[image: View Post]Alien VFR, on Jan 2 2009, 10:47 PM, said:
[image: View Post]Rivcyko, on Jan 2 2009, 04:43 PM, said:
Should be some in there. Have you checked it, since you got it? (realize it has been a while, since you got it, but be honest).
Nope, bought it new and now 2 years later at 23k miles is the first time I've had the fairings off. Neglegence, I know...
But I'm due for a coolant change, brake fluid change, etc.
Like I said, temps were always in the normal range, so I never bothered to check the level.
So where did the coolant go? There are no leaks, and I do my own oil changes and never noticed any coolant or anything strange in the oil.
Blown head gasket?
Could be just a small breach on the gasket that was just slowly sipping at the coolant system?
Open you radiator cap and see how far down the coolant is.
for the many years I owned my 4th gen, I can only remember having to add coolant twice or three times to get it up to the full level line on the bottle, and It wasn't much I had to add. Most likely from normal evaporation. Losing all the contents in you expansion bottle is definitely normal, unless the dealer never filled it in the first place(?).
Beck
95 VFR
