Oil Filter Is Stuck!
The filter came off no problem, the harder you turn the harder is clamps, way better than the screwdriver method
[image: View Post]radar, on Feb 14 2009, 04:44 PM, said:
Had the same problem, then I purchased this type of wrench, http://www.bosstools...mp;ProdID=11970The filter came off no problem, the harder you turn the harder is clamps, way better than the screwdriver method
That looks pretty nice. :cool:
[image: View Post]The mailman, on Feb 15 2009, 01:32 AM, said:
Drive a screwdriver straight through the filter and then you'll have two handles to put some torque on that baby! It's messy but that will get it off quickly. Put an old cookie sheet under there first to ease clean up. (or don't tell your s/o and use a new one, just wash the crap out of it) :biggrin::+1: :+1:
Caveman style mechanics, but it works great! Used the method a few times already.
Beck
95 VFR
Beck
95 VFR
I didnt know there was a different way.
[image: View Post]5speed, on Feb 15 2009, 01:17 AM, said:
Geez, nothing is easy. I tried my two different strap wrenches then bought the kind that fits on the end with a ratchet. It wouldnt budge and now the wrench is moving without budging the filter. Anyone have any suggestions how to get this bastard off?You can grab it straight on from the front with a large pair of Channel Locks if you have a pair.
Draping foil over the header pipes will also lessen the mess.
http://i107.photobucket.com/albums/m317/bluespecv03/Random%20Pics/oilfilterwrench.jpg
[image: View Post]bluespecv03, on Feb 14 2009, 08:18 PM, said:
How bout one of these? Its cheap and available at any auto parts store. Has worked perfectly for me every time.I have one of those. Maybe not the same brand but it slips or crushes the filter when it is really, really stuck. Note: these are filters I didn't install. IIRC, Honda calls for a stupid high torque figure on filters now; probably a liability "thang". I can use either my kung fu grip or a small rubber pipe wrench on filters I install.
Major lesson learned -- I now only use K&N oil filters with a bolt on the top of the filter. You'll never have a problem again, and it will be a piece of cake to reach every time. K&N oil filter from K&N site.
It works better than it looks. I've had an identical one made by LISLE for, jeeez it must be 20 years. I've never had a filter defeat it. Worth every penny and more. :fing02:
Does any one else have any thought about this?
Hand tight with a lubricated seal/oring is plenty for any oil filter. My wife uses her Honda Fit for work and does about 35k miles per year. I change the oil in that thing all the time. I spin it on and off by hand now... works perfect. (It's got the grippy stuff on the end of the filter that helps though.
[image: View Post]unkjj, on Feb 15 2009, 12:07 AM, said:
was the engine cold when you started the oil change. I have found it is much harder to get the filter off if th engine is cold when I start (this is the case with any engine). I always take a lap around the block or just down the street to put a little heat in it, then it comes right off every time.Does any one else have any thought about this?
I agree a warm filter will spin easier.
[image: View Post]bluespecv03, on Feb 14 2009, 09:18 PM, said:
How bout one of these? Its cheap and available at any auto parts store. Has worked perfectly for me every time.http://i107.photobucket.com/albums/m317/bluespecv03/Random%20Pics/oilfilterwrench.jpg
The little socket cups do work the best. However there are many diffirent sizes, even in the same filters. I have 2 at work, just to work on honda filters. I guess it depends on where it is made as to which tool works.
I have a set of oil filter pliers like that and I have not had a single oil filter that they would not take off. The kids at the oil change places put the filters on WAY too tight. These pliers always work.
[image: View Post]CBR_Rod, on Feb 15 2009, 10:50 AM, said:
Only saw one mention of this so I'll mention it again. Put oil on the filter seal before installing it.Absolutly. It really does help the filter to come off. A dry seal will bind on the filter boss.
Lube seal lightly, spin filter on until it touches down, tighten an additional 1/4 turn.
You don't need to be a gorilla to get 'em on...OR off.
Beck
95 VFR
[image: View Post]5speed, on Feb 14 2009, 07:17 PM, said:
Geez, nothing is easy. I tried my two different strap wrenches then bought the kind that fits on the end with a ratchet. It wouldnt budge and now the wrench is moving without budging the filter. Anyone have any suggestions how to get this bastard off?I see you have all the "standard" replies including harpooning the filter with a screwdriver. Before going down that road - if it does not work you have to trailer the bike to a mechanic to get the filter off - try this....
Using a standard worm gear hose clamp with a combination slotted and hex head for tightening the clamp. Install the clamp close to the base of the filter and tighten with a socket wrench. Position the worm gear hex head so you can tap it with a hammer using the socket on an 4-6 inch extension. The force from hammering on the clamp is tangential to rotation of the filter and will break the filter free. BTW, it usually only takes a couple of "taps" to get the filter moving. Once it starts turning you can use any of the other filter wrenches. I have had very good luck removing stuck filters this way without making a mess or destroying the filter.
Stuck filters are usually the result of not oiling the filter before installing.
I can't claim credit for this solution. I found it on the web while trying to get a stuck filter off a GL1800
/Jack
[image: View Post]cbennett5199, on Feb 14 2009, 09:14 PM, said:
Happened to me the first time. It's in a nasty place compared to every other bike I've worked on. :mad: The only way I could get it off was, first, use a screwdriver to see if I could start the twist. After that didn't work, I carefully used a chisel to unfreeze the filter from the threads and, after a bit of careful chiseling, I finally got it loose enough to spin off. It was messy, but I didn't give a crap... I got the damn thing off. :beer:Major lesson learned -- I now only use K&N oil filters with a bolt on the top of the filter. You'll never have a problem again, and it will be a piece of cake to reach every time. K&N oil filter from K&N site.
I have been using the K&N on my Ducati for a decade and swear by them. They work great going on and coming off.
http://www.etoolcart.com/ProductImages/specialty/KD-3253.jpg
[image: View Post]cbennett5199, on Feb 14 2009, 10:14 PM, said:
Major lesson learned -- I now only use K&N oil filters with a bolt on the top of the filter.And how this is better than a standard Honda filter and a standard Honda filter wrench?
Because the nut on the K&N will never come off and that Honda filter wrench is kind of a pile of crap that may or may not grip.
[image: View Post]1996900sp, on Feb 15 2009, 11:44 PM, said:
Because the nut on the K&N will never come off and that Honda filter wrench is kind of a pile of crap that may or may not grip.I must be doing something wrong, because the aforementioned "pile of crap" grips perfectly every time I need to replace my filter. For a fraction of K&N's price, too.
Ok dude relax, you are lucky you have not come upon one of the dreaded stuck filters like many of us have.
I do wish the VFR's oil filter placement was a bit easier to access tho. :mellow:
[image: View Post]Trinith, on Feb 16 2009, 01:48 AM, said:
I typically only put them on hand tight. When it comes time to change them a good solid grip and grunt gets it off pretty easily. Haven't needed a wrench for a bike filter yet...and I haven't had one fall off either.Same here. Of course I also oil the seal before installing and warm the engine for a couple of minutes as well. Works on bikes and cars. The only time I have had to hammer a screw driver through a filter is if I have the work done at a dealership/oil change shop (which is something I haven't done in years). Hand tight and 1/4 turn extra. Over torquing a filter is also a good way to strip the seal.
