Congrats... I have and Black 06' also. I would recommend a "Guardian" all weather bike cover. I used one during the winter months in the northwest enviroment and it worked great. I would also recommend a pcIII to help with the v-tec engagement if you don't already have one.
[image: View Post]HorribleHutter, on Nov 3 2008, 03:23 PM, said:
I had a '96 CBR900RR new back in '96 and loved it, but this bike is more suited to my current riding style than a CBR1000RR.
Need some advice on the following upgrades:
Frame sliders
Gel hand grips?
Mesh jacket with armor
Tail tie down net
Snug fitting bike cover, lockable
Lock or method for locking on the go (I have a heavy 80mm Kryptonite cable I use at home)
Gloves
Now ask us what type of oil to use, what's the best tire and if you should change your sprockets every time you change your chain.... :blink: :laugh: :laugh: :laugh:
It's a great bike! Happy riding.... :biggrin:
looks like your have the corbin seat, did it fit well?
Frame sliders
Gel hand grips?
Tail tie down net
Gloves
OK. I know the guy never did an oil change in his 966 miles and over a year and a half, so what oil and stock filter and how often to change oil? Even though I already have a spare rear tire in the shed, what touring tires are best? I don't putt around, but I don't think my riding requires a sticky tire. Chain/sprocket/tires/valve adjustment/Coolant flush at 16K miles? On my '96 CBR90RR I had to tighten the chain each time I cleaned and lubed it. Do I have to tighten the chain on this bike, or does it have a spring tensioner?
Todd was joking here, hence the emoticons after his statement. The search function on the top tool bar will be your friend for all of those questions as they all have been beaten to death. And as for the drive chain tension, you have to adjust it as needed. I've never seen a tensioner on a drive chain. Enjoy the bike, it doesn't seem like the previous owner did much enjoying of the VFR!
Congrats on the new to you bike! Although, you do realize that the pearl black absorbs the most light and is therefore the slowest of all VFR's? :biggrin:
Oh, and maybe you should post some pics so we all believe you.
Is there a write up on here about the pcIII? Is that a piggyback computer or something?
I clay barred the pearl black, so now it's as fast as the fastest! :goofy:
I tried to upload a photo, but it said it was too big probably because it was teken at 10 megapixels. I'll take some low rez pics in the next couple of days.
All joking aside on the oil issue, if it's never been changed since the bike was new it needs to be done ASAP. It's supposed to be done after the first few or several hundred miles.
Frame sliders - contact VFRD member Radar to see if/when he's making more 6th gen. VFR sliders. Or Google R&G sliders and order a set. Radar's are cheaper and very well made but you'll have to modify your coolant bottle for the install.
Tie-down or cargo net - my 6-hook cargo net doesn't work well with my VFR, so I use bungees - usually the flat strap kind I've bought at Wal-Mart in the automotive section.
Locks - I use a disc lock with orange reminder cable. Minimal protection, but if you can at least dissuade amateur crooks you've done a lot.
Not sure about the Corbin, but the rear seat cowl does not work well with the Sargent. I've never put mine back on after swapping out saddles a couple years ago.
I found a round magnet that fits over the key slot in the ignition. I place the magnet there every time I remove the key as a reminder to remove the disc lock. I have never forgotten to remove the disc lock. :biggrin:
Didn't you get the memo from Billy Mays? There's a UV repellent wax out that's good for 15hp. I used it and could hardly keep the front end of my bass boat black 06 on the ground! The guys on the red ones were astounded when I passed them. It gives almost as much of a performance boost as running a mix of 10-40W and 20-50W valvoline car oil. Look for it on TV after 2:00AM. I just leave the TV on while I sleep and Billy wakes me up with his screaming sales pitch. If you order in the next 15 minutes they'll throw in a free set of steak knives. :laugh:
Actually Asphalt absorbs the most sunlight. I use this effect to enhance my travels through the time/space continuum...... I must be off!!
^ this is why black is the fastest, it absorbs all light around it, this creates a black hole for traveling at or faster than the speed of light, covering vast universes in mere seconds which even the red ones cant do. :blink: :biggrin:
No - not a black pearl. Haven't you heard about the problems? Oh, wait, your is a 2006 which is OK. It's the 2003 Black Pearl that has issues. http://www.imdb.com/title/tt0325980/
I ordered the Joe Rocket Phoenix 5.0 jacket and 2.0 pants from NewEnough.com Thanks for the advice.. saved me at least $50 and it gets here Monday before I leave for Mexico on Tuesday.
[image: View Post]leanit, on Nov 4 2008, 05:26 PM, said:
Frame sliders
Gel hand grips?
Tail tie down net
Yep, and I got that Sham Wow to dry it off after washing it! LOL
End of thread · 25 posts recoveredWayback Machine snapshot 12 Apr 2010
