Who Said Vfr.s Cant Wheelie?
Kind of hard to translate what the guy said mostly cause I'm not sure how it translates, but I think the guy was saying 'Stay back cause either way you can't make it the whole way'
http://www.vfrdiscussion.com/forum/uploads/1244980093/gallery_13129_4707_866259.jpg
[image: View Post]SEBSPEED, on Jul 11 2009, 01:07 PM, said:
Funny you posted this, I just ran one up into 4th gear for the first time today! :wheel:That would be even cooler if you were doing a wheelie Seb! :laugh:
:squid:
:squid:
Yeah, the guys at the safety course for hopeless beginners told me to take it easy and start slow... :blush:
:laugh:
[image: View Post]YoshiHNS, on Jul 11 2009, 02:47 PM, said:
HAHAHAHAHA. HUNGARIANS!!!!Kind of hard to translate what the guy said mostly cause I'm not sure how it translates, but I think the guy was saying 'Stay back cause either way you can't make it the whole way'
Your translation is pretty close! :fing02:
He said "Stay back a little, because you cannot go like this all the way." "Ok."
Man, they should have done something with the noise. Even when they were standing next to each other it sounded like a hurricane. :angry:
[image: View Post]ericlee, on Jul 11 2009, 01:47 PM, said:
im think its cool he can drop it back down seemingly pretty soft instead of slamming it down.Just open the throttle more when the front is coming down and it will slow down the descent. Doing wheelies in 1st gear with huge engine braking is a recipe for a balls / fuel tank meeting, 2nd gear clutch works much better.
[image: View Post]Pete McCrary, on Jul 11 2009, 10:58 PM, said:
I was one of those unfortunate ones that was born without the wheelie gene in my DNA.Get the technique down on a mountain bike or dirt bike, then transferring those skills to a street bike is easy.
I was one of those unfortunate ones that was born without the wheelie gene in my DNA.:+1:
[image: View Post]jeremy556, on Jul 12 2009, 02:59 AM, said:
Not impressed. I have seen an old guy do longer wheelies on the Cherohala.I'm not that old Jeremy! :cool:
Apparently, I was born with the wheelie gene... and it's really been working against the old "Veteran MSF Instructor" thing I've got goin' on certain weekends... I'm getting certification to teach the new "Advanced Rider Course - Sportbike Techniques" in two weeks... so, I'm sure there will be a wheelie segment in there... if not, I'll just have to add it. :blink:
You wheelie??? :blink:
:laugh:
[image: View Post]gruss, on Jul 11 2009, 08:13 PM, said:
yuttt ughhhi laughed when i read that
[image: View Post]jeremy556, on Jul 11 2009, 10:58 PM, said:
Just open the throttle more when the front is coming down and it will slow down the descent. Doing wheelies in 1st gear with huge engine braking is a recipe for a balls / fuel tank meeting, 2nd gear clutch works much better.And that, girls and boys, is how peanut butter was discovered...................................... :dry: :idea3:
No; It Wheelie was! :warranty: :squid: :wheel: :comp13: :fing02: :rolleyes:
Ya, dat's it........... :491:
[image: View Post]rangerscott69, on Jul 15 2009, 08:08 PM, said:
You gotta cover that rear brake.http://www.ringburn.net/yutughhh/
Funny little game
Funny little game
yeah, Woo, I got up to 5,000 points! I had to turn the sound off to do it...
http://www.vfrdiscussion.com/forum/uploads/1247600307/gallery_9864_2412_44266.jpg
Proof
[image: View Post]vanion2, on Jul 16 2009, 09:19 AM, said:
I had 5 minutes to kill...http://www.vfrdiscussion.com/forum/uploads/1247600307/gallery_9864_2412_44266.jpg
Proof
I don't know hot to save a screen shot. But I got 20020, which is way longer than any real life wheelies I've had! :biggrin:
[image: View Post]freako, on Jul 16 2009, 10:03 AM, said:
Ok..Im gonna ask a stupid question here and I don't need the link to the Wheelie School...but....
How do you wheelie properly? I can't imagine you pop the clutch. I also don't think the VFR has enough power to just wheelie upon applying full throttle. What is the exact technique?
Please be gentle....
P
Ex-Floridian here...
Best way, IMO, is to use the clutch in 2nd gear. Reason for this, is in second gear you have less torque, so it is not as easy to loop it, and less engine braking, so if you chop the throttle the bike doesn't come back down as hard. It is also much easier to shift from 2nd to 3rd than from 1st to 2nd.
You can also just use the throttle in 1st gear, just roll along at about 7000RPM and roll on the throttle. Either way, make sure and roll back on the throttle when setting the front end back down to soften the landing.
