I've searched around and can't seem to find it.
I would like to add a DPDT switch that would allow me to turn the fan on, off or run normally depending on switch position.
Has anyone ever done this? Any tips or suggestions?
I seem to remember a write-up that HS did that showed you how to add a manual fan switch to override it's normal operation.
Thanks!<{POST_SNAPBACK}>
I believe the fan is switched on by the thermostat trigger for the fan shorting to ground.I seem to remember a write-up that HS did that showed you how to add a manual fan switch to override it's normal operation.
I was just going to say I'd go for just manually on or normal, but then I realised that when it stays on and you're moving the fan is fighting against airflow, so your idea is a goodun.<{POST_SNAPBACK}>
UMM search not bump!~
<{POST_SNAPBACK}>
