wera803
MuddDawg
jeremy556Honda recommends 36/42 f/r, IIRC. In twisties I run 34/38 or so.
My question is what does the Motorcycle manufacture know about whatever tire your running? Shouldn't you go by the tire manufacturer's recommendations since they designed the tire with whatever rubber compound?
They don't know. They recommend the pressures for the one or two tires they recommend for the bike. Of course how does a tire manufacturer know what bike you are puting the tires on either?? Should the pressures be the same for a Hayabusa and GSXR-600?? There is quite a bit of weight difference between the two.
I think it is just one of those things that you have to play with to see what works best for you, your bike, and your riding style.
Take the cold tire pressure.
Ride the bike normally to heat up the tires...
Take the Hot Pressures of your tires.
You should be looking for a 5 % to 10% increase from cold to hot.
If you have more than 10% increase,,,, add air.
Example:40x5% is 2 pounds air ; 40x10% is 4 pounds air.
So if it reads 45 pounds of air. I need to add enough air ( how much ? ) to keep it under 10% increase ( 1 pound at a time,till I know what MY bikes cold tyre pressure is on a average temp. day ).
This is a tyre formula that was posted on here somewhere. Now I've been playing with it the last couple of days, and for it to work on my bike I've had to go up to 44lbs. on the rear cold to keep it under 10%(4 lbs.) when warm. The front tyre is right on at 36, and is only 38 warm(5%).
What I'm wondering is 42lbs. is suppose to be the max, but it runs cooler at 44 (according to formula). P.S. I weigh 230 lbs......
Has anyone worked with this "type of formula", and to what results?
I'm also 50/50 smooth to bumpy roads so I'm wondering about lack of tyre flex?
Anyone have any ideas? ..... Monk
Edited 24 May 2009 by Monk
