Honda Saddlebag Attachment
5 posts Started 22 Oct 2008 Last recovered post 22 Oct 2008 Wayback Machine snapshot 12 Apr 2010
I'm negotiating the purchase of a 2002 VFR (non-ABS)from a private party. The bike does not have saddlebags. Neither the owner nor any of my VFR friends know if the 2002 has the same mounting system as the 2003 - 2008s.
Has the attachment system (brackets, footpeg brackets, etc.) changed from 2002 to 2008?
Thanks for any info you can share.
Commin' Back Home
Welcome! :beer:
All bracketry remains the same 02-09
[image: View Post]dutchinterceptor, on Oct 21 2008, 08:41 PM, said:
Welcome! :beer:
:+1:
:offtopic: Some unsolicited advice for when you install them... Don't tighten down ANY bolts until everything is attached. Leave ALL bolts just bearly threaded. I figured that it would be bolt and go when I did it :pissed: , but you need as much play as possible to fit everything together!!!
That is definitely good advice. Even with leaving as much slack as possible, I still struggle to get everything to line up properly to get the last couple of bolts in. :mad:
End of thread · 5 posts recovered Wayback Machine snapshot 12 Apr 2010
