Also, how easy are they to install?
[image: View Post]SilverRocket, on Oct 20 2008, 09:10 PM, said:
My plan is to keep riding the bike through most of the winter. With the weather cooling down this week, I realized I need to get heated grips and soon!!! What are you guys using. What works best? Looking for cheap but reliable.[image: View Post]SilverRocket, on Oct 21 2008, 12:10 AM, said:
My plan is to keep riding the bike through most of the winter. With the weather cooling down this week, I realized I need to get heated grips and soon!!! What are you guys using. What works best? Looking for cheap but reliable.[image: View Post]timmythecop, on Oct 21 2008, 09:10 AM, said:
i will be activating my symtecs in about 10 minutes. Installed them in about half an hour and havent been able to use the high setting yet.[image: View Post]VFR_Brandon, on Oct 21 2008, 03:03 AM, said:
My plan is to keep riding the bike through most of the winter. With the weather cooling down this week, I realized I need to get heated grips and soon!!! What are you guys using. What works best? Looking for cheap but reliable.[image: View Post]Tightwad, on Oct 21 2008, 08:24 AM, said:
I used Dual Stars. They don't get overly hot for me, I can run them on high with little problem, although I haven't needed them much so far this year. I used my own two position switch, instead of the monstrosity they came with. You can hardly tell they are installed. I tapped into my auxiliary fuse panel for the power supply.[image: View Post]SEBSPEED, on Oct 21 2008, 08:44 AM, said:
I used Dual Stars. They don't get overly hot for me, I can run them on high with little problem, although I haven't needed them much so far this year. I used my own two position switch, instead of the monstrosity they came with. You can hardly tell they are installed. I tapped into my auxiliary fuse panel for the power supply.[image: View Post]SEBSPEED, on Oct 21 2008, 01:44 PM, said:
I used Dual Stars. They don't get overly hot for me, I can run them on high with little problem, although I haven't needed them much so far this year. I used my own two position switch, instead of the monstrosity they came with. You can hardly tell they are installed. I tapped into my auxiliary fuse panel for the power supply.[image: View Post]SEBSPEED, on Oct 21 2008, 07:44 AM, said:
I used Dual Stars. They don't get overly hot for me, I can run them on high with little problem, although I haven't needed them much so far this year. I used my own two position switch, instead of the monstrosity they came with. You can hardly tell they are installed. I tapped into my auxiliary fuse panel for the power supply.[image: View Post]Beck, on Oct 21 2008, 09:28 AM, said:
Here's a pic of my custom Hi-off -low position switch I installed for my Symtec grip heater system, on my left handlebar switch housing.[image: View Post]Beck, on Oct 21 2008, 09:28 AM, said:
Here's a pic of my custom Hi-off -low position switch I installed for my Symtec grip heater system, on my left handlebar switch housing.[image: View Post]Tightwad, on Oct 21 2008, 09:54 AM, said:
I used Dual Stars. They don't get overly hot for me, I can run them on high with little problem, although I haven't needed them much so far this year. I used my own two position switch, instead of the monstrosity they came with. You can hardly tell they are installed. I tapped into my auxiliary fuse panel for the power supply.[image: View Post]SEBSPEED, on Oct 21 2008, 09:40 AM, said:
I used Dual Stars. They don't get overly hot for me, I can run them on high with little problem, although I haven't needed them much so far this year. I used my own two position switch, instead of the monstrosity they came with. You can hardly tell they are installed. I tapped into my auxiliary fuse panel for the power supply.[image: View Post]SEBSPEED, on Oct 21 2008, 10:40 AM, said:
I used Dual Stars. They don't get overly hot for me, I can run them on high with little problem, although I haven't needed them much so far this year. I used my own two position switch, instead of the monstrosity they came with. You can hardly tell they are installed. I tapped into my auxiliary fuse panel for the power supply.[image: View Post]spotthedogg, on Mar 20 2009, 12:23 PM, said:
Should a person not fuse the Symtecs? If so what size fuse, I have read different opinions on what the actual draw is.[image: View Post]ECX585, on Mar 20 2009, 07:44 PM, said:
I've been looking into the HOT GRIPS today, and several websites say that they're being discontinued. Anyone know what's up?
