I was just about to take the bike out for a nice 26 degree spin around town, but I think my ignition switch is frozen.
The bike has been parked outside and the cover blew off. I have it parked with the bars locked. When I put the key in, it won't turn. I didn't twist too hard for fear of bending or breaking something.
Has anyone ever had this problem at temps above freezing? I just want some peace of mind that it's only the temperature causing my problem.
The lock is on top moisture can easily get in, try lock de-icer if that does not work post it, sure someone on here has an idea of what it is.
Try turning the key as you wiggle the bars back and forth. There's a little bit of play in them at lock.
Edit: To answer your question, yes I've had that happen above freezing.
Not trying to insult your intelligence or anything, but did you try to turn the bars to the left as you turned the key?? I've had it before where there was tension on the locking pin and hard to unlock unless I turned the handlebars a little.
Edit: Damn, CrazyInNYC beat me too it. Got to be fast around here.
I said it first, but he said it better... :blush: :goofy:
ABOVE freezing!??!? :huh: I thought you said 26 degrees. Unless you meant Celcius...in which case the hair dryer prolly won't help :laugh:
I have used the lighter on the key a few times and it works ok. I now carry a can of de icer and tru flow in my stitch my lock smith told me to be careful with the de icer because it removes all lubricant from the switch and it would eat it self in short order he recommended following the de ice with a teflon based lube after using this method it does not continue to get worse throughout the winter as it had in past winters.
So what was the outcome?
Must of got it unstuck?....to busy riding to answer? :goofy: :wheel:
Today the temps were above freezing and the ignition switch worked fine. I figured it was just the low temps freezing it up, but now I have some peace of mind in knowing so.
End of thread · 21 posts recoveredWayback Machine snapshot 12 Apr 2010
