[image: View Post]Baileyrock, on Jan 12 2009, 04:59 PM, said:
[image: View Post]KeystoneVFR, on Jan 12 2009, 05:24 PM, said:
[image: View Post]soichiro, on Jan 12 2009, 04:45 PM, said:
How does the ABS ring mount? I believe it's just bolted on.
Let me ck. some notes.
Ok, acording to notes from other memebers.
cbr600f4 99-00
cbr900rr 92-93
gl1500C 97-01
are all the same. Aftermarket rotors are stupid expensive for little gain except bling, bling.
[image: View Post]Baileyrock, on Jan 12 2009, 04:57 PM, said:
You can use any 98-09 front rotors from any VFR ABS or Not along with the bikes listed above by Doug.
If you had a abs bike then you would just need to drill 3 small mount holes in one rotor to hold the pulse ring on any of the above mentioned rotors! :cool:
The 3 mount holes are the only difference in an abs rotor! :excl:
i thought just the F4 rotors were interchangeable with ours.
Seb?
I have no personal knowledge of the Wing and 900rr rotors, but have heard it many times that they are the same as the VFR. :huh:
I got that information from the EBC brakes catalogue.
First, I found out which front rotors the VFR uses. Then, I searched the rest of the EBC electronic catalogue for the identical part number, and noted the corresponding Honda models.
Why I did that was to help out a member who was trolling Ebay for used replacement rotors and he wanted to widen his search.
BUT, I've forgotten which was which, so anyone who really NEEDS to know should search the application list themselves.
Edit -> Find -> MD1014X -> Find All
http://www.ebcbrakes...pplications.xls
The MD1014X
c is the contour rotor.
