ok guys, heres one for ya.... first off:
02 vfr,k&n filter, o2 disconnected and resisitored, brand new complete wiring harness from honda. otherwise stock
after I got the bike back from honda for recall wiring harness, exhaust smells rich and bikes max speed is 120ish(indicated) I don't normally ride that fast, but if power is missing there, it must be missing from other places too. it doesn't have as much snap as it used to.
I thought about just biting the bullet and getting a power commander to remedy this, but I would rather have it running at spec before anything else.
bike temperature seems normal, 172 on the highway, anything above that in the city
researching on here found someone with a similar problem and one answer was that the computer was stuck in 'warm up mode', shooting a rich mixture to help warm the catalytic converter. if this is a valid suggestion, what would a fix be?
WORST case scenario I could take it back to honda and tell them to remedy this, but I would much rather do it myself
is there a way to pull a code from the computer to tell me what, if any errors it is throwing out?