To do a 2nd gear clutch wheelie, roll along at whatever MPH is 4500RPM in 2nd, go WFO throttle and hold it, then feather the clutch. When I say feather, I don't mean pop it, you won't get the front wheel off the ground doing that. You need to use the clutch to modulate the power to the ground, and it will take a lot of practice to get it right. Don't pull the clutch all the way in, just until it engages, then use the 'friction zone.' You probably won't get the front tire more than an inch off the ground the first 100 times you try it. Once you get it down though, it is an easy, reliable way to get to the balance point.
P
About 2nd gear wheelie, when you are at 4500 rpm...is the clutch out or all the way in at the moment when you go WFO. What I am asking is when you are rolling along at 4500 rpm and crank the throttle is the clutch out and then u pull the clutch in a little to feather it or are you rolling along with the clutch in and go WFO and start letting the clutch out slowly (feather it)???
[image: View Post]jeremy556, on Jul 11 2009, 10:59 PM, said:
Not impressed. I have seen an old guy do longer wheelies on the Cherohala.Just what age do you refer to as old?
Anyone that can race in the Senior Superbike class in WERA :biggrin:
. . . . . . and that age is? I'm assuming I would qualify.
I did wheelie my bicycle practically all the way across Cobb County in my younger days. When I was 12 years old in 1962.
Put a heavy passenger on back/ fill your saddlebags with weights.
Put your feet on the rear pegs and lean all the way back.
Add MAXIMUM front preload (seriously, the suspension won't be able to extend, and so any upward motion will lift the tire off the ground, the bike will be unstable and dangerous, but you'll wheelie easy).
Get a torocharger.
change gearing.
And, of course, buy a GSX-R. :goofy:
This coming from the guy who's only got the front wheel off the ground on accident...
I looked it up in the rule book - 40 years old is called Senior? I'd give anything to be 40 years old again.
They need to invent a Super Senior classification then. Minimum requirements:
1. Member of the AARP.
2. One or more grandchildren.
Jeremy, you're dang young punk. I ought to get my walker and come to Marietta and teach you some respect for your elders. :biggrin:
This could be a U tube classic in the making! "Young Punk Beating - note carbon fiber walker for faster swing"
Watch out Jeremy
[image: View Post]Pete McCrary, on Jul 16 2009, 01:26 PM, said:
I looked it up in the rule book - 40 years old is called Senior?Jeremy, you're dang young punk. I ought to get my walker and come to Marietta and teach you some respect for your elders. :biggrin:
Thought you would like that :laugh:
Bring it! http://www.cflriders.com/forums/images/easyaction/smilies/Fighting/boxing.gif
[image: View Post]ZiaVFR, on Jul 16 2009, 02:20 PM, said:
This could be a U tube classic in the making! "Young Punk Beating - note carbon fiber walker for faster swing"Watch out Jeremy
Careful now! Ain't a single one of us getting any younger.
Boy BR sure has been quite on this one. Hey Old Timer, I could use some help here. Dang kids are ganging up on me!
I never speed or wheelie, it's against the Law and dangerous! I leave it to the :squid: :squid: 's. :ph34r:
[image: View Post]timmythecop, on Jul 16 2009, 11:50 AM, said:
Boy, that sucked! :huh:
If I had an $800 old KLR I'd maybe experiment with doin' wheelies. But NOT on my $5,000 baby VFR. I can just see it now... wife comes home, sees the lovely red cycle all scratched up and beat, because of me trying to do wheelies in a parking lot. I don't need that aggravation. Or repair bill.
Yeah, if I need to do wheelies I'll stick to tryin' to pull 'em on my Specialized mountain bike.
Just me.
do you 180 or Dragon?
P
I've heard,,, just heard mind you, I've not tried it myself,,, that the best way to wheelie is the buy an Aprillia Tuono. :biggrin: Apparently, they wheelie without any special training at all.
GypsyCat
[image: View Post]freako, on 16 July 2009 - 08:03 AM, said:
[image: View Post]timmythecop, on Jul 11 2009, 01:39 PM, said:
<!--id1--><object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/kuK-EQ81fSc&"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/kuK-EQ81fSc&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object><!--id2-->Ok..Im gonna ask a stupid question here and I don't need the link to the Wheelie School...
but....
With warm tires...Roll to about 15 to 20 MPH...roll off the throttle, then back on with about 75% throttle real quick! The front end will lift with the application of throttle! No clutch required! Clean pavement, no dirt, preferably a nice clean road or
very large lot! I watched the clutching video and may try it...but I hate wear on the clutch! Have a Wheely nice day! Happy New Year!!!!!
Attached thumbnail(s)
- [image: Attached Image]
