#1 Thread starter
Just purged my tires and filled with nitrogen. Has anyone else done this? Supposed to give consistent tire pressure, cooler tire temps, and longer life.
http://nitrogendirect.com
quicknick, Feb 18 2006, 11:57 AMThanks for the info VFR FLYER. I have a gas question. Why does helium make your voice funny for a few seconds afer you inhale it?
quicknick, Feb 18 2006, 12:57 PMThanks for the info VFR FLYER. I have a gas question. Why does helium make your voice funny for a few seconds afer you inhale it?
VFR FLYER, Feb 18 2006, 07:24 PMdon't know, don't care BUT...........
any time you breath anything but air or oxygen you deprive your brain of needed oxygen and the resulting deaths may be found from the Compressed Gas Association. at or about $100 for a 220 cu in. tank are you letting your employees or customers do this? hope not! your liable!!!!!!!!!!!!!!
chris2992, Feb 18 2006, 12:40 PMThis is kind of off the subject, but FLYER see if you agree. For every 10 degrees of ambient temp change, there is 1 psi difference in the tire. Therefore if you inflate your tire to 36 psi at 0 deg F, and the temp rose to 100 deg F, your tire would then have 46 psi in it. That is the rule of thumb that I have lived by for as long as I can remember, is this correct.
BDKesling, Feb 18 2006, 01:41 PMWell, sort of. The main reason we breathe is to purge the carbon dioxide we've built up. Getting the oxygen is a secondary benefit. This is why the air that we breathe out still contains about 16% oxygen, when the air we breathe in has about 20%. I don't recommend seeing how long you can breathe air without oxygen, but having fun with helium once in a while is unlikely to kill.
VFR FLYER, Feb 18 2006, 08:51 PMwell if you want to nit-pic ...........the air we breathe in is to get oxygen (PRIMARY) dry.gif and the air we breathe out is to rid ourselves of carbon dioxide.
in the good ole usa several people DIE yearly from playing with helium and the person allowing this is liable. i didn't say it wasn't fun, i just don't do it
ExcaliberVFR800ABS, Feb 18 2006, 12:40 PMJust purged my tires and filled with nitrogen. Has anyone else done this? Supposed to give consistent tire pressure, cooler tire temps, and longer life.
BDKesling, Feb 18 2006, 02:00 PMI'll have to agree to disagree. Carbon monoxide poisoning doesn't hurt because we are still able to breathe out and get rid of the built up carbon dioxide, which I will contend is the primary reason for breathing huh.gif
I'm sure several people die playing with helium, but I won't agree that breathing it in and talking funny makes it dangerous anymore than I will agree that riding a motorcycle is dangerous because some idiot in a cage might not see you. Both CAN be dangerous, along with walking down a flight of stairs, but with my opposable thumbs and a skull full of kidneys, I'll take my chances.
Brian
BDKesling, Feb 18 2006, 03:00 PMI'll have to agree to disagree.� Carbon monoxide poisoning doesn't hurt because we are still able to breathe out and get rid of the built up carbon dioxide, which I will contend is the primary reason for breathing� huh.gif
VFR FLYER, Feb 18 2006, 12:36 PMmy biggest pet peeve is the selling of co2 inflatetors for tires at our motorcycle supply shops. this is probably worse than using compressed natural gas! there is also no benefit to using helium. happy to answer all "gas questions"
dutchinterceptor, Feb 18 2006, 02:18 PMWhat exactly is your peeve about the co2 inflaters?
VFR FLYER, Feb 18 2006, 09:09 PMIF YOU AGREE TO DISAGREE, ARE SAYING I AM INCORRECT ON THE TOPIC *NITROGEN IN TIRES?* WHATS YOUR ANSWER?
VFR FLYER, Feb 18 2006, 03:47 PMC02 inflators are dangerous because..........co2 expands rapidly with temp as a gas or liquid. a common example is a common result ie. co2 cylnders are filled on the dock in las vegas. c02 pressure in the cylinder at 70 degrees is about 850 psi. the cylinder has a burst disc safety that releases a little above 2000 psi. the newly filled cylinders are rolled out in the yard for storage. in the summer at 110 degrees plus in the sun. several of the burst discs will let go....expanding volume.
i can demonstate this to the local people by taking a plastic soda bottle and squirting a little co2 inside and screw the cap down tight. throw the bottle out into the parking lot and within a few minutes the bottle will explode from the internal pressure. DO NOT DO THIS! the force of the explodeing bottle can remove your hand. you may also get a response from the fire dept and or police.
if you have an inflator fill a tube just enough to give it its shape and then set it in the sun. oh yeah! DO NOT DO THIS! ITS DANGEROUS
BDKesling, Feb 18 2006, 03:58 PM
tbzep: When I say carbon monoxide poisoning doesn't hurt, I mean that it isn't a painful death, like drowning or suffocation, or getting hit with a big spear. This was in reference to our reasons for breathing.
dutchinterceptor, Feb 18 2006, 04:03 PMJust so I'm clear on this....you're saying that the cartridges are dangerous in and of themselves OR just that the CO2 gas is dangerous under certain conditions?
Are you saying that the cartridges have the potential for explosion while sitting in my jersey pocket while I'm cycling on a 100+ degree day? Might have to consider a frame pump if that's true.
VFR FLYER, Feb 18 2006, 04:46 PM
what is the beer keg setup? i understand the bottle, keg but was is the pump for? a normal keg has co2 going in to pressure the keg and a beer supply out to tapper but that looks like some kind of pump? huh.gif
KEGS FIZZING MACHINE art.490
to fizz the still wine.
