Finally got my Stebel Compact Nautilus installation on my 6th Gen finished and tested last night. Wow! I am more than pleased with the sound.
I did my installation a little differently and am very happy with the results.
1. I seperated the compressor from the megaphone/horn body with a good whack on the bottom of the compressor with a rubber mallet. I then mounted the compressor on to left frame right under the bracket the left fairing bolts to. I drilled a couple of 6 mm holes through the frame and then used the rubber cushioned "C" clamps Anchor makes (availabe at any West Marine or Boater's World). This keeps the compressor under the fairing bodywork and also allows it to be mounted vertically as they recommend.
2. I mounted a 40 amp relay (not the crappy one that comes with their kit, but a good one from Jim Davis) right in front of the R/R on the right side of the bike. This allowed the stock horn wires to plug right in and act as both the trigger wire and ground wire for the relay.
3. The tough part - I fabricated/welded up a bracket that bolts to the location of the stock horn. I used a half round section of 1�" muffler pipe along with some other metal straps to weld all of this together. It allowed me to place the horn facing forward (as it should) but it really snuggled it up out of the way of the exhaust pipes, front fender, etc. You really have to look hard to see it.
4. I installed a brass barbed fitting into the hole in the megaphone body and then ran a 15-18" piece of 5/16" I.D. hose from the compressor to the megaphone horn unit. Hose clamps at each end of course.
Thing works great and you really have to look up under the front of the bike to even know it's there. It was a lot of work but it isn't hidden behind any body work or pointed sideways. Used stainless steel hardware all the way and 10 ga wire for the compressor. Power comes from a Tightwad 4 gang relay under the seat. Running a 20 amp fuse.
The sound goes out in front of the bike unobstructed so it's full effect can be "experienced".
Pics to follow soon.
