Cheap Pilot Powers?
20 posts Started 19 May 2009 Last recovered post 20 May 2009 Wayback Machine snapshot 2 Sep 2010
So, I burned up my tires at TMAC and I have just a few threads showing through on the rear. I need new rubber and it must a Pilot. Where do you guys get cheap tires?
Kevin
PM wera803. He has a line on lightly used PP's from Kevin Schwantz's RR school in N. Ga.
They're bad luck, though!
Just Kidding!
That's if you don't mind race take offs.
A few of 'em don't even have chicken strips. :laugh:
I don't know what the pricing is on the race takeoffs...but the best price I've found for new Michelin street tires is at derbycycles.com
http://www.derbycycles.com/cgi-bin/eShop/i...lin&count=1
If you're in a rush you can call dennis kirk and they will price match the derby cycles price and you'll get them the next day.
:+1: :+1:
:+1: :+1:
Have to say is I think that's the best price I've seen on PP's.
Not only low prices, but fast standard shipping, and they send them in a cardboard box!
OK... so the front is a 120 something. Is the second number the angle of attack or something? So, what I'm getting at is do I need the 120/60... 120/65.... or 120/70. And if I can use all three what is the difference? Which one is going to give me the fastest turn in?
Kevin
First number is tread width, second number is % of width is the height. Example in car tires:
265/75/16
265mm width
sidewall is 75% of width so sidewall is 198.75mm
16 inch wheel diameter
tire overall diameter is 16" + (198.75mm*2)
IIRC, the VFR is 120/70/17
[image: View Post]turtlecreek, on May 19 2009, 11:14 PM, said:
120/70 is what you want.
+ a 180/55ZR17 for the rear.
265/75/16
265mm width
Huh? :blink:
120/70/17 =
4.72" wide with a 3.31" sidewall which gives a tire that is 4.72" wide and 23.61" tall overall.
120/60/17 would be
4.72" wide with a 2.83" sidewall, so 4.72" wide and 22.67" tall overall.
The diameter of the tire affects overall gear ratio, as well as unsprung weight. Larger tires will also ride "smoother" because it is easier for a larger diameter tire to roll over bumps. Basically, you should stick with stock unless you are well aware of the benefits and the very real drawbacks of changing tire sizes. Usually the people that design a vehicle specified a tire size for a list of good reasons.
OK. Just ordered a Road2 rear and a Power front. Under $300 delivered with tax. Feel like I'm getting a pretty good deal. I just hope I like the Road2 rear. But, every rider in my group on Saturday had this combo so it must be as advertised.
Kevin
I will vouch for the Pilot Road 2 rear. After running Powers for years, I only plan on buying Pilot Road2 rears until something better comes along (excluding special deals like take offs). The Road2s have 90% of the Power performance with nearly double the tread life.
The funniest thing about this whole post.... Derby Cycles is run by a member of another board I am a member of. www.kentucky-sportbikes.com Small world.
Kevin
265/75/16
265mm width
Huh? :blink:
Basically, the middle number is how tall the tire is. If it was 120/70/17, the tire would be 120 mm wide, 120mm tall (sidewall height), and on a 17" wheel. If it were 120/50/17 it would be 120 mm wide, 60 mm tall, and on a 17 inch wheel.
Think of older cars with taller tires as having the middle number as a 70 or 75. (it's 70% or 75% as tall as it is wide). Cars with bigger wheels and rubber-band low profile tires will have the middle number as a 50 or lower.
We can fit different profile (different middle number) tires onto the wheel, but it drastically changes the shape of the tire, which greatly affects turn-in, and is not recommended.
265/75/16
265mm width
Huh? :blink:
I should add, that fitting a wider or skinnier (first number) tire on a rim also changes the shape and affects turn in...
End of thread · 20 posts recovered Wayback Machine snapshot 2 Sep 2010
