I just got a new to me 2006 VFR. I weigh 220lbs and would like to set the suspension properly for my weight.
It's hard to measure everything solo, plus I'm no expert and I don't have the proper tools.
Is there anyone in the LA area (I'm in the valley but can travel) that can help me get it setup?
To say thanks, I can buy you a six pack / lunch / tank of gas? Thanks.
You do need a friend, but no special tools are required... There are videos detailing the process (which is the same on almost all sport(y) bikes) on youtube.
I'm way out in Perris, Just south of RIverside, but would be willing to help if you feel like the long travel. Hopefully someone closer to you will chime in and be willing to help to save you the long travel.
Seriously though, it's a pretty simple process on the VFR since there is not a whole lot to adjust on the bike, just sag (preload) and rear rebound damping.
For your weight though, you may need stiffer fork springs.
This video is a good start for suspension settings.
[image: View Post]JBAXX, on Jul 25 2009, 08:03 PM, said:
Make it three and I'll be there too! ;p
Jerry, I might take you up on that offer since you're only minutes from me.
Michael
No problem Michael. Bring a six pack each for Greg, Shayne, and myself! :laugh:
I might have to come to you since my garage doesn't have room for any more bikes!
You can adjust sag on the stock suspension, but at your weight it will never be correct! :huh: You would have No Free sag if you try to get the rear anywhere near and ideal setting, maybe 35-40mm Sag street riding rear and 30-35mm front sag.
At 220 lbs you should look at buying new springs front & rear, something if the range of a .95kg front(stock .74kg) and a 19-21kg rear spring(stock 15.3kg)
Good luck! :cool:
End of thread · 11 posts recoveredWayback Machine snapshot 9 Apr 2010
