First you have to remove the wire and take off the plastic shrink wrap (exacto knife does wonders) then pick out the hot glue from the top and bottom of the molding. Then lift off the moulding from the speaker chamber. Push out the speaker from the sound hole with some kind of small rod or plunger. I did all this before I decided to document it for vfrd content? Opps.
Now you need a set of doner wires, having ripped the old wire off its almost impossible to soldier earbud wire back together cause it is made from coated wire, sometimes wrapped with nylon thread. Solider does not like to adhear to this kind of wire. luckly if you remove the doner wire from a cheap set of ear speakers the manufacture already prepped the ends to soldier. I got a free set of ear speakers from somewhere - cant remember but they were really uncomfortable and the sound wasnt so good, no way would I use them for riding! ER-6 speakers from Etyomotic are designed to fit inside your ear comfortably and they seal out a good deal of ouside noise, so you dont have to crank up the tunes. They act like ear plugs when you turn off the sound. Ideal for riding IMHO!
Find a doner pair Harvest the wires
pull on the earphone edge they usually just pop right off
With a hot solder iron heat up the solder and remove the wires from the speakers then untie the ends and thread the wire out of the housing
Notice the color of the wires Right speaker has a red wire Left speaker has a green wire the ground wires go on the left side of the speaker bond pads - this is standard
Thead the wire through the molded holder there is an open side that goes on top - when you take it apart there is some hot glue you must pick out with a pick careful do not break the molded plastic.
Solder the new leads to the er-6 speakers after you thread the wire through the top - careful do not break the flexible bond pads tie a knot at the end
Here you should test the connection and see if you have sound in both speakers before you put them back together!
Slide the speaker into the chamber I used my forceps to push it back inside until the plastic tines on the side snapped around the speaker
gently slide the moulding back over the clear speaker chambe they snap into place pull the wire taught as you slide the moulding to the speaker then replace the band around the end
almost done
cut some shrink wrap to size slide it over the body
using a heat gun shrink the wrap dont linger with the heat gun or you will melt the speaker body
almost done
