So I was checking the K&N air filter on my 04. I noticed the thorottle bodies were a little dirty so decided to clean them. I used a little tooth brush and some intake cleaner, it took the carbon right off. I was spraying the can down one of the throttle bodies, holding the throttle wide open. The rubber band form the can that was holding on the little straw breaks off and fly's up in the air, right in front of my face. It went down a throttle body and came to rest ot the top of the runner on the intake plenum.
Luckily it is in sight. I have a pair of grabbers at work that I will be able to sneak down there and get it out. I have no doubt It will come right out. Some of you probably have the same tool. Long skinny, slinky thingy with a thumb trigger. There are four claws that spread out on the other end.
Anyways, just thought i'd share. That would never happen again in a million try's.
