[image: View Post]Rice, on Jan 21 2009, 11:22 PM, said:
[image: View Post]CrazyInNYC, on Jan 19 2009, 08:17 PM, said:
[image: View Post]Rice, on Jan 19 2009, 07:49 PM, said:
[image: View Post]CrazyInNYC, on Jan 19 2009, 07:26 PM, said:
Thank god you didn't write "irregardless", don't get me started on that one...
What's wrong with that?
:pissed: I hope you're kidding...
Regardless is correct
I believe SNL did one of their boston skits with Ben Affleck and Sully where they used irregardless. I can't find it, but I did find this...
Quote
Irregardless is a term meaning
in spite of or
anyway. According to the Oxford English Dictionary,
Irregardless was first acknowledged in 1912 by the Wentworth American Dialect Dictionary.
:laugh: :cool: :ph34r: :lurk:
:offtopic: :offtopic: :offtopic:
Quote
Main Entry:
ir�re�gard�less Listen to the pronunciation of irregardless
Pronunciation:
\ˌir-i-ˈg�rd-ləs\
Function:
adverb
Etymology:
probably blend of irrespective and regardless
Date:
circa 1912
nonstandard : regardless
usage Irregardless originated in dialectal American speech in the early 20th century. Its fairly widespread use in speech called it to the attention of usage commentators as early as 1927. The most frequently repeated remark about it is that �there is no such word.� There is such a word, however. It is still used primarily in speech, although it can be found from time to time in edited prose. Its reputation has not risen over the years, and it is still a long way from general acceptance. Use regardless instead.
SOURCE: Merriam-Webster
There has been a recent shift in dictionary authoring from prescriptive to descriptive. If enough people use it incorrectly it will end up in a dictionary, although it will likely have the "nonstandard" designation you see above. Slang will also show in some dictionaries.
The point being that irregardless is a double negative and doesn't make logical sense. Rice, I thought you were an IT guy???
Quote
If there are any shifts in the ways that dictionaries respond to the English language it is the general move from prescriptive to reflective. When Dr Johnson first published his Dictionary of the English Language he hoped to record the best that had been written and thought. Now the role of most dictionaries is to record what is used most commonly and to keep up with the pace of change. As Ms Treffry says: "It is no longer a rule book of what you can and cannot use. We simply describe what is going on."
SOURCE
