Removing Bar End Vibration
6 posts Started 16 May 2008 Last recovered post 21 May 2008 Wayback Machine snapshot 10 May 2010
Hey guys,
thought I would share an el cheapo handlebar buzziness remover
step 1 remove end weights
step 2 go to Wal mart and buy el cheapo caulk- costs $1.00 per tube- I used my caulk gun
step 3 cut a small bit off off caulk tube and insert into handlebar end and squeeze away
step 4 reassemble bar end weights.
It worked wonders on my 96 gpz 1100(test mule)-probably cut the vibrations down about 80%
I don't think the OEM handlebars for the 6th gen have any hollow part of the tube to do that?
Someone correct me?
Someone correct me?
I believe once you remove the part that the bar-end weight bolts to, the rest of the bar is hollow. I might look into doing this on the Helis next winter.
I have a 2003 and never noticed any buzzing in the bars. Even after switching to the Heli's. Adding a good set of aftermarket grips might help a bit. I have the Progrip 719's.
I have heli bars and then I installed some of the throttlemeisters. I feel no buzzing at all. But I did buy the heavy throttlemeisters. And what Johnmark101 said, progrip grips helped too.
Filled my heli's with gel, added heavy custom bar ends, and P.G. 714's. Works for me.
End of thread · 6 posts recovered Wayback Machine snapshot 10 May 2010
