Need advice on dealing with the throttle cables when replacing right hand control on 5th gen,
12 posts Started 2 Feb 2026 Last recovered post 5 Feb 2026 Wayback Machine snapshot 10 Feb 2026
The handlebar switches on my 5th gen are pretty shot, so I bought replacements, but the throttle cables are giving me grief.
Is there any way to get the throttle cables loose *without* involving the screws down by the throttle drum?
[image: image.png.96c66324a6be2e0320acfa2d9fa697ca.png]
I can't find my ratcheting 90 degree screwdriver and I'm afraid I might have already mucked up the head on the smaller screw.
I can buy a new tool, but if I'm missing something clever, I'd sure like to find out.
Removing the throttle cable adjustment bracket makes getting the cables off much simpler.
Unfortunately, yes, the little screws need to come off.
Do you have a JIS screwdriver set? And maybe a hand impact wrench?
[image: 20250421_231754-M.jpg]
I faced this little challenge when I borrowed the throttle tube from my 99 to use on my 1200. I couldn't get a straight shot at those screws so I opted to back off the adjusters fully, which gave just enough slack at the throttle housing.
Please tell me you didn't use a Phillips head bit?  First rule of wrenching on any Honda (or Japanese motorcycle for that matter) is to remove all Phillips head screwdrivers from your toolbox and toss them in the trash.
I've done a handful of throttle cable replacements on 5th gens.  Much easier to get that little bracket off first and install last.
-stuff a rag or paper tower wad below that area in the V of the engine just in case you drop a screw.  It will be less likely to vanish if you prevent it's path from falling into the void below the throttle bodies.
-ratcheting offset 1/4" drive screwdriver fit with a JIS bit is your best friend for this job.  Bonus points if you get one with a swivel head.
This little fella stays in a tool roll next to an ammo clip of JIS bits.  I also keep a standard 1/4" bit driver (traditional screwdriver profile).
https://www.amazon.com/gp/aw/d/B08DQ9ND52
17 hours ago, vfrgiving
 I don't think I'd go that far, but yeah you need to be using JIS drivers/bits on any Japanese vehicles. Haven't stripped a single head since discovering this. Don't get the cheapest Chineseum ones either get 'em from a quality tool vendor. They are totally worth it.
2 hours ago, MBrane
Maybe move them to a junk tools bag used for DIY home repairs?  I'd get them out of your main vehicle repair tool box though, not worth the chance of a mix up.  The thing about JIS bits and drivers is they are perfectly fine (and sometimes superiors choice) to use on Phillips head fasteners.  So it wouldn't matter if all you had to grab for were JIS bits since they can handle both.
I'd forgotten about the difference between JIS and Phillips.
I *did* use a Phillips, but I stopped before making a mess of it.
I just ordered a set of JIS bits, the swivel head driver and a replacement for my 90-degree ratcheting drive from Amazon.
Thanks to all for your input.
Another quick tip.  Take a photo of the cable ends before you pull them from the bracket.  That way when you go to put them back you can set up the thread, bracket and nut spacing as it was.  Will make life much easier so you aren't having to fight a ton of adjustment at the business end.
also.. if for what ever reason the swivel or offset of choice presents to much bulk to get a straight shot. ..  Pull the JIS bit from the driver.  slip the box end of a tiny 1/4" combo wrench over the bit.  use your thumb and index finger to get this arrangement in place.  keep a finger pushing on the backside of the bit as you turn the wrench with your other hand.  once cracked loose, you should be able to remove the wrench and roll the bit between your index/thumb to remove the screw,
2 hours ago, vfrgiving
That's why I bought the other driver:
[image: image.png.cbefb6a948330550c007d54970ad3f30.png]
My original version of this is not closed on one end; the length of bit itself is the limiting factor in the amount of space needed.
That's essentially the same as what you describe with the advantage of the ratchet.
I know it's somewhere, but there's a time factor.
3 hours ago, mello dude
Also another tip.... mark each cable end with paint pen so you arent head scratcing on reassembly on which cable goes on top and bottom....
[image: 20250827_184015-S.jpg]
That's a good idea.  Although, if forgotten and mixed up it's not that hard to figure out mechanically.  I never marked the ends.  Roll the throttle tube open and closed with the throttle body ends disconnected and it's easy to see which cable shortens when "giving it the gas".  That's the primary and needs to go on top.
mello dude, 2/3/2026 at 9:46 PM
This is exactly what I do
End of thread · 12 posts recovered Wayback Machine snapshot 10 Feb 2026
