Boy was I wrong on my theory related to rear spring rate.
I had Phil at Aftershocks re-valve and re-spring my Vtec forks last summer and while I felt an improvement with the forks I wasn't happy with the bikes handling.
I installed a CBR Ohlins on the rear at the same time as the redone forks, but I did not increase the spring rate for fear of a horrendous ride and I thought that if I could get the proper SAG with the stock rate spring than everything was cool. As mentioned I wasn't really impressed with the set-up and was considering another complete front end swap to a F4i, but after another conversation with Phil I was convinced to try a heaver rear spring rate first in order to bring the bikes balance back closer to what Honda originally had.
Phil installed .95 kg forks spring and recommended 19 kg rear spring to maintain balance, so I ordered a 19 kg from Ohlins.
Today was my first ride with the new spring set-up and I haven't even set proper SAG or dialed in the shock yet.
Results, This thing is on Rails ! :goofy: Turns in better, holds a line better, does everything better. It has transformed the bike completely and I can only imagine how it will feel after I set Sag and spend a day on Comp. & Rebound settings.
Amazing !
straight numbers are 30% stiffer on the front springs (.74 to .95) Rear spring in now 25% stiffer (15.5 kg to 19.3 kg)
added from a newer post 10-19-07
Don't forget that with all this Forking around you guys are doing to the front that you need to consider increasing the rear spring rate to better maintain the bikes balance and get better performance from your forks too.
I first did the forks with valving & .95's and I installed an Ohlins on the rear with a stock rate spring, though it was an improvement it wasn't right.
When I finally installed the proper rear spring on the rear (19kg for my 200 lbs) it transformed both ends of the bike!!! fing02.gif
Turns out running a soft/stock rear spring with new stiffer screwed up feel on both ends because the stiff front transfered more weight to the already to soft rear making it feel worse and the stiffer front tended to bounce across many bumps and irregular surfaces instead of absorbing them.
I had a old post about it " transformed" don't know if it's still around, but consider stiffening the rear spring in close to the same percentage as the front and you'll be much happier.
(note if you just commute and don't hit the twisties you may never notice it) cool.gif
update 1/31/2010
After years of learning, reading and sharing set-up info mostly with Pete McCrary we realize that the ONLY way to achieve proper spring rates on out VFR's(or any bike) is by achieving BOTH desired FREE 7 RIDER SAG numbers! Rider sag numbers alone mean ABSOLUTELY nothing by them self in relation to determining correct Spring rates!
I plan to add real world spring rate numbers here from members who have done it the right way achieving desired Free & Rider Sag numbers!
I weigh 190 lbs and have a 19 kg(1065 lb) spring on a Vtec, I get the following numbers measuring by myself:
Free sag- 12mm
Rider sag- 32mm
These are real close for what I want, but I want to check it again check it again w/help to be more accurate.
So IMO if you weight 190 plus you'll need at least a 19kg spring to get close, I'll be trying a 20 kg real soon and post my numbers.
BTW I started w/a 850 lb spring on my Ohlins and had No free sag w/35mm rider sag.
jasonsmith:
220lbs no gear. I wear full textile top to bottom. 07 RWB VFR
Parts
Elka 3-Way with remote pre-load - Rear spring rate - 1100lb or 19.6kg (STOCK 15.3kg) 28% increase.
FRSP S3732095 RT Front Fork Spring 36.7x34.5x315 .95kg from RaceTech (STOCK .74kg) with valving (see below) to compensate for the increased spring rate. 28% increase.
RaceTech
G2-R Gold Valve Kit - G2-R Next Generation Compression Kit
FMGV S2040G
Fork Rebound HFR Gold Valve Kit-Racing (Hi-Frequency Response Race Rebound Gold Valve)
FRGV SR2001
Stock Oil Weight = Honda SS-8 (10wt)
New Oil Weight = Maxima 5wt HP Fork Oil (RaceTech recommended US1 which is 2.5wt - 5wt from what I can tell)
Numbers
(with full gear, 3/4 full tank)...
Front:
Sag - 35 mm (3 lines exposed on the pre-load adjuster)
Free Sag - 15mm, down 7mm.
Rear:
Sag - 35 mm (23 out of 52 available clicks in on the pre-load)
Free Sag - 7mm (With a 1200# rear spring I would guess my free sag could be increased to 15mm or so at 35mm rider sag)
