Now, I need to know if anyone has any experience with fitment on a v-tec.
I hope I won't have to manufacture anything for the lack of manufacturing capacity.
[image: View Post]JamieDaugherty, on Apr 21 2007, 10:28 AM, said:
Yes, you are going to need to make the shock longer. The F2 shock is 292mm long and the VFR800's are 324mm. Normally what I do in this situation is make an extension that fits between the lower eye and the shock piston rod. This extension will have the 5/8-18 threads on each end to make with the Fox's threaded adjusters.[image: View Post]Rice, on Apr 23 2007, 05:32 PM, said:
Yes, you are going to need to make the shock longer. The F2 shock is 292mm long and the VFR800's are 324mm. Normally what I do in this situation is make an extension that fits between the lower eye and the shock piston rod. This extension will have the 5/8-18 threads on each end to make with the Fox's threaded adjusters.[image: View Post]Baileyrock, on Apr 23 2007, 06:43 PM, said:
Yes, you are going to need to make the shock longer. The F2 shock is 292mm long and the VFR800's are 324mm. Normally what I do in this situation is make an extension that fits between the lower eye and the shock piston rod. This extension will have the 5/8-18 threads on each end to make with the Fox's threaded adjusters.[image: View Post]Rice, on Apr 23 2007, 07:07 PM, said:
I have an idea.[image: View Post]Baileyrock, on Apr 23 2007, 09:25 PM, said:
Sebspeed's also in NY and is a great fabricator, he might be able to come up with a spacer for you. Really you can use almost any solid bar, pipe, etc. with a hole through it.Sebspeed's also in NY and is a great fabricator, he might be able to come up with a spacer for you. Really you can use almost any solid bar, pipe, etc. with a hole through it.
Yeah, maybe I shoulda done that before I sent it out... :goofy:
If you're not in a hurry Dmitry, you're welcome to come visit me in June, and I can mod your bracket for you! Or, if you figure out your dimensions, send the piece to me and I'll take care of it.
Are you sure the F2 shock has a 1000lb/in spring on it? That's pretty heavy for an F2, unless the rider was a really big guy. If so then you have really lucked out!
Also, all of the information I have, both catalogs and in my notes, state that all VFR800 shocks are 324mm. Where did you find it shown that the V-tecs are 312mm?
Thanks for the info!Actually what you are experiencing is the stiffer rear spring pushing a bunch of extra weight to the front suspension making it work harder IMO or the settings on the Fox are way off also causing weight transfer issues. :unsure:
Set Sag front and rear(as the rear spring should also effect front) back off all the way on rear Comp. and adjust rebound first. You really want fairly quick rebound without letting it bounce back up, maybe a second delay. Then adjust the comp.
You might have to jack it some extra front preload to help deflect some of the rear transfur, but stiffer fork springs are the min. way to go. For that rear spring I would look at .85 or .90kg fork springs.
I'll do sag this weekend. I am also getting ready to order some springs and fork oil. I don't think my oil has ever been changed since new.
What weight oil do you recommend? We seem to be the same weight (190)
I will get the .90kg springs.
Also, which knobs control rebound and compression on the Fox shock?
The red knob on the remore can that has 8 notches is compression?
The blue collar on the bottom of the shock seems to be turning indefinately in either direction. How do I know how where it is and which way to increase/decrease?
Sorry for fludidng you with silly questions :rolleyes:
Aftershocks built my forks and I don't know what weight oil they used, but they did use Ohlins oil. He said it last longer than many other brands. The weight of oil used can also depend on if you have revalved the forks or just using stock valving.
You are correct that the red knob is Comp. and the blue (on the bottom of the shaft) is rebound. On a Fox the rebound will bottom out at full stiff turning it clockwise, turning CCW you will feel it drop tension somewhere between 20-30 clicks out(full soft).
Yeah, Ohlins must think the same thing considering how much they charge for the fluid.
You have the rebound backwards - as looking down from above with the shock installed CCW is hard and CW is soft. I doubt you'd get 30 clicks out of it, somewhere around 20 is max.
