#1 Thread starter
Not that it was ever common to start with, but it seems like the frame design on our bikes is now not that common out there, even to some extent, within the Honda product line. I'm talking about the extruded aluminum frame spar perimeter frame design on the VFR. Most bikes out there emply mostly welded aluminum plate construction to make up their frame spars and swingarms. Even the extruded aluminum frame spars on Honda CBRs are shrinking to almost vestigial pieces, mostly replaced by high pressure diecast aluminum pieces. Are the straight long spar designs on the VFRs becoming old-tech/obsolete/technical dead-end stuff?? This question popped into my mind when I was reading an article about the new Ducati 1098, which after all these years, still employs Ducati's now traditional, chromemoly steel lattice basic frame design. Seems like if there is anything that could have been a traditional frame design for Honda, it would be the extruded aluminum frame spar design that was carried on from the RC30, up to the present 6th gen. It would be truly sad to see something very familiar to many Honda riders, just mostly dissapear with the end of the VFR line. It seems like tradition in a lot of Japanese motorcycle companies does not carry over as much as they do with the Italians and to some extent, the Germans too.
Just a thought.
Beck
95 VFR
Just a thought.
Beck
95 VFR
