Gosh I'm uneducated..
Regards,
Bruckner
[image: View Post]vfrjim2002, on Oct 26 2007, 03:16 PM, said:
The tire isn't cupping it's "squaring" off. Unless you're blessed enough to live in an area surrounded by winding roads it will (I think I'm safe in saying this) always happen.[image: View Post]Beck, on Oct 27 2007, 08:18 AM, said:
Themore common (normal? at least for some brands like Dunlop) cupping happens on the front tire. Never really heard of anyone else here that suffered from rear tire cupping.[image: View Post]Bent, on Oct 26 2007, 11:23 PM, said:
Just a free opinion, the BT020 is probably the worst performing motorcycle tire ever made for twisties in modern times.....right there with the Pilot Road. FWIW.[image: View Post]HispanicSlammer, on Oct 26 2007, 06:52 PM, said:
Rear tires will in fact cup! You can feel it like a shallow bowl in the tire, and it usually happens where the rain grooves are. You said you get a wallowing in the curves which leads me to believe that your rebound is not set high enough. Try a click or two on the bottom of the shock to increase the rebound, that should smooth it out some and give you a more planted feel in the turns. If the bike feels unstable loose and bouncy the tire is actually bounding out of the bumps and leaving the ground when it comes up on the rebound stroke and then comming back down hard creating cups in the tire when stikes the ground. Its not a compliant ride. Increase the rebound - if you go too far it will feel hard and bumpy.[image: View Post]superfunkomatic, on Oct 26 2007, 06:51 PM, said:
Just a free opinion, the BT020 is probably the worst performing motorcycle tire ever made for twisties in modern times.....right there with the Pilot Road. FWIW.[image: View Post]Bent, on Oct 26 2007, 07:23 PM, said:
Just a free opinion, the BT020 is probably the worst performing motorcycle tire ever made for twisties in modern times.....right there with the Pilot Road. FWIW.[image: View Post]SEBSPEED, on Oct 26 2007, 07:17 PM, said:
Just a free opinion, the BT020 is probably the worst performing motorcycle tire ever made for twisties in modern times.....right there with the Pilot Road. FWIW.[image: View Post]Bent, on Oct 27 2007, 12:07 AM, said:
"We" = Negatory.... :wheel:[image: View Post]Bent, on Oct 26 2007, 04:23 PM, said:
Rear tires will cup.[image: View Post]TommyHoffman, on Oct 27 2007, 10:28 AM, said:
Rear tires will cup.[image: View Post]Bruckner, on Oct 26 2007, 09:52 AM, said:
Basic question you'll say but here, lately I found that the bike was less than rock solid at highway speeds in curves, I feel a bit of a wobble, could be due to lower temperature tire operation (low 40Fs), but then I looked at the rear tire closely (never done that before!) and found that the center section was considerably more worn than the sides (obviously?), when I run a finger over the tire I feel the edges on either sides, but this could be entirely normal.
