[image: View Post]Synaptic Misfire, on Feb 6 2007, 09:45 AM, said:
MiniDV format video occupies about 13GBs of storge space per hour.
High Def is roughly 40GBs of storage per hour.
This camera rig records 1 hour to 1GBs, that is about a 13:1 compression rate. More than likely using MPEG-4 compression which is passable at best as long as you don't reencode the video. For $849 I don't find this a very good deal here is why.
Auxiliary input compatible MiniDV camcorder - $399
520 TV Line (Highest Res) Bullet Cam - $175
LanC Remote for camcorder - $60
Pelican Case for Camcorder - $40
Mounts, Cables, Tapes etc. $100
Total: $774
Now it is a $100 less and this rig will produce 10 times the quality of the hard drive based rig and leave you the flexibility to edit and compress as you choose.
You decide what is better.
You know your stuff. Could you lend a little more advice? What do you think about this guys setups?
Chase cam
http://www.chasecam.com/pdr100-rear-72dpi.jpg
Looks like you add this add this and another cam for PIP.
http://www.chasecam.com/ss/SS1000front.gif
http://www.chasecam.com/ss/run7.jpg
Do you know of any other way to get PIP?
