Shots From The Bars
10 posts Started 1 Nov 2007 Last recovered post 4 Nov 2007 Wayback Machine snapshot 14 Apr 2013
No this thread is not about this���.Although it is just as much fun but not particularly productive or praiseworthy.
From VFR bars the shots are lasting and ultimately pleasing as well conducive to long term memory and better trip reports. AND even if the shot is poor it does not leave a bad taste in your mouth. Memories!!!!!!!!!!!
Sedonna
Over the top in the Sierras
About to make the pass and the only MCs I passed on the trip. Heading East on AZ 60 about this time two years ago towards Globe and 191.
On the way to the North Rim of Grand Canyon - ie system works great on both bikes.
Crater Lake
Lots of VFRD members shoot from the bars (beats from the hip) � some use videos but I STILL prefer still. Of course, HS does both � look at his latest in Monument Valley.
I have used both my first generation Canon Digital Elf (2 meg � S100) or the current gen Lumix (7 meg - LS70) Panasonic cameras on my left grip RAM mount. Both are wide angle compact cameras. More about the cameras later.
I prefer the camera on the left Grip RAM mount and keep the Zumo on the Tank Mount. I have settled on the long RAM bar to lift the camera over the screen on the VFR and over the vent on the Wing.
From the left grip it is easy to operate the only two controls that matter � on/off and shoot! Sometimes even a zoom!
Ultimately, I may go to a brake reservoir mount as it looks cleaner. And your clutch housing is less likely to move.
Next Why I use two cameras - RAM and one in the tank bag.
Nice post... :thumbsup:
Is that the 5.25" clamp on the handlebar mount? Does it shoot over the windscreen?
It is the standard "R-A-M motorcycle mount for clutch/brake reservoir" setup. I will try to find more pics.
Will talk about Pro/cons of Windscreen later. Shoot over the VFR and thru the Wing though!
There was already that much snow????? Wild!!!!!
On tour, I use two cameras - saves wear and tear and droppppping! One Camera on the RAM and the other in the trunk/tank bag for walking and get the bike/ in the frame shots. Ie prove you were there shots.
I use this RAM camera adapter to screw on the camera ����..
about $10 attachment screw mount for Camera
As a result when you jump off, it is a PITA to take the RAM camera off and then back on for repeated scenic stops. Once is ok but a stop every 10 miles does not cut it. This is on my Sierras tour in 06 ............back when I took the camera off. Too much hassle means one thing � no pictures!
You can see the Screw standing tall :unsure: . :thumbsup:
Better to leave it on all the time. Obviously you can still take photos from the RAM camera when you stop but �����..
.........when you step off the bike grab the other camera.
I think one time in an internet daze, I saw a camera quick disconnect mount that worked with the tripod screw mount but have no idea where or when���.
So when you want the obligatory shot to show the bike/steed was there.
You take your camera out of your tank bag/trunk. Off RT36 in Northern California.
Lassen NP � somebody wanted more snow??
I use a Kodak with 10x zoom to get the walk arounds. I have put this bigger camera on the RAM mount once and it was just too bulky.
This means that your RAM camera is always available to take the shots that you would never get from a tankbag or even around your neck
You take shots you could never get with a stop ...............even if you took the time.
Or when your riding buddy has to stop 3ft into the week long ride so his wife can help him read his Zumo screen and remind him to be a good boy. You can circle back and snap without taking off all that F���. gear!!!!
For BailyRock Eyes Only�����..Please Note that is a LIGHT PEWTER METALLIC BOX behind the ���..well GRAY BMW Rt1100
Next Security���..
With X-mas approaching with the inevitable questions "what do you want for X-mas" this is it :thumbsup:
I use a sophisticated cloaking device for security. see Romulansbirdofprey.com for more details
A better shot of the Cloaking in action - you can barely see it :beer:
it uses 12 volt power which I run from my aux fuse box.
to keep them guessing sometimes I use the Old beat up Black Helmet defense or What a POS!
Or No Defense
In the evening of course, the camera comes off so you can get a burger shot (see Sebspeeds Album). I find it is actually faster to remove the RAM mount and the camera as a unit. Watch for the bolts on your RAM arm to explode all over the parking lot. :pissed:
Compact/small cameras are best for the evenings when you can stick them in a pocket and have a brew.
Next thru the screen or over and more on RAM mount
Does the camera get dirty with bugs and stuff being mounted there?
I was just getting to that...................
Hint ................kind of depends if you live in Florida or California.
No water and plenty of dry heat..............equals no bugs. Vegetation and bugs don't do well in Fires!
San Diego Landscape circa 2007 fire season.
C14 coming up on my tail ....................... has the biggest stinger in MCing.
Another shot of the mount sans camera.
More on bugs next <_<
That shot of Mt Lassen wasn't anytime recently. It's been two years since we had that much snow.
Late May this year...........2007
Not sure if this was from my RAM camera or not. The Top
RAM Zumo shots............ :unsure:
Great road coming up from the South BTW.
End of thread · 10 posts recovered Wayback Machine snapshot 14 Apr 2013
