Riding W/ Leaking Fork Seal
An uneven level of fork fluids (one fork had just much less than other) caused my lowside in a "sort ot extreme breaking" situation. He should avoid compresing the forks as much as he can. If the fork are pushed and compress and one of the fork seals is leaking, that will result in different compression 'strength' of each fork and end up in the tank slapper or similar... So probably slow ride home is in order.Got a call from a friend that is out on a road trip to see some relatives 600 miles from home. He said the bike (VFR) has been sitting in their garage for the week that he has been visiting. He went out today to get things in order for his return trip and discovered about 6 - 8 drops of oil on the ground. After a quick look-see, he discovered the right seal is leaking a bit. I figure the heat in the closed garage forced the oil past the seal enough to have a few drops make it to the ground. Now, as the original topic questions, is their any concern in riding it home or should he get it repaired on the road before his return? I think it would be OK for now but told him I would ask the crowd here. What say ye?
As for me, the lowside was unexpected (but the bike was 3 months new to me and I have never checked the forks) since I was not breaking super hard (I did not lock the front wheel) but it probably saved my butt in bigger scheme of the things as there were 3 deer standing in front of me.
Martina
Disclaimer: I am not a mechanic so I could be completely wrong. Maybe some of the more mechanically advanced member will chime in.
Despite what Martina said, I doubt it would make much difference to the handling - there are bikes that have the each leg performing slightly different duties, with no noticeable affect on steering, braking, etc.
Besides, so far you're only talking about a few drops - it may not get any worse.
He could lift the dust cap from the leaking seal, and swab out the oil that is no doubt pooled in there. This might be enough to get him home without any more oil dripping down the outside of the fork. He might also choose to wrap a rag around the fork leg, and zip tie it in place, to catch any oil that is getting out. Then just keep an eye on it, check it when you stop, and change the rag if it's getting slimy enough to drip.
He might even be able to fix the seal pretty easily. Sometimes all that's happening to cause the leak, is a bit of grit on the seal. Take a piece of old film negative, or other similar plastic item, and work it down between the seal and the fork tube. then work your way around the tube, and push the grit out. If it fixes it, yay! If it doesn't fix it, he's going to be replacing the seal anyway, so nothing's lost.
One thing for your friend to consider. I have often heard of shops installing new seals, damaging them during installation and they end up leaking again in a short time. If he is 600 miles away from the shop he is probably going to be SOL.
+2 on that one from me. It happened twice from the dealer, when they changed it before I bought the bike, and then about 25 days later. On the second repair I didn't even get the bike back right away because it failed on the test ride. 45 days later the other one failed. Most of my ownership ~3000 miles have been on leaking fork seals. I replaced them ~1000 miles ago myself and still no problem. <knock on wood>
Keep in mind, I think in my case, something can be wearing those things abnormally like the upper and lower slider bushings. The seals can also be installed easily upside down, or easily damaged on installation.
I'd ride it home and do the paper towel band-aid. There is A LOT of fluid in there; over a quart....tell him to save the oil that has escaped so he'll know when he's low..... :thumbsup:
