What is the relationship (or is there one) between chicken stripe width and proper set-up of a bike?
[image: View Post]Beck, on Jun 5 2009, 04:01 PM, said:
Uhmmm... I dunno....effects of countersteering???[image: View Post]sckego, on Jun 5 2009, 02:22 PM, said:
Chicken strips come off through a combination of lean + pressure on the tire. On the rear tire, this happens while getting on the gas coming out of a corner... a fairly common occurance for most riders. The lean, combined with the tire getting further 'squished' due to the weight transfer to the rear, can force the tire down to it's edge or beyond. Scrubbing the strips off of the front, on the other hand, mean that you need weight on the front while leaned over, which is what you get while trail-braking deep into a corner... not so common for alot of riders, which is why most have much larger strips on the front then the rear.[image: View Post]HispanicSlammer, on Jun 5 2009, 03:40 PM, said:
Chicken strips come off through a combination of lean + pressure on the tire. On the rear tire, this happens while getting on the gas coming out of a corner... a fairly common occurance for most riders. The lean, combined with the tire getting further 'squished' due to the weight transfer to the rear, can force the tire down to it's edge or beyond. Scrubbing the strips off of the front, on the other hand, mean that you need weight on the front while leaned over, which is what you get while trail-braking deep into a corner... not so common for alot of riders, which is why most have much larger strips on the front then the rear.[image: View Post]turtlecreek, on Jun 5 2009, 04:15 PM, said:
Chicken strips come off through a combination of lean + pressure on the tire. On the rear tire, this happens while getting on the gas coming out of a corner... a fairly common occurance for most riders. The lean, combined with the tire getting further 'squished' due to the weight transfer to the rear, can force the tire down to it's edge or beyond. Scrubbing the strips off of the front, on the other hand, mean that you need weight on the front while leaned over, which is what you get while trail-braking deep into a corner... not so common for alot of riders, which is why most have much larger strips on the front then the rear.[image: View Post]SEBSPEED, on Jun 5 2009, 06:34 PM, said:
I'm no expert though![image: View Post]BusyLittleShop, on Jun 5 2009, 10:30 PM, said:
A question was raised on what creates disparity of wear[image: View Post]RIDER_44, on Jun 6 2009, 02:12 AM, said:
A question was raised on what creates disparity of wear[image: View Post]RIDER_44, on Jun 5 2009, 11:12 PM, said:
I will also have to concur that, playing on the edge is for the track...not the street.
Chicken strips come off through a combination of lean + pressure on the tire. On the rear tire, this happens while getting on the gas coming out of a corner... a fairly common occurance for most riders. The lean, combined with the tire getting further 'squished' due to the weight transfer to the rear, can force the tire down to it's edge or beyond. Scrubbing the strips off of the front, on the other hand, mean that you need weight on the front while leaned over, which is what you get while trail-braking deep into a corner... not so common for alot of riders, which is why most have much larger strips on the front then the rear.[image: View Post]Bent, on Jun 8 2009, 10:48 AM, said:
Ya gotta point there, Dale. I heard Bea's is near Chapter 11 because we haven't been there in too long. We need to go help them out![image: View Post]BusyLittleShop, on Jun 6 2009, 01:30 AM, said:
A question was raised on what creates disparity of wear[image: View Post]BusyLittleShop, on Jun 6 2009, 04:06 AM, said:
A question was raised on what creates disparity of wear[image: View Post]TimC, on Jun 8 2009, 12:53 PM, said:
I'd also think that shorter wheelbase/quicker steering bikes like supermotards would show more front tire wear away from the centertread.[image: View Post]Pete McCrary, on Jun 8 2009, 12:18 PM, said:
Speaking of tires, lean angles, etc- I am hearing more and more about Goldwing riders running small automotive tires on the rear of their bikes as opposed to motorcycle tires. Yikes![image: View Post]Pete McCrary, on Jun 8 2009, 10:18 AM, said:
Speaking of tires, lean angles, etc- I am hearing more and more about Goldwing riders running small automotive tires on the rear of their bikes as opposed to motorcycle tires. Yikes![image: View Post]SEBSPEED, on Jun 8 2009, 10:12 AM, said:
