Seat Cowl
[image: View Post]landlover, on Mar 5 2009, 08:27 PM, said:
Hi, have a 2007 VFR RWB, usually leave the cowl on when riding, do any of you that have a sixth generation VFR also ride with the cowl on and if so does it leave markings from rubbing the plastic?Mine left two small rub marks in the rear corners...I leave it on most of the time also.
+1
but the grab rails make much larger marks.
[image: View Post]landlover, on Mar 5 2009, 07:27 PM, said:
Hi, have a 2007 VFR RWB, usually leave the cowl on when riding, do any of you that have a sixth generation VFR also ride with the cowl on and if so does it leave markings from rubbing the plastic?Yes. I put a couple of small pieces of the 3M clear material on there to keep it from getting worse. Most of the time I ride with the cowl on.
Dirk
Dirk
Yes same here. The dealer even replaced the plastics once and put some foam pads on the bottom the the cover. Still scratched again. Just dealing with it now.
Hi, have a 2007 VFR RWB, usually leave the cowl on when riding, do any of you that have a sixth generation VFR also ride with the cowl on and if so does it leave markings from rubbing the plastic?mine doesn't leave a mark from rubbing, but from being pressed up against there constantly. Doesn't bother me one bit.
[image: View Post]bluespecv03, on Mar 5 2009, 08:55 PM, said:
Mine have marks as well. What marks do the grab rails make?I'm guessing he's joking about the looks of the handles just being there :biggrin:
Beg to differ. Handles make marks, too. try'n to find the pic.,..................
http://i37.photobucket.com/albums/e81/Dutch9090/VFR%20Misc/008.jpg
http://i37.photobucket.com/albums/e81/Dutch9090/VFR%20Misc/013.jpg
I see what you talking about.....Learning as I go....."It's better to say nothing and be thought a fool;Than to speak up and let it be known"......
Chinese Proverb:
"When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others.".......................Monk
[image: View Post]hidesertmlb, on Mar 6 2009, 07:41 AM, said:
I have the cowl on always. Yep, rub marks present on the tail fairing underneath the back edge of the cowl. I just learned to live with it. :dry:Still can't talk your wife in to getting on the back huh Mike? :laugh: :laugh: :laugh:
[image: View Post]hidesertmlb, on Mar 6 2009, 11:41 AM, said:
I have the cowl on always. Yep, rub marks present on the tail fairing underneath the back edge of the cowl. I just learned to live with it. :dry:You are a bigger person than me! Pay X amount of dollars for a brand new bike and use the cowl and in return it leaves marks that can not be taken out, sounds like a crock of s*** if you ask me.
Hi, have a 2007 VFR RWB, usually leave the cowl on when riding, do any of you that have a sixth generation VFR also ride with the cowl on and if so does it leave markings from rubbing the plastic?I apprciate the heads up! I have not noticed this but now that I have been warned, I will try to come up with a solution. If it works, I'll let you know. I took my hand rails off the second week after I bought my bike since I was told they can have a similiar effect. Thanks, JD
Yes, sir. Welcome to the new millennium. "Thanks for your $$, now pi$$ off". At least you'll still get a trillion miles on it. Though, in 10 years, the thread will be,..." Street fighter or not?"
"Value-able,... are any paint and bodywork, skills, one has."
http://kimskorner.zed1.net/albums/Answers/Yoda.sized.jpg
[image: View Post]toddulu, on Mar 6 2009, 07:53 AM, said:
Still can't talk your wife in to getting on the back huh Mike? :laugh: :laugh: :laugh:Since a Wave Runner two-up plunge at Lake Mojave a couple summers back, no. I don't think she will ever be back on. :unsure:
As for the rub marks, it sucks, I know. I don't know whether mine were influenced by the tank bra (seat is pushed back slightly?), or just bad fitment from the factory. Relatively speaking, when compared with the 4th gen tail section (prone to cracking), I would rather have rub marks instead.
