#1 Thread starter
I just picked up a refurbed Garmin Streetpilot 2610 for $349 yesterday. They also have the 2720 model for $449 as well. Both in limited supply, both come with City Nav software, both are touch screen operation.
See them here... Getfeetwet
The 2610 memory uses a CompactFlash card and they give you a small one (156 meg). I ordered a 2GB card and the Garmin mount with power/audio cord for $63 from Amazon. The 2GB card allows you to load the entire US in full detail, the mount and power cord enables you to have a locking mount to attach to a RAM mount and to power it off the bike's supply. (Neither has an on board battery like the Quest/2)
The 2720 memory uses Flash type and comes preloaded with the entire USA, so you don't need a bigger CF card. You will however need the Garmin mount w/ power cord. Approx. $28 at Amazon.
You'll also need to pick up a RAM mount or Techmount setup to mount the assembly to your bike. I went with CycleGadgets.com as they seemed the easiest to build the setup I wanted and pricing was roughly in the ballpark. Approx. $49 for all three pieces. The other sites come pre set and wouldn't work with my setup. Since I have the Scotts steering damper I can't use the fuel tank bolts, so I opted for the Clutch/Brake setup.
So, with the 2610 you can get in a real decent performing GPS for $462 while the 2720 will cost you $527. Not bad, and the cheapest I've seen so far...
