#1 Thread starter
As you May know I change my own tires, up till now I just used a set of jack stands to balance my wheels. But I converted an outside gardening bench into a balancing stand VFR Wheel Adapter
The inside diameter of the hole is about 2" I found a 1 1/2 inch bushing (inside diameter) that fit just perfect, tap it in with a hammer and I am good to go.
(IMG:http://www.vfrdiscussion.com/uploads/balance/balance01.jpg)
One end of the bushing was smooth the other was threaded so I found some adapters that had 3/4" threads on the inside, and 2 end caps with 3/4" threads on each end, I used a 5/8" bore bit to cut a perfect sized hole for the 5/8" rod washers and bolts. ?I have it set out how it fits together.
(IMG:http://www.vfrdiscussion.com/uploads/balance/balance02.jpg)
The Bench
I cut a U shaped hole in the bench and reinforced it with 2x4s and put legs on the ends, leveled the table and screwed the legs on.
Here are the screen door wheels I used to let the rod turn freely, its just 4 sliding door wheels screwed into a 2 x 2 block of wood on each side.
(IMG:http://www.vfrdiscussion.com/uploads/balance/balance03.jpg)
(IMG:http://www.vfrdiscussion.com/uploads/balance/balance04.jpg)
(IMG:http://www.vfrdiscussion.com/uploads/balance/balance05.jpg)
I had to chisel out some wood to keep the rod from rubbing, it sort of screws side to side but not so much I cant get a good balance.
Here you can see how the adapter is used
(IMG:http://www.vfrdiscussion.com/uploads/balance/balance06.jpg)
The endcap on the right screw thru the hole in the wheel and it is all tightned down with the bolts on the rod.
(IMG:http://www.vfrdiscussion.com/uploads/balance/balance07.jpg)
Total cost for the hardware $18, bench was already there, the extra lumber was too. Home Depot, Sorry Lewis the post doubled up on me so I erased that one, with the questions you asked, I believe they are all answered now.
I just use the rod to tap out the adaptor when I am done a few gentle taps ?thru the hole and it comes out the other side.
The Bench
