So, adjusting the front suspension. I assume you use a screwdriver? Is there something else? I tried a screwdriver and it worked, but the blade isn't as wide as the slot so it cuts into the metal.
A bicycle cone wrench. Big flat surface, slots in nicely, has a long handle and doesn't chew up the soft aluminum like a regular screwdriver. I suppose you could also improvise with a biga$$ flat washer and vice grips ala McGiver...
I started to type a response....then had a duh moment. I understand, and I own cone wrenches.
