will be changing the tires, and I think I'd be better off with the stick-on weights if for no other reason than to avoid some ham-fisted type prying off the OEM-installed weights and scratching the wheels. So, I should take the OEM weights off myself before taking the wheels to the dealer, and tell them to use stick-on weights. Yes?
Not an earth-shattering issue, I know, but opinions would be appreciated. Thanks.
