My local shop said 34 front and 32 rear .
Disadvantages of Underinflation
An underinflated tire can't maintain its shape and becomes flatter than intended while in contact with the road. If a vehicle's tires are underinflated by only 6 psi it could weaken the tire's internal structure and eventually lead to tire failure. Lower inflation pressures will allow more deflection as the tire rolls. This will build up more internal heat, increase rolling resistance (causing a reduction in fuel economy of up to 5%) and reduce the tire's tread life by as much as 25% while increasing the probability of irregular treadwear. Drivers would also find a noteworthy loss of steering precision and cornering stability. While 6 psi doesn't seem excessively low, it typically represents about 20% of a passenger car tire's recommended pressure.
Disadvantages of Overinflation
An overinflated tire is stiff and unyielding and the size of its footprint in contact with the road is reduced. If a vehicle's tires are overinflated by 6 psi, they could be damaged more easily when encountering potholes or debris in the road, as well as experience irregular tread wear. Higher inflated tires cannot isolate road irregularities as well causing the vehicle to ride harsher and transmit more noise into its interior. However, higher inflation pressures reduce rolling resistance slightly and typically provide a slight improvement in steering response and cornering stability. This is why participants who use street tires in autocrosses, track events and road races run higher than normal inflation pressures.
__________________
What do you guys run in your tires ?
At the track with Michelin DOT's I run 31/22 cold. :laugh:
I'm assuming this is a typo and you mean 31/32?
No, several years ago both Dunlop's Ntec rears and Michelins DOT Race rears have had recommended cold tire pressures of 21-22 psi, I guess mostly because of construction process changes! Been ruuning at or near the front of the fastest group at tracks near you for the last 3 years! :blush:
Hot rear pressures are around 25-26 psi.
btw these are in no way like any street tires. :laugh:
More like >99.9%In the last 100,000 miles of rippen twisties at speeds higher than 80-90% of most riders
:laugh: I wish. Thanks for slowing down occasionally so I can catch up.If I lived on the Dragon and was as quick as Jeremy is there, I might drop pressures a little lower to try an keep up. :blush:
Correct, those are DOT race tires. Not slicks with treads cut into them, but street legal tires meant for racing. You would quickly overheat a street tire at that pressure and have little traction, though it does make wheelies MUCH easier.No, several years ago both Dunlop's Ntec rears and Michelins DOT Race rears have had recommended cold tire pressures of 21-22 psi, I guess mostly because of construction process changes! Been ruuning at or near the front of the fastest group at tracks near you for the last 3 years! :blush:
Wow, that is low tire pressure. Those are race tires with treads cut in them, right? Good for only 6-7 heat cycles?
Anyway, no need to ever go anywhere near that low on the street, on street tires you'll have almost no traction and could damage your tire.
Slicks with treads cut into them are exactly that - non street legal racing tires, slicks, that someone has literally cut tread into. I don't see these much except on motards at Deal's Gap. I am not 100% sure on all the reasoning for doing this, but it would make the tire rideable in wet weather, and possibly avoid a ticket. Hopefully someone else can chime in on this, as I would like to know more.Correct, those are DOT race tires. Not slicks with treads cut into them, but street legal tires meant for racing. You would quickly overheat a street tire at that pressure and have little traction, though it does make wheelies MUCH easier.
Off topic, but what's the difference between slicks with treads cut into them and DOT race tires?
Might I suggest you buy a bicycle pump(floor type),cheap. That way I can top them both off with less than 10 pumps while cold....I'm sad because I think there's got to be something like a nail or similar through the rear PR2 on my VFR; I came out to the bike earlier this week and noticed it was getting harder and harder to walk it out of the garage in the mornings. Finally put a gauge on it and it was, uh, let's just say "stupidly low". Had to idle to a gas station about a mile away with my own gauge to get it back to something close to right, stopped when I had 36 in the front (it was down a few pounds) and 40 in the rear. Felt like a whole new bike. Have been keeping my eye on it, will check again today and see what it's like, but I'm really hoping it was some sort of one time leak (like that makes any sense) and that I don't have to put a plug through a PR2 rear with less than 3k miles on it.
Glad you mentioned the weight Busy,
cause the same tire pressure needs are not the same for every bike.
36/42 on some bikes would be like riding a complete Rock , works on the vfr though
I just got a 07 GSXR and I am commuting 180 miles round trip every day. What kind of tire pressure should I keep in my tires??? Thanks!!!
I just purchased an 07 GSXR and I am currently commuting 180 miles round-trip everyday...What do you guys recommend for my tire pressure setting? Also, how often should I change the oil since its all freeway riding?
36/42 F/R works just fine
Why would you buy a GSXR for freeway riding?
You can run a few more PSI on the freeway than in the twisties, but check what the bike says it takes.
I bought the bike for weekend riding and recently moved far from work and sold my car for a down payment on a house...I know it sucks riding that beast after about an hour...But, on the plus side, my commute is mostly hills and sharp turns http://www.vfrdiscus...tyle_emoticons/default/wink.gif
