Ever Removed Linked Cbs Brakes? - Suspension
6 posts Started 7 Mar 2007 Last recovered post 7 Mar 2007 Wayback Machine snapshot 30 Sep 2012
:idea3:
Hi guys
Anyone ever delinked the brakes by removing CBS on a VTEC ??
Any sort of experience is welcome
Anthony
I haven't but search De-link or delink or some such, there will be some good info.
Hi Anthony, :rolleyes:
I don't see any real benefit to removing the Linked set-up unless your changing out the forks to USD or some other adjustable forks.  The system works well and is unobtrusive in most situations and in my opinion will benefit every rider with the possible exception of the very best Racer types out there.  my $.02
To answer your question there should be several post that cover this if you try the SEARCH box or look in the Mods section. Many people have done it for their fork swaps and a few outside that to boot.
Good luck. :thumbsup:
Ditto advice above, unless you are changing the forks dont bother delinking. Just ride it for a season and you'll get used to it.
If you do de-link then your decals will be wrong like mine, no DCLBS on mine any more, might just put a line thru it with a marker http://www.vfrdiscus...tyle_emoticons/default/smile.gif
[image: View Post]veefer800canuck, on Mar 7 2007, 09:57 PM, said:
Linky: (or is that DE-linky?) http://www.vfrdiscus...tyle_emoticons/default/wink.gif
http://www.321igniti.../de_linking.htm
Because of the fork master cylinder, that's your best option.  I did mine, but if you don't know how to neutralise that m/c, don't bother.
End of thread · 6 posts recovered Wayback Machine snapshot 30 Sep 2012
