#1 Thread starter
[IMG=360]http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_31431.jpg[/IMG]
A while back my motorcycle was hit by a large truck in a parking lot. (Some of you might remember the post)
After waiting for the parts and time to do the work, I managed to get it all together to get ready for the riding season here in Colorado.
Here is the "how to" on replacing the upper fairing ona VTEC VFR.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_19795.jpg)
remove the mirrors and set them aside. I do it in order to make things easier.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_71702.jpg)
remove the trim covers for the windscreen.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_100130.jpg)
Then the windscreen itself.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_32467.jpg)
remove the left and right fairings.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_32256.jpg)
take out the 2 special clips by pushing in the center and then pull them out.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_104380.jpg)
remove the bezel by pulling,with medium force on the 2 pins on either side.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_83133.jpg)
remove the colored trim piece on either side of the bezel as well.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_69260.jpg)
the only thing holding the fairing now is 2, 10mm nuts...remove them and drop the fairing down
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_68483.jpg)
take all light connections off and the temp. sensor.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_40263.jpg)
While it is removed, take out the light housings (phillips head screws) and the temperature sensor.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_15509.jpg)
don't forget the grommets or
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_36532.jpg)
the screw clips to go on the new fairing.
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_31431.jpg)
install everything back on the new part and connect your lights. Check them before going too far into the install.
Go in reverse order as shown here and put it all together again.
Here is the end result....
(IMG:http://www.vfrdiscussion.com/forum/uploads/1142781988/gallery_416_1291_44632.jpg)
Good luck!!
Scott
LDSRIDER
Good luck!!
Scott
LDSRIDER