It is consisting of a recirculating pump, a pressure reducing valve and a specific fizzer to joint carbon dioxide (CO2) to the wine contained in the kegs.
To being under pressure in the keg, the wine do not lose the fizz.
tbzep, Feb 18 2006, 04:52 PMLOL! Here's a quote from the site. You can tell, English isn't their first language. It was the first interesting pic dealing with CO2 pressurization that I found doing a google image search. tongue.gif
redneck7769, Feb 18 2006, 06:06 PMI heard from an tire maker a long time ago that nitrogen does not degrade the compounds in your tires as fast as oxygen and therefore would make your tires last longer. (ie longer period till tire has what i call weather cracking)
VFR FLYER, Feb 18 2006, 06:13 PMi am confused? why would someone waste time trying to fizz wine? pour that crap out and get some good beer!
VFR FLYER, Feb 18 2006, 10:47 PMC02 inflators are dangerous because..........co2 expands rapidly with temp as a gas or liquid. a common example is a common result ie. co2 cylnders are filled on the dock in las vegas. c02 pressure in the cylinder at 70 degrees is about 850 psi. the cylinder has a burst disc safety that releases a little above 2000 psi. the newly filled cylinders are rolled out in the yard for storage. in the summer at 110 degrees plus in the sun. several of the burst discs will let go....expanding volume.
VFR4Lee, Feb 18 2006, 08:56 PMI have a gas question. How to neutralize the ass gas that I try to pass off on the dog? Oops, we don't have a dog. laugh.gif
Growler67, Feb 18 2006, 06:53 PMWe used Nitrogen when racing in Hawaii. Air has other gases in it and some of those expand due to heat, and contract due to cold. Nitrogen was chosen because it is inert and readily available. Being inert, it did not change the tire preasure when the tires heated up while racing. Just my $0.02, without any tangents.
Growler67, Feb 18 2006, 08:53 PMWe used Nitrogen when racing in Hawaii. Air has other gases in it and some of those expand due to heat, and contract due to cold. Nitrogen was chosen because it is inert and readily available. Being inert, it did not change the tire preasure when the tires heated up while racing. Just my $0.02, without any tangents.
BDKesling, Feb 18 2006, 02:41 PMWell, sort of. The main reason we breathe is to purge the carbon dioxide we've built up. Getting the oxygen is a secondary benefit. This is why the air that we breathe out still contains about 16% oxygen, when the air we breathe in has about 20%. I don't recommend seeing how long you can breathe air without oxygen, but having fun with helium once in a while is unlikely to kill.
As mentioned above, helium is much lighter than any of the gas particles that make up the air we breathe. As such, it's a lot easier to move, and your vocal cords vibrate much more easily when passing helium over them as compared to air. The helium then vibrates at a higher frequency, and you talk like a chipmunk (animated, not the park kind).
Brian
Growler67, Feb 18 2006, 11:01 PMAs heavy as a VFR might be in comparison to other bikes, it doesn't weigh what a 767 does. The amount of increase in negligeble compared to the same tires under the same conditions filled with air. A front tire was set at 32 psi with air and after a few laps, it was up to almost 36 psi. We switched to nitrogen for an endurance race and after 30 laps it was still at the original pressure. The others that had air were making adjustments, we just topped off the fuel and switched riders.
VFR FLYER, Feb 18 2006, 08:14 PMthats true...........your tire will not weather crack on the inside where the nitrogen is............
if your worried about weather cracking on the outside of your sportbike tires................either start ridin it or...................most guys i know replace worn out tires every two years...........we try and wear out the whole tire tongue.gif
scooter996, Feb 19 2006, 09:10 PMRumor has it they wont leak as quickly as oxygen and tire pressure raminas constant. Nitrogen is 3 times more dense than air so you don't have to worry about slow leaks.
Here was a good article on it.
Nitrogen is also supposed to move through tire rubber three times more slowly. Without any impurities, nitrogen also is subject to less expansion and contraction as the tire heats up and cools down during usage.
767fixer, Feb 19 2006, 08:37 PMfor street use the use of nitrogen is a pure sales gimmick.
BDKesling, Feb 19 2006, 09:43 PMHell, you can use nitrogen all you want, I'm certainly not the nitrogen police.� You can also sleep on a bed of magnets and drink "demagnetized" water.� For that matter, replace all your bliker fluid with demagnetized water and watch your bike float 3 inches off the ground.� But for the love of Interceptors, don't say that nitrogen gas doesn't expand and contract with heat or diffuse as quickly as oxygen.
If anyone wants to know or see more about this, drop me an email, swing by West Virginia University, and I'll fill some balloons with pure oxygen, pure nitrogen, argon, hydrogen, carbon dioxide, helium, and whatever else I can find a tank of.� We'll pour liquid nitrogen on the balloons, watch them shrink, then watch them get bigger as they warm back up.� Then we'll light the oxygen and hydrogen balloons to make big fireballs, inhale the helium balloon and talk funny, pour the carbon dioxide balloon into a beaker and use it to put out a candle, and rub the other balloons on our heads and stick them to the wall.� Then I'll buy you a beer and we'll talk about oil.� goofy.gif
Brian
vfrjim2002, Feb 20 2006, 03:55 AMROTFLMAO. Was that extemporaneous? lurk.gif No matter, after that, I'll buy. beer.gif
