I am not in any way a paint or painting expert and this is by no means an endorsement to do this and I take no responsibility for your results if you decide to do this, so do so at your own risk. I am posting this as I find this type of information very useful and have made good use of many how-to articles on this site so I wanted to give back.
That out of the way...
The $50.00 Paint job
Probably more like $30.00 or less for a bike. I have some bad paint fade on the rear section of a 91 VFR I picked up about a year ago and was looking for an inexpensive way to repaint it over the winter in my basement. After some searching on the web I came across the $50.00 paint job, seems common to be done on a car but could only find one reference to someone who did it on a tank of a 250 Ninja.
Links
http://board.moparts...l...part=1&vc=1
http://ca.youtube.co...feature=channel
This should give you an idea of what I started with.
Note the paint is almost faded to white on the top portion of the tail section, bungies had also worn through the paint down to black plastic on the sides.
Basically you use a foam roller to roll on Tremclad rust paint (also known as rutoleum in the US). the paint is thinned 40% to 50% with Mineral Spirits.
I used 1/2 can of 230ml Fire Red Tremclad and 1/2 can 230 ml International Red Tremclad mixed to get the color somewhat close to the original paint. This was thinned to about 40% to 50% with Mineral Spirits
Repair all minor imperfections with spot putty
Scuff up the original paint with 400 grit sand paper
Apply 1 coat of paint and let it dry for 12 - 24 hours
I think this is coat 1 - it looked bad after this and I was not sure it was going to turn out
Apply coat 2 and let dry 24 hours
wet sand with 600 grit to remove imperfections
2 more coats of paint allow to dry between coats - Still somewhat worried this isn't going to work.
Wetsand
2 more coats of paint allow to dry between coats - Starting to see better results now
Wetsand
Repeat until you are satisfied with the coverage, it was 7 or 8 coats for me.
On the final coat wetsand with 1500 to 2000 grit - I used 2000 grit
Let paint harden for at least 2 weeks
Buff with power buffer (I didn't have a power buffer so I did it by hand) with cheap Turtle Wax polishing compound.
The result on the bike but a I still have to do the buffing.
This is after some hand buffing
In the end I was pleased with the results the biggest issue for me is the color doesn't match. It works OK on the tail section as it is separated from the rest of the bike so it isn't as noticable. If I was doing this on a black bike it probably would be less of an issue.
Links
Wetsand
Wetsand
